lmr
Mar 30, 2021 20:34:05 GMT
My car continued to run really well, but over the last few months it was beginning to leak oil. I was due to change the oil so I decided to change the sump gasket at the same time. Apparently it is worth checking the sump as these engines have plastic cam chain guides which if they are beginning to wear they deposit lumps of plastic into the sump. The sump is easy to remove, just a series of bolts Taking the sump off was good news. No plastic pieces So a new oil level sensor seal and sump gasket fitted, and now the leak is sorted There are some more jobs to do, but I am mobile again
Last Edit: Mar 30, 2021 20:35:05 GMT by lmr
Mar 30, 2021 22:02:18 GMT
great to see it getting some love. my v8 e38 had 287k on it and still ran fine, so there's years of life left in this if you keep the rust at bay. Looks like my front jacking points have also turned to weetabix, so more fun with the grinder ahead
Mar 30, 2021 22:29:29 GMT
Love this car, makes me want sack off my e61 530d and get one like yours......must resist! Glad its still giving good service to you!
lmr
Oct 12, 2021 20:47:00 GMT
Is it really 6 months since my last update where I wrote there are more jobs to do? My levels of prevarication are getting worse. The truth is I had a number of areas I wanted to address, but I kept putting them off. What was getting annoying was the obvious leak in the rear suspension. Whilst I admire people who run very low cars, it isn't my thing. The leaking suspension wasn't really an immediate problem, as it inflated immediately when I started the car up. What was becoming more of a concern was the flickering of the alternator light. It would come on at random times, infrequently at first, but then more regularly. When I last changed the alternator drive belt, I found the tensioner was worn, so I started by changing that. The occasional belt squeal disappeared, but I was getting a charging light more regularly. I was due in German a couple of days after changing that, so drove from the midlands to Stansted Airport, and promised I would carry out further investigation when I got home. On my return journey from Stansted, the alternator decided to stop charging. As it was late at night and I had no tools, I booked myself into a hotel, abandoned the car there, and got the train home the next day, with a friend recovering the car a day later. So the sensible thing would be to buy and alternator, throw it back into the car and get going? As I said six months ago, there are other jobs to do. So, the car now looks like this Some people call it mission creep. I look at it as if one of my cars needs work, try and do an much as I can in one hit. The to do list was getting pretty long. Rear wheel bearings are rumbling. I changed some of the front suspension joints a couple of years ago and recall the dampers were limp. Last year's MOT highlighted some play in the rear suspension. The CCV on the rear of the engine is leaking. So I wrote a list and ordered lots of parts. Rather than replace the alternator, I have ordered a new regulator and bearings. A replacement alternator is the thick end of £500 (this engine has a water cooled version). The know weak point on these alternators is a plastic sleeve the base of the alternator. Mine had definitely seen better days Thankfully I managed to source a replacement. The parts total for the alternator is £55. Hopefully this will be successful. I will also be replacing the following front and rear dampers (Bilstein B4) Front springs (Eibach) Rear airbags (Genuine BMW) a tad more expensive but they were kind enough to give me a trade discount rear arms and ball joints rear wheel bearings and hub carriers CCV valve I will also do a full service, gearbox oil change, fresh antifreeze and anything else that needs addressing To date, I have sorted the front damper and spring replacement I have also stripped the rear suspension. separating the driveshaft from the wheel bearings needs a very good puller This bearing is the better of the two, but has definitely earned its retirement The rear suspension components didn't look too terrible in position, but are clearly knackered when inspected more closely Hopefully another weekend will see this back on the road, unless I find other items to replace
aero
Oct 12, 2021 21:12:48 GMT
Great car, I recently owned an e38 with the same engine. The alternator went on mine and bmw quoted 800 quid for a new one! Luckily there’s a guy who sends you a recon unit for £144 on eBay: alternator guy I think he’s called: great service. Pig of a job as you say to replace when you add in all the cooling pipes (£500) from BMW and the belts and pulleys. It took me 2 days, but if I ever do it again it will be much quicker. Great thread, thanks for updating. Here’s the old girl with my brother’s 530
75swb
Beta Tester
Club RR Member Number: 181
BMW E39 540 Touring75swb
@75swb
Club Retro Rides Member 181
Oct 12, 2021 23:41:23 GMT
The best kind of scope creep! Will be in great shape once that lot's finished. What's with the silver front bumper BTW?
I did the crank case ventilation job on a v8 before (740i). It's a very satisfying job and not too difficult. I read at the time that it increases throttle response and maybe it was confirmation bias or maybe it wasn't but afterwards it did feel happier from a standing start, less lethargic.
lmr
Oct 15, 2021 16:13:11 GMT
The best kind of scope creep! Will be in great shape once that lot's finished. What's with the silver front bumper BTW? I came back to the car one evening, and someone had hit the car, cracking the original bumper. It is sat in the corner waiting patiently to be repaired. Another job to add to the list.
bazzateer
Imping along sans Vogue
Oct 15, 2021 19:32:25 GMT
Gotta love a 5 series estate. In the best manual variety too.
lmr
Oct 26, 2021 17:52:04 GMT
So, another weekend passed and progress has been made. Whilst it wasn't actually necessary to remove the driveshaft from the car, as I was this far in, I figured I might as well so that I could inspect the driveshaft boots. This was a relatively easy job, until one of the bolt heads sheared off. To protect the shaft I masked it off, then got busy with a cutting disk and die grinder, which got me to this A stud extractor finished the task Reassembly is ongoing I find it amazing how many tools are required. This photo was taken after a tidy up...... For a change of scene, by which I mean I was fed up of lying on the floor, I tackled the CCV valve The inside wasn't as bad as I expected. It is a simple, albeit fiddly job, but went back together fairly easily. I used a new gasket too, hopefully making this repair last a long time Final job of the weekend was to address the surface rust I found when removing the cover from the shock absorber cover. They cleaned up nicely rust converter, etch primer and metal paint to follow.
lmr
Another weekend of progress. between other jobs I have applied several coats of metal paint to the area around the shock absorber cover I tested the cooling system by filling with water rather than risk wasting antifreeze. I am very glad I did. I have previously had an occasional small weep from one of the temperature sensors. It never dripped but a hint of moisture. Removal and refitting of the sensor resulted in a drip. The sensor has an o ring on it which was perished. It seems BMW do not list a separate part number, so I measured the o ring and ordered one. Another of the "whilst your at it" jobs was the windscreen surround, The existing one was ropey The new one looks better I went through the car and did a bolt check on everything I had replaced, got it off its axle stands, bled the cooling system with antifreeze and started it up.it was so lovely to hear it run after a few weeks.
lmr
Of course, at this point the obvious thing was to open the workshop door and go for a spin. I was keen to get the car back on the road as this is my daily drive, and I knew the MOT was coming up. I did a check on MOT status, and it had expired. So the much anticipated test drive was deferred until I could get the car booked in. Yesterday, the car passed the MOT without drama.
I'm very pleased to confirm the alternator rebuild has been successful. The new suspension components make the car feel more solid, but I think a 4 wheel alignment is now needed. The CCV valve replacement has made the most obvious impact. Tickover is now stable, throttle response is definitely improved, and emissions have improved too. I am really looking forward to getting some more miles on this, and hopefully it won't need spanners laying on it for a while
v8ian
Just remembered my e39 tourer sprung a water leak, took weeks to find, it turned out to be there rear heater pipes that go up the prop tunnel for the rear heater corroded.
🇿🇼Kingludba🇬🇧
If in doubt... flat out !
Nice work on keeping it going. They don't build them like this anymore.
`99 BMW 528i auto - current `01 Merc C320 - Gone `01 Forester S-Turbo - Sold `89 BMW 320i Convertible - Sold(shoulda kept it ) `88 Toyota MR2 T-Bar - Sold `89 BMW 325i touring - Sold `89 BMW 535i - Let her go too early `85 BMW 320i 2 door - Rust = character `00 Subaru Impreza Turbo wagon - Sold (engine failure) `93 BMW 325i - Sold
