MR TIKI
TIKI,style from a different angle!
So,a long story in short,this clock was a project started by my Father 20+ years ago not long before he passed away. I don't know much about it other than I recall him having issues with the power supply.I would really like to make it work again,before I switch out the workings for a modern quartz movement can anyone please point me in the right direction or shed some light on what it may need? Regards Bryan. Ps.the insides look like this....
Last Edit: Feb 11, 2020 0:20:17 GMT by MR TIKI
Boldly driving faster than a tin worm can wiggle.
slater
Club RR Member Number: 78
Feb 11, 2020 17:03:13 GMT
don't you dare put a modern quartz unit in it! Sure fire way to ruin a clock!
MR TIKI
Feb 11, 2020 17:16:05 GMT
don't you dare put a modern quartz unit in it! Sure fire way to ruin a clock! like I said,I'm hoping someone can point me in the right direction...I don't even no if it is standard 240 volts before I plug it in.I unboxed it yesterday from storage and after a bit of web browsing I came up with no how to or don't does as far as making it work. hopefully somebody on here can help... Bryan
slater
Feb 12, 2020 16:45:12 GMT
I'm no expert but I have a collection of old clocks I've found places. There are basically two types. Those that run independently off mains power and those than run of a signal from a central 'master clock'. The former are generally as simple as connecting them to mains power. The 'slave clocks' require a pulse from a pulse generator and that needs to be at the right voltage etc. (They do very)
I'm afraid I cant tell you what type you have but I'm leaning towards slave clock from the look of it. don't put any voltage through it until you've had an expert look at it if I were you! I'm pretty sure theres clock forums and what not out there that could help
Seth
Feb 12, 2020 19:14:20 GMT
Having just seen this I'd have said what Slater has, it might well be a slave clock. I'm afraid electronical timekeepers are outside my field of expertise though.
MR TIKI
Feb 12, 2020 23:29:02 GMT
thanks for the input Gents,the idea of it being a 'slave' clock rings a bell now it's been said.that give me something to look for,so fingers crossed.
regards Bryan
Feb 13, 2020 21:19:50 GMT
don't you dare put a modern quartz unit in it! Sure fire way to ruin a clock! What he said! It's a slave clock. I'm 98% certain of that. It's got no second hand so it's probably a half minute loop version. The big (huge) question is whether it's a series or parallel version. You feed it a square wave. On the half minute versions it will advance the minute hand half a minute forwards every time the square wave changes polarity. You see the coil at the bottom - really a solenoid - that should push or pull a 'thing' nearby which actuates the mech. If you can find that 'thing' and push and pull it you should find the second hand goes round. That'll finally confirm it's a slave clock. (But it is!) How good are you at electronics? And how much do you want to know? James PS, Nice clock. Do you know where it's from?
Feb 13, 2020 21:47:00 GMT
In the spirit of sharing... Here is our big slave clock. (By 'ours' I mean it belongs to work and was rescued when we moved building.) It's a second loop version (ticks every second) and, unusually, it seems to be a series one. Which is really annoying. Chloride bought Gent in about 1981 and then sold them again the following year so that nicely dates it. It got to the new building safely and then somebody put it on a high shelf with the face up and some other idiot dropped a box on top smashing the glass and bending the hands. Hopeless people! Here's the mech. I'd never seen it working (it was in a previous control room at the old place and had already been put aside when I joined). The new building doesn't have pulse loops, we went onto timecode data instead. So to see if it worked, and possibly to get it working and back on a wall, I built this. It's an Arduino single chip computer (to do the ticking) with a driver circuit I made to drive the actual clock. As a test thing it proves the clock works and allowed me to dial in the voltages and currents I needed to get it running. But it's not locked to anything so it's uselessly inaccurate. It's much worse than my 150 year old long case clock at home. But it proved it works. I wish I had the time to restore it and get the driver working and locked to something. I have a bad feeling it's just going to kick around at work getting increasingly damaged. (Which I'll be really upset about.) James
MR TIKI
Feb 13, 2020 23:09:24 GMT
don't you dare put a modern quartz unit in it! Sure fire way to ruin a clock! What he said! It's a slave clock. I'm 98% certain of that. It's got no second hand so it's probably a half minute loop version. The big (huge) question is whether it's a series or parallel version. You feed it a square wave. On the half minute versions it will advance the minute hand half a minute forwards every time the square wave changes polarity. You see the coil at the bottom - really a solenoid - that should push or pull a 'thing' nearby which actuates the mech. If you can find that 'thing' and push and pull it you should find the second hand goes round. That'll finally confirm it's a slave clock. (But it is!) How good are you at electronics? And how much do you want to know? James PS, Nice clock. Do you know where it's from? My Father ran a print works in Staines Middlesex from the earlier 60s until 1981.as a child I remember it being on the wall next to a giant type making machine,but I never saw it work.My Father keep it when the business closed in '81 and years later cleaned all the ink and grime off of it,because he didn't know how to get it going it was packed away. As for electronics,I can solder and that's about it.my O level electronics course has long since left my brain.🤔 What you've built there looks very interesting,I guess I'll be needing something similar. Thank you for such an informative response,it's everything I love about RR. Sharing skills and knowledge makes the world go... Bryan
Feb 14, 2020 20:02:01 GMT
Here's some more! From what I remember you normally drive a slave clock from a 50V square wave. Like this... The frequency depends on the clock you are trying to drive. So 'my' clock is on a second loop. Yours doesn't have a second hand and probably will be a half minute loop (ticks every 30 secs) or possibly a 1 minute loop. This 50V thing... Sounds like a lot of volts but I'm pretty sure our system was really 50V. Now yours might be different. Who knows. It'll probably run quite happily on a lot less volts and if I was making something I'd try and run it on less. I'd try and run it on just enough to keep time properly to be honest. It's important to note that it is not a 50 volts on for a period and then off for a period. It actually reverses direction. So for the first period current is running, say, forwards. For the next period current will be running backwards. If you stick a multimeter across the pair of wires you'd see +50V, then -50V, then +50V and so on as it switches. Now... Series and parallel systems. This is series. Each clock has a fairly low resistance coil but the 50V is shared across several clocks. I'm not sure how many clocks or how many volts each coil would see to be honest. The big disadvantage of series systems is that if any clock fails, or you need to remove one, the whole loop breaks. For that reason they weren't very popular. As it happens 'my' clock is a series one. It's a pain in the bum to drive. You'd think I could just run it on say 10V instead of 50V and it'd work. But it didn't seem very happy like that so I'm actually running it on 24V and I have a big dropper resistor that pretends to be another clock. Parallel was more common. Here if you have to take a clock out you only affect that one clock. Each clock should have a much higher resistance coil so it can run on a higher voltage without drawing to much current and burning it out. Again, I couldn't tell you what resistance to expect though. I could measure mine though and compare numbers. Interestingly the wiring on your clock appears to tun through a round thing which looks like a high wattage variable resistor. I've never seen that before but I'd guess it's a way to tweak the current. If yours is a parallel clock I think you may be able to buy a driver off the internet. I think they exist out there. God only knows if they are any good. As mine was a series clock (and therefore a bit odd) I didn't really bother looking and just built something. We had an apprentice at the time so I got them to do a bit of the development before we tied the design down. Ask if you want to know more! Or tell me to shut up - that's fine too! James
Last Edit: Feb 14, 2020 20:03:15 GMT by Sweetpea
MR TIKI
Feb 19, 2020 17:24:55 GMT
James, That's all rather brilliant thank you,It makes sense that my Father stumbled with powering it 20+ years ago.sadly its not something I feel is within my skill set.based on the information you've given I have been able to find a company that produces a driver for it www.electric-clocks.co.uk/.they produce something they call an EC4A which will do the job for around £50,does that sound about right cost wise? sorry for not replying before,I only just got my PC back from hard drive surgery! OUCH! regards Bryan
Last Edit: Feb 19, 2020 17:27:58 GMT by MR TIKI
Feb 19, 2020 21:15:25 GMT
Bryan, Probably, yes! First of all, having looked through his site, it looks like there is another way of driving slave clocks that I wasn't aware of. And it's probably more common that the way I was familiar with. I said that it was a square wave and it reversed polarity (current went forwards and then backwards.). Well it looks like this new way is a string of short pulses. Like this... So every 30 secs or a minute you get a short pulse. He also seems to be using a lower voltage than I managed with our big clock. I did say our clock was odd. Here's what I'd recommend you do. Do you have a multimeter? If so you need to measure the resistance of the coil - and of that strange round thing that I think is a variable resistor. You also need to find if the thing works and if it's a 30 second or 1 minute mech. To do that, the coil will move a lever near by. If you can find that lever and move it the clock should advance by either half a minute or one minute. Then... I'd take some close up photos of the mech and contact the chap. Send him the photos and the coil resistance and see what he says. He's evidently played with a lot more clocks than me! Again, if I can be of more help please let me know. Good luck, I hope you get it working 'cos there is something magical about seeing an old slave clock ticking again. I'd love to see a video of it running if you get it going. James PS, Cost wise, who knows. In reality it's s lot of money for a few bits. But what you are really paying for is his expertise and development time. And that's fair enough. At the end of the day it doesn't matter what it cost so much as what you are prepared to pay to see it going again. And like I say, there is something magical about seeing an old clock running again. Certainly when I got ours going I just stood and grinned at it for about 5 mins. I reserve the right to be a bit strange...
Last Edit: Feb 19, 2020 21:19:52 GMT by Sweetpea
MR TIKI
Feb 19, 2020 23:44:58 GMT
I reserve the right to be a bit strange... You are in good company! I'll be sure to let you know how it plans out. thanks again Bryan.
Colin
Feb 23, 2020 12:07:33 GMT
Hello, I I have a clock repair and restoration business, send us a message over on Facebook and I'll send you in the direction of a website that sells battery driven control units for converting slave clocks. Www.Facebook.com/ClockRepairAndRestoration Colin
