thomfr
May 12, 2020 14:03:53 GMT
I sent a short email with the same question concerning hazard lights to the supplier of the LED indicator relay and he answered me that using a 3 pdt style switch will do the job together with the LED indicator relay. I searched the internet and found only 240 volt versions. Wonder if they also work with 12 volt?? Thom
UPDATE: YES, I CAN USE A 240 VOLT SWITCH FOR 12 VOLT.
Last Edit: May 23, 2020 9:19:20 GMT by thomfr
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
thomfr
Jun 17, 2020 19:48:00 GMT
No action? yes, off course! Must admit that I spent most of my time looking for a new job (frustrating process with idiot HR departments, companies that mean that 20 years of experience come for an starter salary etc. etc.) But I'm making some progress, keep fingers crossed. I did finish the electrics of the Alfa. Will refit the dashboard tomorrow with my dad. Also replace carburetor rubbers (between inlet and carbs), refitted the carbs itself and fitted almost all waterlines. (forgot to take pictures..). Next on the list is fitting dashboard, the exhaust manifold, last flexible water lines and filling fluids. Looking forward to a good test drive. Thom
thomfr
And then there is (bright) light! Dash and gauges are in again and the relays for the lights (to avoid running the full current over the light switch as it was OEM) and petrol pump nicely sit on the under dash parcel shelve. The green and yellow cable rolled in front are speaker cables currently not in use but I saved them (they are connected to the door speakers) if I do change my mind in the future and fit a radio again. Now fighting to refit the 15 years old inox manifold (4 into 2 into 1 2"bore from Alfaholics) and exhaust which does not want to go in again tension free. I asked a mate to help tomorrow with this as it is a pig of a job to do on your own. Next will be firing up and test drive. Thom
Last Edit: Aug 7, 2020 10:16:06 GMT by thomfr
thomfr
Aug 12, 2020 21:11:33 GMT
It’s alive again! Tomorrow APK (Dutch MOT) Time. Thom (Sorry for the mess, have to clean up and tidy the Garage now).
Last Edit: Aug 13, 2020 12:59:09 GMT by thomfr
thomfr
Aug 13, 2020 13:07:50 GMT
MOT failure...
First got a call that the defrosting was not working. Explained them that they had to close the flap which allows air to the feet manually instead of pushing a button. Solved! ;-)
Then the right main beam was pointing too much to the middle of the street. One screwdriver and 1 minute later solved.
Last one was unfortunately not so fast to solve as being a steering joint under the steering box having a bit of play and a nasty crack in the grommet (= failure) which you only can see if the wheels are hanging free in the air (like they do during MOT front axle test...).
So, I have to order a new joint, but first have to take it out as they are used with normal and left turning treat and I will otherwise for 100% sure order the wrong one... ;-).
Thom
teaboy
Make tea, not war.
Aug 13, 2020 13:28:19 GMT
That’s not too disastrous a result.
thomfr
Aug 27, 2020 14:04:11 GMT
APK (Dutch MOT done!) So legal again for the next two years. The Alfa is built in 1973 and the Dutch government is discussing (too long already) the MOT stop for cars older than 50 years so hopefully only one more time in two years. The Alfa is now in (decent weather) daily service again and met an Polish/Italian soulmate on a Supermarket parking lot. ;-) With the Alfa fit again I moved attention over to the Volvo Duett which is currently still parked in my dads garage. Before we moved to our new house (3 years ago) all the welding had been done and the body was prepared for painting but only the white part was painted. It should get this color combination (Picture from the web, not my car) This combination of light grey and dark blue is correct for the model but not for the model year but I really do not want to paint it bright orange as it was originally. It looks like this now: The painter is always very busy but happens to drive a 74" Dodge Coronet with some electric problems. I made a deal that I will have a look at the Dodge electrics and he will take care about the painting of the Volvo somewhere in the next two months (so bypassing his ques of waiting vehicles) and giving me a hefty discount on labour but off course I have to pay the materials and the cabin rent (he has to pay his boss some hourly rate for the energy use). Which means I have to hurry with the fitting of my disk brake conversion on the front axle to get it rolling again. Shock absorber lower mounting modified (otherwise the car will have a turning circle like an oil tanker) and Amazon brake anchor plate modified to fit the Duet/PV hubbs. This is fun! Thom
eurogranada
Nice result on the MOT.
I really think I should make a point of looking you up one day, as well as another dutchy on here...
thomfr
Sept 7, 2020 16:54:46 GMT
The Alfa is running faultless. Some progress made to the Volvo, Brakes now fitted (bar lines). I found a nice NOS Smiths mechanical oil thermometer in my dads garage so now looking for a matching mechanical Oil Pressure gauge (one with a tube connection to the engine). Would be anice touch under the dash. forum.retro-rides.org/thread/215611/looking-smiths-mechanical-pressure-manometerMy neighbour is also a car nut and parked his Volvo outside today. Nice motivation push ;-). Thom
Last Edit: Sept 7, 2020 16:56:19 GMT by thomfr
Sept 8, 2020 18:00:22 GMT
Get an MGB combined water temp. oil pressure one ...
thomfr
Sept 9, 2020 17:44:28 GMT
Get an MGB combined water temp. oil pressure one ... It has had a functioning water temp gauge for the last 55 years.. The scale of a water temp gauge is different from scale (for oil it will always stand at least at 3/4 scale). Thom
thomfr
Sept 15, 2020 20:20:25 GMT
Saturday was a good day as I could make my car painter happy with functioning lights on his 74 Dodge Coronet. He only has to come back as the horn is not working yet (keeps blowing fuses). Happy painter means short waiting time for painting my Duett... ;-) Today was a bad day as I had expected feedback (so I was told) on a third (job) interview of last Thursday on Friday or Monday but up to tonight, nothing. Tried to reach HR without success... So my head was a bit full so only removed some (30m2) plastic "wood strips" (do not know the correct English word) from the veranda ceiling which I want to replace with wood and hung a water hose buddy which was languishing in my garage for ages. Thom Tomorrow I want to proceed further with the Duett brakes (F%ck job search! Grrrr.).
Sept 15, 2020 22:18:14 GMT
Good luck with e job search It’s not fun. I know since my wife is in a similar position. I like the hose arrangement. Porsche?
thomfr
Sept 16, 2020 7:47:04 GMT
Thanks! Wheel is a Alfa 156/147 Speedline works option (bent rim) Thom
Sept 16, 2020 12:09:56 GMT
Thanks! Wheel is a Alfa 156/147 Speedline works option (bent rim) Thom I see, Ive not been into the Alfa scene for quite some time (used to drive a 75 when I was young as well as a Bertone 1750 GTV) Nowdays it’s more Volvo cars.
thomfr
Oct 10, 2020 19:35:52 GMT
Long time no update. The Alfa is running fine and I enjoyed late summer very much Work on the Volvo is slow but going forward on electrics, brakes and body. I only forgot to take same foto's... My mum came up the other day with one of my old rooms ornaments My Bibendum which I got somewhere mid 70's from my father trusty company haulier as present. Had it on the wall in my boys room for years and it landed on my parents attic. My mum found it last week and gave it to me. Looked up an old lamp fixture, putted in a 1Watt LED and hung it in my garage. Memories.... Also I finaly moved my bigger compressor in (Javac TX3). It needed 240V. 20Amp power which I did not have until last week so it lived a while (4 years) in my fathers garage. Finally enough air supply for all my jobs (360 litres nett at 8 bar). It fits nicely under my little fab. table )which was made at it's height ;-) ). Thom
thomfr
Last week was a combination of one live and two online job interviews. No feedback yet. I helped my dad with getting an engine from his attic (see other topic) Thought just about making some more progress on the Duett but.. I enjoyed the Alfa for a bit more than 1000 Km. after it's open hard surgery but when I started it yesterday to take it for a spun (after weeks of rain the temperature has dropped slightly and we have nice open sunny weather) it ran on 3 pots!! I checked the spark plugs and they all show nice dark brown (not one wet or black). After that checked the compression and found nice equal measurements between 12 and 13 bar each.. Head scratching! Decided to first try other (new) plugs,then a spare set of cables etc.. Will be continued... Thom
Nice to catch up on the your fleet, the high standard you work to is really impressive, Good luck with your job search, you will find something but, until then, use the "extra" time to get your cars as you want them, Nigel
thomfr
Nov 10, 2020 21:42:08 GMT
The Alfa is in good health again! Dodgy (only 2 years old) spark plug cable was the culprit.. Today was a lovely day over here and I went to my parents place where my Volvo Duett lives until I get a permit to built a carport behind my garage. I used the Italian diva for the relaxed 8 Km. drive and pushed the Duett outside for some work. Removed some obsolete filler from the inner fenders and floor and turned myself into a snowman (my hair is grey but not so grey normally...). Thom
Lovely little Alfa, Ive had such an itch for another retro Italian recently. I got to drive one of these about a bit in Germany but it was breathed on a little, great fun.
