Phil H
Club RR Member Number: 133
MOT Q - Warning messagesPhil H
@philhoward
Club Retro Rides Member 133
This is another one of those things that really annoys me on moderns One fault showing can be only vicariously connected to the actual problem š” Iām sure itās done to make you spend your money at the dealership āTake me to your dealer - bring deeds to houseā..
This is another one of those things that really annoys me on moderns One fault showing can be only vicariously connected to the actual problem š” Iām sure itās done to make you spend your money at the dealership āTake me to your dealer - bring deeds to houseā.. Oh yes Phil, aināt that the truth!
Jem45
Do you know if the Haldex unit has ever had an oil and filter service in its life? May possibly be a good start It's had a couple. I wouldn't expect dirty fluids to stop the rear diff 'communicating' with the ECM in any case would you? I'm thinking I may have snapped a wire when I was cutting the old anti roll bar off.
Carbs 'n chrome
Phil H
@philhoward
Donāt older Haldex controllers have a habit of self-expiring? ATP or the likes repair/remanufactured them from memory of my time reading about VAG stuff of the same era.
Jem45
This is another one of those things that really annoys me on moderns One fault showing can be only vicariously connected to the actual problem š” Iām sure itās done to make you spend your money at the dealership According to the man with diagnostic kit from the owners club, Anti Skid Service message can be linked to (amongst other esoteric things): Traction Control Abs System/ Reluctor rings brake pressure sensors Steering Sensor/ Yaw sensor Rear Diff (on 4x4 models) Stability Control Front Driveshaft bolts So it is a bit random for sure but if you've got the right kit, very helpful.
Carbs 'n chrome
Jem45
Donāt older Haldex controllers have a habit of self-expiring? ATP or the likes repair/remanufactured them from memory of my time reading about VAG stuff of the same era. Yup. And TBH that wouldn't be a particular inconvenience to me right now. Unlike the fault code it's causing.
Carbs 'n chrome
MOT Q - Warning messagesChasR
@chasr
Club Retro Rides Member 170
I'd be tempted to say sick some tape on the dashboard .
Jem45
I'd be tempted to say sick some tape on the dashboard . Chas I'm disappointed in you. That's the sort of crappy thing I'd do but from a man who is the custodian of an M3, frankly, that's poor
Carbs 'n chrome
@chasr
Damn, you saw through my tongue in cheek comment!
I had to try and ease the solution somehow!
