1992 nissan 100nx 2.0 twincam 16v 2.0 engine conversion, taken from a primera gt150bhp black top sr20de .Fully stripped, rear cage, front and rear strut braces. Bucket seats, 4 point harnesses,Full stainless straight through exhaust with stainless 4-2-1 tubular manifold. lowered 40mm on uprated springs and shock absorbers. Adjustable fuel pressure regulator.
within the last 12 months, brand new whiteline uprated antiroll bars front and rear with poly bushes Cost £330. Custom drive shafts from GB engineering cost £420.
Brand new tyres - Toyo proxes.
Nissan Almera gti front brakes, with drilled, grooved and vented discs.
stand alone gauges
Probably some other mods that I've missed.
The body work does have a couple of issues, but remember that this car is 30 years old, and is very presentable.
The near side front wheel arch has damage due to my friend driving into it on my drive !!
The off side wing has some small surface rust spots and fading not the top.
there are a couple of rust spots if you look close.
one of the heater control slides has snapped off, still operational, easy fix.
Comes with some spares
Brand new hydraulic handbrake never fitted
Bonnet
Ht leads
original front and rear antiroll bars with bushes
gearbox- has 5th gear issue, popping out, all other gears and sensors perfect.
DizzyRadiator with twin fans
Brake servo and master cylinder
Oil cooler and hoses with brand new sandwich plate
A couple of belts,
A pair of larger calipers suitable for a bigger brake conversion.
original manifold and brand new down pipe.
a couple of gearbox/engine mounts
battery tray
standard fuel pressure regulator
Probably a few other small parts which I've forgotten.
Mot runs out in a couple of months, but will fly through next one, as its only done 2500 miles since last year.Runs perfect, great oil pressure, water temp perfect.
These cars are getting rare now, grab a retro bargain.
Only selling as i don't use it very much.
please ring ( 07923 ) 055 480 for any questions
cash on collection or bank transfer.
NEED GONE ASAP, bought another car
Having trouble uploading photos, please ring or text and i will send them via whatsApp, until i can fix the issue. thanks, have managed to upload a couple, but still struggling.
stand alone gauges
Bonnet
Ht leads
A couple of belts,
battery tray
