So another long overdue job done after work last night was to fit the Dentists lamp in the carport for inspection of engines and other detailed items when you need a super light source. Thanks to Paul “Oblertone” who brought it up to me and left it with his daughter in Essex to collect a few weeks ago. So I prepared two 100mm x 50mm pieces of wood to fit between the roof beams, and painted and screwed them together. Then found my 65mm drill bit (call it what you want) to drill a hole through for the adjustable hanging post to go through, as well as the wiring from the lamp to mains. One of those purchases made years ago from a member on UKGSER who needed to move it on. At £80.00 it was and is a bargain. My other 1950’s drillpress has ceased to function, tripping the power when you turn it on. Used the rattle gun to run the coach screws in to hold the mounting plate in place, and cut the excess 10mm off the rear with a cutting disc. Mounted with some more free hardware. Its not going anywhere. Light fitted. Mickey of course came around to check up on me after he had his dinner. He liked it. Tucked away. And seen in perspective. Does not get in the way of headroom. Of course I had to go see just how bright it is after sunset as well. I think it works. One dentists junk is another mans treasure. Dismantle mobility scooters rear end tonight.
I know you like these things so here's a shot from Fitzroy Island, QLD on my last evening in my 40's. It's nice here. I assume, therefore, that birthday greetings are in order. Also, I spy wiv my likkle eye... Have a good un! Cheers George. That wasn't my drink but I'm sure it was as delightful as what was drinking it. Thought the wife had got me a strippergram for a second. Her outfit left nothing to the imagination, bless her cotton socks - if she'd been wearing them. The wife actually took the photo of her. I've not turned into a peeping Tom.
Yesterday afternoon I managed to sort one of my treasure piles out. All the steel “off cuts” that I had stashed in the garage went out to one shelf in the new wood store. After I rearranged some wood and added a few brackets for very long 8 meter lengths of plastic pipe. Next job was to remove the motor, brackets, controller module and other junk as well as rear axle from the mobility scooter chassis. The gearbox opened, I removed all the gears and closed that up again. Cut the centre post off, all other loose tabs and ground it all smooth. Then reassembled the rear axle under the chassis. Rake added. Current thinking is to lengthen the chassis. Possibly source a cheap go kart rear axle, narrow it and refit with wide tyres. OR…….. (and I need advice here) Use a regular driven lawnmower rear axle and whatever mechanisms are in it, to fit a mower engine and its bits to make a simple, slow (safe) little ride on. Thanks to Mercdan68 for picking up a Schwinn kiddies tricycle for me on his way home last night. No, I have no idea, I just like them. They are never cheap, and looking at the condition of this one, they should be cheap. Needs a ton of cleaning up and paint. But hopefully be a nice little side project I am thinking red and Lime green. .
"Possibly source a cheap go kart rear axle, narrow it and refit with wide tyres."
Jul 24, 2021 10:00:39 GMT
"Possibly source a cheap go kart rear axle, narrow it and refit with wide tyres." Yup, Paul Y suggested and I have messaged a seller.
Jul 24, 2021 10:04:59 GMT
"Yup, Paul Y suggested and I have messaged a seller. " Why am I not suprised !
Last Edit: Jul 24, 2021 10:12:53 GMT by westbay
"Yup, Paul Y suggested and I have messaged a seller. " Why am I not suprised ! A really good and loyal friend. I count him in the inner circle. Job done, thanks to, Paul Y but plans changed again.
That dentist light fitting is really excellent. My bungalow was a dentist's in the 60s. I have a much older light with magnification and have found stashes of teeth when removing all the sheds.creeped the missus out ha ha
That dentist light fitting is really excellent. My bungalow was a dentist's in the 60s. I have a much older light with magnification and have found stashes of teeth when removing all the sheds.creeped the missus out ha ha False teeth, or just harvested teeth? I could see myself do a silly sculpture with a load of false teeth. Real teeth are as bad a collecting toenail clippings.
Well, going in some direction, just not sure if it is the right one. Yesterday I had given to Sally for putting up with me. So it was a bit of shopping, lunch and coffee at the Turkish in Chatham. Also some food shopping. My day was made when I found some USA made Cajun spice, I love cooking with it, as does Sally. Before we went out, I was looking on Marketplace for a gokart rear axle and some wheels. Found a seller who had a load of plastics and brackets, and messaged him on the off chance that he may have more parts to sell, turns out he has a ton of parts, mini moto engines, quad engines etc. But he also had a rear axle, with sprocket, disc and bearings plus carrier brackets and a spare wheel. Cost? £50.00 which is way out of my cheap ass league, not negotiable, but if you add up the value, I guess it is still a good price for what it is. So he messaged while we were having lunch that I could collect. Went there at 3.00pm after shopping, spent 45 minutes talking to him, Sally sat in the car. Then back home with the bounty. Sally went home to water her garden and do a few things. Quicky mock up shows I will have to cut about 250mm or 10” out the axle and re~weld it to fit better in proportion to the front end, which I still like. And once the chassis is lengthened it should come into proportion. While down at the garage, mate Craig started to interfere from 80 miles away. Sallys son was bringing back the mini moto I had given her for the grandson. He had partially dismantled it, as it was not running right according to him, only running well on choke. He had also tried unsuccessfully to “govern” it to slow it down for Harry. Then gave up. So in stead of buying some small used motor, I got given bck some small motor that I paid for already. He brought is back and chatted for a while, then went off again. So this is where craigrk comes in. “Why don't you build it as a TRIKE as you like different, that will be different” he asked me via text. You see, friends……. Always creating havoc. So I will take a look and see what a single rear wheeled creation works like, or else I will remove and add just the motor to the ride, narrowing the gokart axle and going that route. Sally was back by 7.00pm and rather than sit indoors drinking or eating in front of the telly, we did all the cutting and prep for 4 more Blue Tit nests. To be completed today, and when I get more Soudal Crystal adhesive. Bootfair was cancelled due to weather forecast.
Paul Y
"Yup, Paul Y suggested and I have messaged a seller. " Why am I not suprised ! Proof once again that my Super Power is spending other people money….. P.
I'll just leave this here ...
For something that’s going to have an adult on it, and a reasonably narrow front track, I’d think four wheels would be better.
Jul 25, 2021 10:54:18 GMT
Real teeth also loads of that smelly lubricant that dentist's use,lots of tooth tools. These are handy for detailed work. Have fun with that trike. 😀
"Yup, Paul Y suggested and I have messaged a seller. " Why am I not suprised ! Proof once again that my Super Power is spending other people money….. P. Super Power indeed. I'll just leave this here ... Thanks mate. For something that’s going to have an adult on it, and a reasonably narrow front track, I’d think four wheels would be better. Still under consideration Glen. Not sure where it will end at. Not been able to give it too much thought and time into it. Still more real world jobs to get to as well. Real teeth also loads of that smelly lubricant that dentist's use,lots of tooth tools. These are handy for detailed work. Have fun with that trike. 😀 I certainly would pass on the teeth. The trike/4 wheeler is going to take a bit of time and thought.
Jul 26, 2021 20:50:48 GMT
No bootfair, so a very lazy, slow start. I don't think I ever had breakfast at 10.00am and then watched some Olympics with Sally. Eventually made it to the shop. Ad made some more birds next houses for Sally, every screw had to have a 1.5mm pilot hole as it is thin, nasty, IKEA pine bookshelf wood. Once done, I set her off to start varnishing them with the brush she chose 10mm wide. And I made a frame for one of the canvas prints, Anthony the one lodger made for me. Done, as happy as I need to be. Sally carried on painting. But left at 13.00 to go cook Uncle Bob the hoarders meals for three days, and get ready for a BBQ we were headed to at 3.00pm In the mean time I started to place bits together. Rear wheel covered in a wooly hat. Yup, I like that so far.
Last Edit: Jul 26, 2021 20:54:57 GMT by grizz
Jul 28, 2021 15:02:49 GMT
Posted the question in question section, if it gets moved by the mods. I have always liked these. Especially in orange. Saw this one today, last MOT 2017 iirc MOT History is chequered, 128k miles Battery flat, tyres bald, some paint damage, needs a wheel bearing(s) Uncle Bob has had it in his yard for 3 years. What should I be paying for it, or do I need to keep walking? In case you want to check the MOT/maintenance history. No idea just how costly these are to maintain or what level of difficulty I may be letting myself in for. But I still like them. Opinions, advice etc please.
squonk
Jul 28, 2021 15:19:58 GMT
For any other car it would be worth scrap value (£150 ish). No doubt because it has a VW badge it will be subjected to 'scene' tax and someone will think it is worth at least £500. With an MoT on ebay they seem to sell for £500 - £750. Personally I wouldn't give more than £200 for it. Before buying, check the bulkhead where the clutch pedal is. Splitting of the metal at this location is common and is a big strip down to repair. Unless you can do it yourself the labour cost will easily exceed the value of the car.
misteralz
Jul 28, 2021 15:23:24 GMT
The wheels are highly desirable. Which is understandable as they're ace. I don't rate that gen Polo at all, but like has been said above, it's a cult VW and you won't lose on it.
