60six
Feb 18, 2020 17:44:55 GMT
For a one off job though, there's a lot to be said for just hiring a decent machine in to get it done, a disc cutter and big breaker would be under £50 for the day i'd have thought. No, that's against heavyspanners rules - It *MUST* be as cheap as possible, and be some random chinese make like 'Huakwanawakhoe' or similar - So far all his dirt cheap tools have done a fantastic job - this trend must continue. The fence part had me in tears of laughter - and now I check every damn fence I see subconciously, same as when someone points out a face in some random object - I can never unsee it now. culpable fence-negligence. My new favorite thing!
Last Edit: Feb 18, 2020 18:00:15 GMT by 60six
ChrisT
Club RR Member Number: 225
Feb 18, 2020 20:54:40 GMT
That cut down door is shocking, the piece riveted on should be inside the door with the bottom of the leaves left longer, folded round and welded to it. Not the quickest job to do but looks a lot better.
I would be tempted to at least try refitting the infill panel inside the door as it does look like a water trap.
As well as insulation in it there should be at least a couple of strengthening ribs running the length of the door, the bottom of these will need cutting back so the panel can fit in.
And the threshold is normally welded or bolted on, not supplied separate.
Last Edit: Feb 18, 2020 20:58:29 GMT by ChrisT
Feb 19, 2020 16:26:26 GMT
It is, a quad headlamp Phase 1 9 Turbo (front left), the white one is a R21 Turbo Quadra.
Last Edit: Feb 19, 2020 16:27:28 GMT by DaveL485
rust[ruhst] noun Also called iron rust. The red or orange coating that forms on the surface of French cars when exposed to air and moisture, consisting chiefly of ferric hydroxide and ferric oxide formed by oxidation. any film or coating on metal caused by oxidation. verb (used without object) to become or grow rusty, as iron. to contract rust. to own a rusty Renault.
bricol
I had first iteration of an R11 - still probably my favourite car, although time probably installs rose-tinted glasses. A turbo, especially after Mr Ragnotti's exploits in rallies, was an as yet unrequited desire.
Hello all. First post here on Retro-Rides. Mostly over on the Volvo Owners Cub Forum but registered here awhile back on recommendation from another member.
Since receiving a generic email from RR a week or so ago I've been reading through this thread with interest. I have to say, Heavyspanners, I admire your approach and skill set...that includes the comedic value. If the first 16 pages are anything to go by we're in for a real treat.
Agree with the others with regards to a cheapy 9" grinder and similar cheapish diamond discs. You'll surely use the 9" again throughout the build and save the 4 1/2" for lighter/overhead work when needed. If you plan on cutting another doorway something like a Cut-n-Break type saw would make light work of both jobs. They're crazy money so maybe a local hire shop as recommended. Would you believe it, driving along today, caught myself fence spotting and... (in my best Victor Meldrew impression) ...spars on the bl**dy inside!
Last Edit: Feb 20, 2020 7:39:14 GMT by Baffler
Liam... '96 854 TDI SE, '99 V70 2.5D S, '05 C70 2.0T Collection, '05 S80 2.0T SE
Feb 20, 2020 19:10:38 GMT
If you do get a 9" angry grinder, please be careful. They are dangerous, my roofer was in the Makita safety manual as an example as to why you don't take the gaurd off (cut from his wrist to shoulder, skipping major arterys! Sliced his bicep down the middle!). Mate had same thing but a bit less severe.
jamesd1972
Club RR Member Number: 40
Feb 20, 2020 19:24:06 GMT
And hold on like grim death ! As with most nasty machines being confident and holding onto the bloody thing are key to a successful outcome ! How’s the Landy ? Working brakes etc now? James
Feb 20, 2020 20:55:28 GMT
If you do get a 9" angry grinder, please be careful. They are dangerous, my roofer was in the Makita safety manual as an example as to why you don't take the gaurd off (cut from his wrist to shoulder, skipping major arterys! Sliced his bicep down the middle!). Mate had same thing but a bit less severe. I might be guilty of using a 4"one without the guard from time to time but my 9" one is pretty scary, if your not holding on tight just turning it on will rip it out of your hand, definitely need to hold on tight and always use the guard. That said it's been incredibly usefull over the years.
Last Edit: Feb 20, 2020 20:55:49 GMT by kevins
Feb 20, 2020 21:50:45 GMT
9" you lightweights, get on a wild 12" stone cutter and hang on for thrills and giggles as it tries to tell you where it's going
Feb 20, 2020 22:10:06 GMT
9" you lightweights, get on a wild 12" stone cutter and hang on for thrills and giggles as it tries to tell you where it's going For maximum giggles make sure it is petrol and use it indoors in a sealed room to stop the dust spreading.....
Feb 21, 2020 14:01:34 GMT
I would not go anywhere near cutting dry with a 9" grinder - the dust is unbelievable.
I rented one of these And extended the windows so the house looked less like a prison! It was quick, easy and with a water supply hooked up clean - even cutting from the inside. Fab thread!
Last Edit: Feb 21, 2020 14:05:54 GMT by wightfug
Wilk
Feb 21, 2020 19:50:14 GMT
Why you wear safety glasses even for the smallest of jobs
Last Edit: Feb 21, 2020 19:51:00 GMT by Wilk
Feb 21, 2020 20:24:34 GMT
Why you wear safety glasses even for the smallest of jobs I have a fairly relaxed attitude to my personal safety some of the time but am always very careful about my eyes. Not happy currently - am working away from home and brought a decent pair of tinted safety glasses to double up as safety gear and also beach/watersports shades. Peeled an orange from the garden last week and its sprayed a few drops onto the lens - I now have tinted lenses with a retro tye-dye pattern
Feb 21, 2020 21:36:21 GMT
I'm pretty deaf and my eyesight isn't great so now always wear safety glasses and ear defenders even if only drilling or grinding for 30 seconds.
Being young you think loud tools/music/cars can't harm you, but it all takes its toll. Anyone for tinnitus?
Feb 21, 2020 22:50:23 GMT
Ehh did you say something ? Can't hear properly since Motorhead at the Hammersmith Odeon , 1981.
Wilk
Feb 21, 2020 23:19:18 GMT
I was a little flippant with eye wear doing small quick jobs until my son came home from work with the glasses in the picture above.... and a cut to his eye brow. Seconds before he’d been grinding and flipped those glasses down off his head for the disc to then shatter milliseconds later Now I always reach for either the goggles or glasses even on the small tasks
eternaloptimist
Being young you think loud tools/music/cars can't harm you, but it all takes its toll. Anyone for tinnitus? There are many, many times I regret not wearing ear defenders. Wish the screaming in my ear would stop. Anyhow, great thread. Very envious!
The other thing to check is the discs themselves. They should be stored in a stable temperature and according to industry training the discs should be removed from the machine and hung or case stored, they never are! There will be a date stamped on the shiny bit the machine spindle goes through and only use the correct type of disc for the job. old or abused discs can shatter when the bonding resin gets over age or the disc is used improperly such as twisting a cutting disc etc.
Great work, i'm watching with interest
Feb 22, 2020 23:08:22 GMT
Yeah, another tinnitus sufferer here
And another. Heavy fabrication in the late 70's/ early 80's.
