145SR15, 145R15 legal/good tread OR would go to an 80 profile so 145/80R15 if we have a matched pair. £450 for a brand new set is just too much. Let me know if you have anything, on a rim or not(!)
"A Pierburg carb? It would be more economical to replace it with a funnel..."
145SR15 ish tyres fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
I thought if the profile was excluded i.e. 145R15 Then it meant 80 profile any way?
So 145R15 = 145/80/15
Not sure if that helps your search or not.
Feb 10, 2020 10:35:26 GMT
I thought if the profile was excluded i.e. 145R15 Then it meant 80 profile any way? So 145R15 = 145/80/15 Not sure if that helps your search or not. the standard profile is 82 rather than 80, not a lot but it's still a bit smaller. I ended up ordering some as the links sent up there were equivalent cost to ebay part-worns. cheers all
@freshandminty
Feb 10, 2020 11:14:21 GMT
I thought if the profile was excluded i.e. 145R15 Then it meant 80 profile any way? So 145R15 = 145/80/15 Not sure if that helps your search or not. the standard profile is 82 rather than 80, not a lot but it's still a bit smaller. I ended up ordering some as the links sent up there were equivalent cost to ebay part-worns. cheers all thanks for that info.
