Hi, all. I haven't been on here in quite some time but thought I'd show you my most recent project.
83 635csi
Original m30 bottom end (178k)
Rebuilt b35 head
Mls hg
Arp studs
70mm throttle body (now on p/s)
Nuke Performance fpr, bov and fuel rail
TurboSmart progate 50
Bosch 440cc injectors
Modified TCD cast iron log manifold
Walbro 255 lift and Bosch 023 fuel pumps
Emerald K3 ecu
Custom engine loom
3" exhaust and 2" wastegate dump, routed through side exit Powerflow silencer
E39 v8 engine mounts
K64 twin plate clutch
Adjustable arbs
E34 540i brakes with Ferodo DS2500 pads
E34 Vacuum servo conversion
BC coilovers
Strut braces front and rear
Racing diffs 4 clutch LSD
Toyo R888R 235 45 17 track tyres
245 45 16 225 50 16 road tyres
My friend and I built the car over the last year, I have a track day to test everything and then will be fitting a 6 point cage and changing the FDR to a 3.25:1. Will be changing to 245 45 16 R888R's for track too
<a href="https://thumbsnap.com/eGUiIA7r" title="Image Hosted by ThumbSnap"><img src="https://thumbsnap.com/s/eGUiIA7r.jpg" alt="Free Photo Sharing by ThumbSnap" /></a>
83 635csi
Rebuilt b35 head
Mls hg
Arp studs
Emerald K3 ecu
Custom engine loom
Adjustable arbs
BC coilovers
