Random update today, getting bored of the car making no noise (I mean I don’t want lairy but I’d like a little more theatrics). Decided the only way to do it would be the gentleman’s half kinda induction kit. You’ll see in a minute... Went to see my old gaffa and mate Nath at ND auto repairs in Sheffield for him to tig me up a simple 3” MAF adaptor. He’s got all the tools going and more than you’ll ever need made the job a pleasure (apart from my curse word chatting for a few hours 😂) After that I went to see my mate Andy who’s helped me loads by letting me use his car for mockup after I pester him every week for parts off the UCF10 he’s breaking 😂 bought a broken airbox top him to cut up anyway and got to work with a spare bottom box I had. Got rid of the gasket and locking band, gutted all the inside so the adaptor can sit flush, trimmed the cold side out too and after I’d prepped the surfaces used some tiger seal to bond it and small screws to hold it while it sets. Reason behind the faffing is 1. It acts as a heat shield that fits mint already (already got some of that fancy gold tape if I’m really feeling flush) 2. it retains the massive factory cold air intake and trim on the front of the engine. 3. It saves me another job of starting from scratch with ally. Win win in my eyes. Need to trim a little more out the front when the filter arrives. I’ve also got some nice rubber edging coming in the post to finish the job off properly 🤙🏻 Cheers!
Last Edit: Nov 23, 2020 17:36:46 GMT by louishavo
Nov 24, 2020 15:04:42 GMT
Well if my Microsoft paint picture wasn’t good enough the filter turned up today. Fits bang on, just gotta wait for the edging strip to turn up and ill chuck it all on. Cheers!
Nov 26, 2020 12:29:44 GMT
Last Edit: Nov 26, 2020 12:48:34 GMT by louishavo
Nov 26, 2020 12:34:39 GMT
Neat job that 👍
Nov 26, 2020 12:56:02 GMT
Decided the factory air intake pipe needed rectifying because there’s a big dampener attached to the left hand rocker cover that dampens sound (no good when you’ve just fitted a cone bad lad). Decided to chop the box off to make it easier to replicate 🤙🏻 Then took the plastic pipe to my mate naths and he made me a new pipe (just waiting on some 16mm and 6mm pipe to have the nipples welded on). Made do with one piece of 3” intercooler pipe hence the pie cuts (didn’t wanna be wasteful). Cheers!
Still waiting on some aluminum pipe to finish the intake so decided to get the steering wheel on. Driftworks had a bit of a sale on so decided to cop a HKB sports boss that retains the cruise control (while I’ve still got it) proper nice bit of kit with the little wiring loom. Here’s some pics 🤙🏻 I am learning Japanese but couldn’t make heads or tails of these 😂 Cruise all works nice and is discreet in the car. Lovely job. Cheers!
My ally pipe I’d been waiting for finally turned up today 🤙🏻 So back down to Nath @ ND auto repairs and he finished the job off for me 🙏🏻 this big plastic hunk of thing is what it replaced. A quick video of how it’s sounding now 👌🏻 just need a black piece of silicone for the throttle body now to make it all tidy. cheers!
Dec 10, 2020 23:24:37 GMT
Last Edit: Dec 10, 2020 23:27:13 GMT by louishavo
The Doctor
Club RR Member Number: 48
Why doesn't the cruise work? I believe my mates Soarer one is working after the auto to manual swap (1jz engine though, not sure if it's any different), all we had to do is getting the car to think it's in drive, and make sure we can get it to think it's in park or neutral again to get it to start.
Great car, the manual makes it so much better in my eyes.
Dec 12, 2020 23:31:48 GMT
Why doesn't the cruise work? I believe my mates Soarer one is working after the auto to manual swap (1jz engine though, not sure if it's any different), all we had to do is getting the car to think it's in drive, and make sure we can get it to think it's in park or neutral again to get it to start. Great car, the manual makes it so much better in my eyes. I spoke to Phoenix engine management and he said it wouldn’t work with the manual box because it works with some of the shift solenoids on the autobox itself apparently 🤷🏻♂️ Just going off what I’ve been told it’s abit beyond my pay grade. I don’t know where the cruise gets it signal from 🤷🏻♂️
Dec 12, 2020 23:40:26 GMT
Little bit more progress on the bits I’ve made at home. Tryna preemptive strike little bits that might hold me up when I start the swap on the 28th! Made a little adaptor brake pipe so it’s an easy to get to when the clutch bracket in up in the footwell of the car 👍🏻 Figured it’d be a faff getting a spanner right up and angled in to tighten the union up in the car (Nice little rubber grommet in the hole too I love a faff 😅) Replaced the slave to flexi pipe with a new piece of kurnifer hard pipe Flywheel bolts turned up today too so the only bits I’ll have to make when it’s all in the car is the pipe between the peddle and the flexi slave line and a prop shaft. Hope I’ve prepared enough 😂 Cheers
Dec 12, 2020 23:43:40 GMT
Also went down to my mates Naths again at ND autos and got him to weld some studs onto the clutch bracket. I’ll tidy it up tomorrow and it’ll get the finest sayin black treatment before it goes on. I’ve ordered some stick on foam to cushion the plastic reservoir too 🤙🏻 Cheers
Dec 19, 2020 19:40:55 GMT
Pre manual swap MOT check came and even though the car seemed to drive fine it needed some bits 😅 Both upper arm ball joints were goosed and much to my disappointment they’re a sealed unit so it meant 2 new complete arms (rear bushes were mint too 🙄) Jobbed. Passenger side came and first Wheel bolt decided it didn’t wanna be one with the car any more so another job added on 😬 Trip to lexus morning after and an extortionate £3 later and new bolt was bought and fitted and the drivers side was done (or so I thought 😂) Decided seen as I had to take the caliper/carrier/disc off I’d double check the sliders on the brakes make sure the brake check for the mot would go smooth (😂😂😂) thats a 1/2 ratchet trying to just get some movement out of the sliders. Had to free 3 off with a breaker bar, which resulted in 2 twisted unusable ones by the time I’d dogged them out 🙄 Luckily one of my best mates who lives round the corner has got a JZX100 Toyota mark 2 (1jz gte - factory r154 👌🏻) and they’re the same so back on the road (luckily he had them spare cause he had 360mm ISF discs and Brembos up front now). Next up was rear tyres. Easy peasy two were ordered off the internet and stretched onto my 10j wide rear wheels, got ny fill out of the ones that came out (amount of rear camber doesn’t help). Next up was to replace the crusty rear anti roll bar links. Luckily the company I ordered them from sent me the wrong ones so a trip to Birmingham yesterday morning to swap them was in order 🙄. At the same time we fitted a new lateral bush in the hub as these were worn too for the MOT. I ordered these from PSB and they were easy to chuck in 🤙🏻 I’ve still got the inner bush on the later arm to do that comes with the set (didn’t have time today to do an alignment as it’s a camber bolt to take off) and also poly rear upper control arm bushes to fit at a later date as these are a little tired but not a fail 🤙🏻 On the MOT lane, ready to rock and roll, emissions passed and another check. All passed ✅ took it outside. Let my mate and garage owner/tester do a smokey to celebrate (on my new tyres 😅) andddddd... Front drivers brake pipe just completely burst. Not sure if this happened on the brake rollers or the burnout but I’m actually so happy he did it and it burst there than doing 60 on the parkway on my journey home 🤞🏻🤞🏻Luckily I had some spare (second hand but good enough) rubber ones from my 4 pot calipers, quick journey home in his courtesy car and i was back on the road. The newer brake lines are slightly different but both will be getting replaced for braided lines now after that lucky escape 🙌🏻. Came home and celebrated by washing the car (for it only to rain) and wet vaccing my front floor mats to get rid of all signs of the last few days antics (what a wild life in lockdown). My P clips finally turned up in the post so spent another 5mins tidying the newly made clutch lines up. All just in time for the manual swap between and new year 🤜🏻 Cheers!
Dec 19, 2020 20:49:28 GMT
That little SDi is quick upto 15mph init 😂
Good work, you have a similar amount of luck as me with things breaking.
That little SDi is quick upto 15mph init 😂 Good work, you have a similar amount of luck as me with things breaking. Haha honestly with these string of jobs it seems like it but ifs all sorted and when the rest of the bushes are in it’ll want for nothing for while. I. Actually glad the hose burst with Nath doing a smokey and not on my next journey!
Dec 20, 2020 16:03:47 GMT
Yeah I wouldn't fancy that popping on motorway. Plus you can guilt Nath a bit 😂
He keeps trying to peer me into a smokey but I don't wanna be that guy that hits a crowd 🤣
Dec 20, 2020 18:45:08 GMT
Yeah I wouldn't fancy that popping on motorway. Plus you can guilt Nath a bit 😂 He keeps trying to peer me into a smokey but I don't wanna be that guy that hits a crowd 🤣 haha think you’ll just have to do one to appease him then he’ll not ask again 😂
Dec 20, 2020 18:50:50 GMT
Only a little update tonight. Remembering I’m going to manual swap the car I didn’t have any pressure plate to flywheel bolts. Online says they’re m8x1.25x30 but best check myself. Into the old nut and bolt draw and found some nice m8x20 cap heads that looked up to the job. Clutch, pressure and flywheel bolt together to check and they’ll do the job 🤙🏻 So the internet lied again 🙄 Painted the simple clutch reservoir bracket too and some nice neoprene foam come in the post to I’ll stick that to the inside to cushion the reservoir and it’s done too. Cheers!
Last Edit: Dec 20, 2020 18:52:30 GMT by louishavo
mat88
Yorkshire and The Humber
Dec 20, 2020 19:39:42 GMT
I'm just glad it's all fixed and you can stop flapping now about the whole thing 🤣🤣... If your tyres fit and it wasn't so low maybe your tyres would last longer 🙄🙄🤣🤣🤣
