Remember Andy, the welder/manager lodger in summer, of BBQ and JD Honey fame? He is back for three days. Of course, like Mickey, he likes to play as well, and actually came home early from work yesterday, and while I was on the roof, drilling and screwing, and drilling and screwing, a LOT, I suddenly heard movement behind me on the ladder..... So suddenly I had company, and in tandem the job went twice as fast. Early selfie. Not the ideal angle to work at, but got stuff done. Screws in, followed by hexagonal caps on them. First two rows of six completed. Andy posing it up. Once capped, we cleared the roof. Then of course with too much light left, I needed to see what the replica pump looked like where I had visualised it for years. So we dragged it out from where it was packed at the back in the corner of the garage. Tried different head dresses. Note, this is STAR Gasoline, not Sinclair, so a bit of editing to come. I will also build a 200mm tall plinth for t to stand on, and need to fit a light inside the globe if I do go with it, or a stalk for the star if that gets used, to have it about 150mm above the top of the roof. Globe needs to be sign written Further back. Add in the Yeti, and you get the picture.
Well done ! looking good.
Well done ! looking good. Thanks Tony, Still loads to do, but the back breakers are mostly done, I think. Bringing this comment over as many people only look at pictures, or at the last page. . RIGHT.......... Searching Searching Searching.......Looking to find out if anyone in Kent, or Medway area knows of any company that tears up or recycles 7.5 ton delivery trucks. The ones with the white box on the rear. Not fully insulated trucks.... But rather the ones that use a Gelcoat sandwiched ply type construction. I am looking for a 4 meter or 16 foot by 2.4 meter or 8 foot section off one, either as one massive section or as two or three pieces, to use as a waterproof wall at the rear Any advice or pointers appreciated.
Nov 21, 2020 10:01:02 GMT
"The ones with the white box on the rear." These the one's usually called 'Luton Vans' or box vans ? One thing I did want to ask ... on the corner over the shed roof , the bit you cut off, is the remaining panel supportted ? if not it might 'flap' in any wind and damage panel and shed roof (might be teaching granny to suck eggs ) but thought I;d ask anyway as my OCD is twitching
Last Edit: Nov 21, 2020 10:05:37 GMT by westbay
Nov 21, 2020 10:25:22 GMT
"The ones with the white box on the rear." These the one's usually called 'Luton Vans' or box vans ? One thing I did want to ask ... on the corner over the shed roof , the bit you cut off, is the remaining panel supportted ? if not it might 'flap' in any wind and damage panel and shed roof (might be teaching granny to suck eggs ) but thought I;d ask anyway as my OCD is twitching I was going to edit and circle the rear corner here. The overhang is less than 300mm x 300mm here, note the supporting framework. So all screwed in along there, in every valley. Not going up or down, regardless of storm Josephine, Henry, Mcallister or whichever one comes next. Not sure if these are called Luton vans, I always thought the smaller Transit size up to 3 ton was that. But of course stand to be corrected. While hoping to find a side from one, not the 4” thick refrigerated type.
Nov 21, 2020 10:26:43 GMT
The ability to envisage the goal and work towards it is my greatest lacking. But one of your strengths buddy. I love how this turning out. #fanboi 😄
Nov 21, 2020 10:41:45 GMT
That flashing works even better if you use a primer under it. Morning mate, Having reviewed the info from the video below, I have decided that both my surfaces are very smooth and clean, so I will risk it, not using the primer. If it all goes tits up though, I would be blaming you, as seems to be the norm these days. Hope that works, video above.
Last Edit: Nov 21, 2020 10:42:34 GMT by grizz
Nov 21, 2020 10:47:33 GMT
Not watched the video, but isn't it a bit cold to be flashbanding? Unless you have a heat gun?
Only working from my dynamat/other deadening experiences...
Nov 21, 2020 11:07:29 GMT
Not watched the video, but isn't it a bit cold to be flashbanding? Unless you have a heat gun? Only working from my dynamat/other deadening experiences... LOL.... You read my mind. I am also known as Grizz of the Two Heatguns. Yes, heat gun for sure, to shape and soften to really stick. I remember the Dynamat I fitted in the Transit, done in summer it was a pleasure.
Nov 21, 2020 11:25:30 GMT
We are all here to help remind you, apart from Glen who's turn it is to hold the banner " it's my fault"
Last Edit: Nov 21, 2020 11:41:52 GMT by westbay
Nov 21, 2020 11:58:03 GMT
Not sure if these are called Luton vans, I always thought the smaller Transit size up to 3 ton was that. But of course stand to be corrected. While hoping to find a side from one, not the 4” thick refrigerated type. A Luton is a type that has the body extend over the top of the cab, can be any size of truck but generally they are fitted to Transit size vehicles, that's a box van and a common material for those and Lutons is Glasonite
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Nov 21, 2020 11:59:48 GMT
That’s really come together well Grizz, inspiring stuff,
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Nov 21, 2020 12:09:50 GMT
It’s always my fault. Just ask my wife. 🙄
Beat me to the “luton” explanation timbo. 😃 There’s a commercial vehicle breakers just the other side of the Dartford crossing; Juliet Way in Purfleet.
Nov 21, 2020 12:46:51 GMT
Hmmm.
Wouldn’t a simple timber frame and some more of that sheet cladding be a better option?
Nov 21, 2020 13:14:17 GMT
I bought a van box from a breakers on Erith marshes although that was 20 years ago. The sides do deteriorate though which is why I've recently had to reclad mine with some old box roof sheets I had laying around.
Nov 21, 2020 21:29:57 GMT
The ability to envisage the goal and work towards it is my greatest lacking. But one of your strengths buddy. I love how this turning out. #fanboi 😄 Thais mate. I know I am,OK on imagination and following up. I is,coming together as expected.
Nov 21, 2020 21:30:33 GMT
We are all here to help remind you, apart from Glen who's turn it is to hold the banner " it's my fault" He is a great team player.
Nov 21, 2020 21:31:32 GMT
That’s really come together well Grizz, inspiring stuff, If there is inspiration in there, then it’s great news. Also, nice if it is, makes one feel like you are making a difference
Nov 21, 2020 21:32:32 GMT
It’s always my fault. Just ask my wife. 🙄 Beat me to the “luton” explanation timbo. 😃 There’s a commercial vehicle breakers just the other side of the Dartford crossing; Juliet Way in Purfleet. Can’t imagine it is ever your fault.
Nov 21, 2020 21:33:16 GMT
Hmmm. Wouldn’t a simple timber frame and some more of that sheet cladding be a better option? Good idea, but not for this build. Prefer to have what I am planning on.
