Mar 22, 2020 19:22:51 GMT
V70 indicator fell out on the M6, luckily the wiring stopped it from disappearing, it was having a good flap/bang on the front wing. The front cover has in part split from the housing, I can not leave it like that as water will get in. I have removed it completely and now need something to stick it with. I have superglue and araldite, yes or no on these please or recommend something perfect. Ta very much in advance. 👍
Bicycle x1 Alfa Giulietta (now wife's) Alfa 156 BMW 630i
Mar 22, 2020 20:12:29 GMT
picture?
Mar 22, 2020 21:21:00 GMT
There you go.
loko
Mar 22, 2020 22:45:47 GMT
Mar 22, 2020 23:42:11 GMT
Dez
Club RR Member Number: 34
Gluing IndicatorsDez
@dez
Club Retro Rides Member 34
Mar 22, 2020 23:49:58 GMT
The fumes from Superglue will make the clear plastic go white/cloudy.
You need the model makers favourite, polystyrene cement.
I would probably go with a thin bead of clear "sticks like" or similar construction adhesive. A solvent glue will certainly re-attach the lens but you will always have the potential for cloudyness with clear items , also a caulk type ashesive will form a seal to prevent water ingress.
Mar 23, 2020 11:21:25 GMT
Thanks everyone, I went with multi stick (shop had it)
drseg
ordinary silicone is awesome, sticks toilets to tiles!
