mylittletony
Club RR Member Number: 84
1957 Ford Fairlane mylittletony
@mylittletony
Club Retro Rides Member 84
It's an auto, overdrive one with a fairly lazy 3:1 back axle.
I should make clear I was looking at cams that produce power from idle to ~4500/5000rpm, nothing fire breathing or too compromising of low down torque, just something unconstrained by emissions and a little freer revving than 3000rpm! The factory cam is obviously extremely conservative
But, it's all academic for now, I'm going to follow the sage words and enjoy as is.
mylittletony
@mylittletony
Apr 17, 2022 18:47:20 GMT
In this installment, I'll be covering several pi$$y little jobs that have managed to be squeezed in between kids Easter holiday and a 5 year old's birthday party, and Easter family stuff. The car got raised on one side so I could check the speedo output existed in the AOD. The hole was present, but with a blanking plate screwed on. Most things on the web said that even after they stopped drilling the casing the teeth were still on the output shaft. Should be either 7 or 8 teeth. So I ordered a cable, a set of gears of different ratios to play around with and a couple of the circlips. They got delivered to my company's US office this week, and one of my colleagues was sweet talked into bringing stuff back for me next week I then fought with the door locks. The original locks came with the car, but no keys. I found a genuine lockset for cheap AGES ago, the boot one was fitted by Dez. Had to swap the little 2 pin mechanism across and then insert in the hole in the door Except I couldn't get the retainer spring engaged... I had 2 which were ever so slightly different, so I tried the other and it went in - result! Except then I couldn't do the passenger side So I whipped the driver's one out and did a proper side by side Seems that subtle bend in the one in the foreground was the reason that one fitted and the other didn't, so I tweaked the background one and now I have 2 fitted, functional door locks, and more importantly no holes in the front doors!! Side trims going on soon, some different headlights on order and attempting to maintain momentum before RRW which feels very close.
mylittletony
@mylittletony
Oh yeah, and I removed a kink from the heater valve cable and oiled it while it was disconnected. Can now adjust the previously freed off valve from inside the car which is nice!
The heater matrix also seems dry and was generating heated air in the car during the last outing
1957 Ford Fairlane glenanderson
@glenanderson
Club Retro Rides Member 64
Apr 29, 2022 17:06:33 GMT
I remeber getting Bryan & Son to recore the radiator for my Reliant over 30 years ago. Good to hear they're still going strong.
mylittletony
@mylittletony
May 19, 2022 10:57:21 GMT
ah, where was I? I've been working my way through various Weekender prep jobs. The list felt short, but it's turned into a bit of a slog... I had mounted the rear speakers in my little DIY shelf so needed to implement my plan to hide them. Here's a pic of an infill piece to level with the seatbelt mount plates Then I trimmed the original (yes, 65 year old fibreboard) parcel shelf to help it fit a bit more easily I skipped a step here, where I cut out holes for the speakers and also slots for the belts. I then glued the same vinyl as the dash over it;- while digging out the roll of material I stumbled across the piece I cut for it several months ago when I cut the dash piece - winner!! I had planned to punch holes above the speakers, I decided to attempt a custom/kustom shape rather than a plain circle. I chose a fleur-de-lys which gives a nod to the French origins too Yep - I'm pleased with that! Both shapes punched out and fitted And also with the ebay special seat belt guides. I needed to remove the rear seat to fit this properly, this is now done and I need to fit the guides properly. A bunch of stuff got delivered to my company's US office and then carried here by a colleague, including new speedo cable, gears and clips! I used an online calculator to pick the 17t gear, that's now fitted but I've yet to drive it! I've got 15, 16, 18 & 19 to try if it's off, but I need to experiment This turned into a fairly loooong job, removing the cluster, unbolting the floor pass through plate and considerable swearing & sweating. However, the added bonus was it allowed me to re-attach the heater control panel to the dash, and fit a couple of AWOL dash bulbs while I was in there. I had booked it in to a garage next to my work for a rear wheel bearing, which they didn't get round to , and it rained all day so I got to find out how leaky it is. The other side was the same... Could be coming in from a number of places really, but it's not that bad - the car lives in the garage normally so I'll try and deal with that another time. I didn't check the boot either I also found out on the drive home that my wipers definitely do not work after all, I think an electric motor conversion is in my imminent future. The next item on the list was "refit trim" - couple of hours in my head, oh how wrong I was!! This piece alone took me several hours of jiggery, pokery, clip trimming and basically working out how to access the stud on the top edge. Extra long extension, routed up through the window mechanism, while lying on the floor and squinting to spot the nut. Loads of bruises, scratches and a good dose of 60yr old grease all over my arms... The good news is the other side went on a lot quicker once I knew what I was doing. All 4 pieces are now fitted, the rear screen trim is still to be fitted. Even better, my wife is pleased!! She's been bugging me to fit the trims for AGES I've also replaced the OG front belts with some modern ones. I plumped for green ones for a laugh - they're a bit obnoxious tbh, but should offer a tiny bit more safety than the frayed friction buckle ones. I needed to nip up the heater valve as it was bubbling after a long drive, but it seems to be water tight (except the various bits of rain water that keep leaking out! ) Jobs for this evening include - Fitting boot badge, fitting rear screen trim, fitting and testing the stereo. It needs a damn good clean, including removing some overspray. I doubt I'll have time for anything more than that though... Come say hi on the weekend!
May 19, 2022 19:53:24 GMT
Love this build, such a great looking car.
The fluer du Elises (elisi?) Look really good. Very clever idea that.
1972 viva 'Sparky'
mylittletony
@mylittletony
May 25, 2022 14:03:34 GMT
Blimey! What a weekend!! After a rather hectic week attaching trim and general finding bits I'd carefully stored in the garage it was Friday. It proper chucked it down all morning so I was holding off until the afternoon. Some rushed packing ensued and finally after finding my crash helmet in the loft, I was off - filling her up and meeting EmDee and Krimbo en route for a convoy. First time on the motorway, everything was gravy. Happy cruising at 65mph, rear bearing noise and a growing wheel vibration made anything faster a bit uncomfortable, but 70-75mph wouldn't be a problem. After a largely uneventful drive we were there. I had intended to fit door cards and switch headlights in the campsite, but ended up chatting and consuming various alcoholic beverages instead... I had to be up early to get over to the paddock Looking out of place!! To quote my wife "Your car looks way older than the rest"... Noise test (88db) and drivers' briefing done, stickers applied, nervous constitutional complete and I was all set It was flipping awesome!! The car performed great, felt quick, although I'm certain didn't look it. I only clipped (/smashed) one cone on the extra chicane and was definitely testing the tyres and handling, as well as EmDee 's passenger tolerance. Even better, the family arrived at the Shell building corner and I was the 4th car to come past on my first lap - perfect! I discovered I had a bit of axle float which resulted in a scrubbed white band on my right rear tyre, but otherwise no nasty after effects. Parked up for the afternoon and thoroughly enjoyed the rest of the day & evening Huge thanks to bstardchild for accommodating my request to run later so my boys could watch Sunday morning I shuffled over to our club stand next to the gate Ended up leaving around lunchtime as I was knackered and wanted to get back to the family. On my way it started to misbehave, particularly pulling away from a stand-still... This got progressively worse, so I found somewhere to pull over and check the fluid. The dipstick is basically useless, and wasn't showing anything so I poured in about 500ml extra. This didn't seem to help much so I pulled over again and added a further litre or so I managed to limp home but it doesn't seem very good. It did reverse onto the drive and get in the garage but I've not touched it since... Most info I can find suggests that a strong reverse but slipping drive points to a worn out clutch/band which means a rebuild - for a couple of grand... If that's the case I may not be able to afford it this year
1957 Ford Fairlane HARDCORE
@hardcore
Club Retro Rides Member 190
May 25, 2022 15:19:34 GMT
Awesome weekend man. Hope the autobox can be serviced back to life!
Paul Y
May 25, 2022 15:23:45 GMT
Tony, Missed what engine you have in your superb land yacht. As a temporary measure would it not be more cost effect to throw a known good box in there so at least you can enjoy over the summer? Might be able to help if I know what I have to look for in the shed of doom. P.
mylittletony
@mylittletony
May 25, 2022 15:37:53 GMT
Tony, Missed what engine you have in your superb land yacht. As a temporary measure would it not be more cost effect to throw a known good box in there so at least you can enjoy over the summer? Might be able to help if I know what I have to look for in the shed of doom. P. Hi Paul Thanks for the kind words, it's fitted with a 351W and AOD (non-ecu version) I am enquiring after 'good' 2nd hand boxes too, but this was a 'very good' one!! Although cheap enough to take a punt on, which I did and I've enjoyed it so far Thanks for looking though - all options are on the table! I've even looked at a manual swap, but it wouldn't really suit the car...
@hardcore
May 25, 2022 15:41:28 GMT
Missed what engine you have in your superb land yacht 351 Windsor I believe EDIT: Toooooo sloooooow (although correct, which is something..)
Last Edit: May 25, 2022 15:42:25 GMT by HARDCORE
1957 Ford Fairlane Mercdan68
@forddan68
Club Retro Rides Member 68
May 25, 2022 17:36:27 GMT
Saw this at the weekend Wonderful motor , a thing of dreams for me
Paul Y
May 25, 2022 19:42:54 GMT
Let me have look in the shed of doom, there was a AOD off a 5.0 tucked in there somewhere. Is the bolt pattern the same as a Windsor? P.
May 25, 2022 19:52:35 GMT
Love the speakers in the parcel shelf there. Great looking car
mylittletony
@mylittletony
May 25, 2022 20:47:27 GMT
Love the speakers in the parcel shelf there. Great looking car Cheers Akku! Let me have look in the shed of doom, there was a AOD off a 5.0 tucked in there somewhere. Is the bolt pattern the same as a Windsor? P. It is a windsor, I'm pretty sure the bolt pattern is the same across the models. I'd be VERY interested to hear more
Paul Y
May 25, 2022 21:39:40 GMT
Out of the country until Friday so will have a look when I get back. P.
Ah man, those photos are amazing, what an experience to get to blast round Goodwood! I had no idea this was part of the weekender, realllly want to get down for it now!
With your gearbox, did you try manually shifting to 1st and see how it drives then?
Mine doesn't commence from a standstill in Drive (probably due to worn out clutches) but shifting manually in to 1st it pulls away nice and hard!
mylittletony
@mylittletony
Ah man, those photos are amazing, what an experience to get to blast round Goodwood! I had no idea this was part of the weekender, realllly want to get down for it now! With your gearbox, did you try manually shifting to 1st and see how it drives then? Mine doesn't commence from a standstill in Drive (probably due to worn out clutches) but shifting manually in to 1st it pulls away nice and hard! Yeah, I was super nervous about taking it on track - but it was so worthwhile! On one of the laps, one of the WW11 planes took off as we were coming up on the tower, such an incredible moment! I've not tried manually shifting it yet, I only have one position below OD due to the column shift, but I'll try it today, planning a test drive up and down the road to see how it behaves today.
Ahh that sounds absolutely magic. That's going on my list of things I need to do immediately!
Fingers crossed for the test drive!
