one last chance for my fiat before i goes for space, sat for 7-8 months now still runs and drives, dead 3rd gear syncro, alternator low charge state, no mot, rear bumper broken, front bonnet and wing dented +indicator (have new replacements +paint here) propshaft centre bearing bottomed outbut straightened
located Telford West mids
My cinq for breaking over christmas, will be chopped up and binned
Engine package, everything on the engine, all piping all wiring ecu etc and everything to run in minus the fuel pump and fuel lines new clutch and flywheel and serviced 500 miles ago £2500obo shes had some stick and always been reliable
AWD conversion complete rear suspension complete inc disc conversion 4 shortened/sleeved shafts, propshaft and mount, gearbox HAS A DEAD 3RD GEAR SYNCRO and front driveshafts +mounts, gear selector and new gear cables and other minor related items £1500 obo
Fuel system 50L half foam fillet tank boot mounted torques UK 044 pump and billet mount and fuel filter all -8 AN black fittings and braided lines and soild under car lines£450obo
black dash interior plastics £100
GT3 front brakes £140ono
rebuilt quick rack £70 ono
OMP upper strut brace looks tatty £60ono
front coilovers TA techs all tabs move £130
front wishbones poly bushed £60
ARB outers poly bushed inner brackets included for cars without £40
Have a set of rare 14x6J steel wheels £60
in Last 500 miles had a new selector unit and gear cables, serviced,rear springs, rear caliper and handbrake cable along with a brand new TTV superlight billet flywheel and a custom clutch.
I can sell as a running gear or engine package units complete so they can be fitted and used in your own centos
Engine .2010 500 abarth tjet on 12,000 miles .Tjet inlet with new bosch 625cc injectors .1.6 cable throttle body with custom adaptor plate . brand new superlight TTV racing billet flywheel and clutchfix custom unsprung 3 puk clutch .custom 304 stainless log manifold and recon'd turbo technics custom T25 hybrid turbo .mocal OTSB1 oil sandwich plate and ATS 13 row narrow oil cooler .custom braided water pipes hoses for turbo and oil cooler . custom intercooler and silicone hoses .MS2 ecu professionally installed and mapped by bailey performance has around 14 hours worth of mapping now .MSD gen 2 coilpack on custom bracket and 8mm silicone HT leads .silicone coolant hoses . all engine mounts sand blasted and powdercoated then new bushes with poly inserts .billet one off brooky oil cap could do with a polish (just for dan)
running gear .panda 4x4 gearbox .panda rear diff mounted on custom setup uses oem bolt holes all sand blasted and painted then sealed .4 custom sleeved driveshafts and shortened propshaft, all .new oem rear arms machined with custom billet hubs .internal panda short shifter with brand new cables .custom gearbox mount .steering rack rebuilt last year
misc .battery relocated in boot with new wiring front to back .50L foam filled fuel tank in boot .complete torques uk fuel system, 044 external fuel pump with billet fuel filter and mountings .black AN fittings on all fuel hoses both flexis and solid pipes front to rear .custom alloy oil catch can with silicone hoses .
10mm spacers on the front and 16mm on the rear all hubcentrics
£4000 whole before parting out
Ash
Ash
