Nov 14, 2020 16:38:10 GMT
Great progress Grizz. I wonder what oddity in US traffic law forced them to go up instead of longer?? I've seen a few of these up and over trucks but they have moved to rollbacks again. Thanks mate. Not sure about style of recovery, but as part of the theme and the age of the truck, this should work well. Today, Dennis is punching loads of holes in the doors etc.
Nov 14, 2020 18:54:50 GMT
Hi Rian, I did the opposite, but in reverse! My Merc takes the older smaller size, but luckily the larger one’s fitted my son’s more modern one. If he still has the original Centre caps would you like them?
Nov 14, 2020 19:36:17 GMT
Hi Rian, I did the opposite, but in reverse! My Merc takes the older smaller size, but luckily the larger one’s fitted my son’s more modern one. If he still has the original Centre caps would you like them? Hi,mate, Good to see you pop in. Hope all is good and your truck still makes you happy. I think the new cheap caps will do the job, I just did not want to tear apart the ones that came with the wheels when I get to removing the Mercedes Benz identity. Thanks for the offer, let’s see what happens.
Nov 14, 2020 21:54:41 GMT
So, when you have over 800bhp on tap, what do you do to maximise it....? Lighten it of course. Before. After This build keeps moving forward.
Nov 15, 2020 12:52:49 GMT
Hi Rian, I did the opposite, but in reverse! My Merc takes the older smaller size, but luckily the larger one’s fitted my son’s more modern one. If he still has the original Centre caps would you like them? Hi,mate, Good to see you pop in. Hope all is good and your truck still makes you happy. I think the new cheap caps will do the job, I just did not want to tear apart the ones that came with the wheels when I get to removing the Mercedes Benz identity. Thanks for the offer, let’s see what happens. Hi Rian, Thank you for the kind words and let me know if you have a need for them. Sadly i had catastrophic oil loss recently, so the truck needs a rebuilt 6.5, conversion to a Cummins 5.9, conversion to a petrol V8, or, sold on to someone else to try any of the previous options. So, that's my Chevy broken, my Land Rover Series three in pieces (prior to MOT time), my Delica needing bringing back to life in the curse word column; with the Merc E class the Jag and the new to me Rav4 doing well in the smiles pile. Keep safe and well and keep on having fun!
Nov 15, 2020 16:13:06 GMT
Hi,mate, Good to see you pop in. Hope all is good and your truck still makes you happy. I think the new cheap caps will do the job, I just did not want to tear apart the ones that came with the wheels when I get to removing the Mercedes Benz identity. Thanks for the offer, let’s see what happens. Hi Rian, Thank you for the kind words and let me know if you have a need for them. Sadly i had catastrophic oil loss recently, so the truck needs a rebuilt 6.5, conversion to a Cummins 5.9, conversion to a petrol V8, or, sold on to someone else to try any of the previous options. So, that's my Chevy broken, my Land Rover Series three in pieces (prior to MOT time), my Delica needing bringing back to life in the curse word column; with the Merc E class the Jag and the new to me Rav4 doing well in the smiles pile. Keep safe and well and keep on having fun! Man, that sucks. I loved your truck, but suspect it would just be too big for the space I have. Hope you can recover some of the value though.
Nov 15, 2020 16:20:37 GMT
So yesterday morning, I started to paint all the greys , into white.... Within 15 minutes of starting, Mickey was here too, and straight up onto the shed roof. First coat on. So today started wet and windy, so I went to get some loo paper for lockdown and some food, in case I got hungry. Back home, it was still wet. By 2.00pm it had dried up, sun out...... So I decided to go do the second coat......... FAAAAAAIIIILLLL...!! It started to rain and with the wind howling an hour after I started, so I shut shop. Really pi553d OFF. What a mess. Oh, and of course I do dislike water based paints. Hopefully get it done before Wednesday, and have it dry before the roof sheets arrive. Chicken Fajitas for dinner, Sallys treat. .
Last Edit: Nov 15, 2020 16:29:25 GMT by grizz
Nov 16, 2020 13:04:03 GMT
This morning I was out by 7.45 to go start and finish the paint before my day job started. Finished. I can honestly say, I am pleased that I did not stay with the industrial grey as planned. The white, green and red are a good, crisp combination, and once I have lights in under the roof sheets, it should work well. Weather and delivery permitting, I plan on taking Thursday and Friday off to get this done. In the mean time, I need to start looking at lighting options. I will go with new materials for this one, rather than old recycled school lights or similar. Sounds like people are getting good results with LED lights too.
Nov 16, 2020 19:44:50 GMT
This is the carport I am about to roof.
It is 6x6 meters.
BUT.....
Let’s work on 5x5 meters, so 25 square meters to be lit up from about 2.2 plus meters up.
The floor is paved with block paving, mostly a mottled grey colour.
So, what is the concensus on what light design and size, output etc to go for?
Last pic above gives an idea.
I do not think I will light up between the front red strip and the first green, but possibly the first green and second beam which is the steel. Then more toward the rear.
Thanks for the input.
Nov 17, 2020 12:34:36 GMT
If you're running power to outside, it may be worth adding a couple of mains sockets in waterproof boxes for running battery chargers and the like.
Last Edit: Nov 17, 2020 12:34:58 GMT by dabhand
1993 Rover 220 Coupe 1972 MG Midget
melle
South West
It'll come out in the wash.
Nov 17, 2020 17:49:51 GMT
That's a very good idea dabhand, may I add the suggestion of adding a power cut-off switch inside the garage? Most burglars will by now also have upgraded to cordless tools I suppose, but still.
thomfr
I would also think about adding a led spotlight with a motion sensor in a corner (with a somewhere hidden switch). This is something burglars don't like as they are often combined with a cctv camera and he does not know if there is a camera or not ;-). Also you could consider to make a "skirt" of clear plastic or poly style sheets from under the roof down for 30 of 40 cm on the side where most of the time the wind (and so the rain) is coming from to keep it dryer. Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
Nov 18, 2020 20:13:05 GMT
If you're running power to outside, it may be worth adding a couple of mains sockets in waterproof boxes for running battery chargers and the like. Not planning on chargers, but grinders, welder, tools..... yes. Compressor gets its own room and wiring. Plan is a few weatherproof plugs and light switches
Nov 18, 2020 20:29:29 GMT
I would also think about adding a led spotlight with a motion sensor in a corner (with a somewhere hidden switch). This is something burglars don't like as they are often combined with a cctv camera and he does not know if there is a camera or not ;-). Also you could consider to make a "skirt" of clear plastic or poly style sheets from under the roof down for 30 of 40 cm on the side where most of the time the wind (and so the rain) is coming from to keep it dryer. Thom I plan on managing the weather, but keeping to the right side of the law. No curtains, but wait till you see it unfold, I hope to make you happy.
Nov 18, 2020 21:38:00 GMT
So today started with this view. 7 contrails, one out of shot. I would love this to be an indication of things being headed in the right direction, allowing us to do what we used to do. At 2,00pm as one meeting came to an end, the doorbell rang. Roof sheets and materials had landed. Interesting experience, the driver refused to help me carry the 5.5 meter sheets onto the drive, as he was not insured, and would have to sue me if he got injured. First time I have ever had such a curse word experience. As he said, he is paid to do sidewalk delivery....... not impressed. But in the end I asked nicely after explaining there was nobody to help me move them onto the driveway, he drudgingly helped me carry them off the sidewalk. Later on, Mickey got home from town and helped me carry them down to the garage. One of the nice things is that the underside, being grey, is not too dark, should work well for winter work. I after 5 weeks wait, we have sheets. I have taken tomorrow and Friday off to get the sheets up. So tonight it was oven grilled lamb ribs and vegetables And just because I am off tomorrow Roll on Thursday.
Don't we all love a jobsworth? As to your contrails, out of interest I looked at Manila International departures from Terminal 1, the one that handles international flights for the full-fat airlines. There's only 27 outbound flights all day, six of which could be called "proper" long-haul, i.e. 1 UK, 2 US and 3 Australia. The rest are all within Asia or to the Middle East (got to keep the slave/maid/hooker supply routes going!). They are all "local" airlines as well, the vast majority being Philippine Airlines, not an Emirates, Quantas, US or UK plane in sight. A fair way to go before normality yet, I fear. Anyways up, glad your kit's finally been delivered and fingers crossed you get the weather on your side for fitting. Enjoy the time off as well!
Don't we all love a jobsworth? As to your contrails, out of interest I looked at Manila International departures from Terminal 1, the one that handles international flights for the full-fat airlines. There's only 27 outbound flights all day, six of which could be called "proper" long-haul, i.e. 1 UK, 2 US and 3 Australia. The rest are all within Asia or to the Middle East (got to keep the slave/maid/hooker supply routes going!). They are all "local" airlines as well, the vast majority being Philippine Airlines, not an Emirates, Quantas, US or UK plane in sight. A fair way to go before normality yet, I fear. Anyways up, glad your kit's finally been delivered and fingers crossed you get the weather on your side for fitting. Enjoy the time off as well! Thanks George I think my comment was possibly a bit sarcastic and tongue in cheek. I am at least part conspiracy theorist and believe there are more agendas being managed behind the scenes than any of us normal people realise. Maybe stopping there is a good idea. But I would of course love to fly to the USA for a road trip with craigrk as we have a serious whizz bang trip planned.
By way of partial apology I will post up a PM received from Rasputin on another forum.
He explained in a clear, non emotive way, what they are up against.
I was aware when the driver refused to help me get the sheets off the sidewalk that he probably had rules to follow. BUT His attitude was filled with anger and possibly even petulance. HOWEVER My day job is in part working with really awkward, some rude and difficult customers and as much as some of you can fine tune a turbo, prune a Bonzai or bake a cake, my forté is managing conflicts.
Anyway, posted purely in case any of us can learn from the info below and understand our delivery driver, team etc.
Hope you won't mind a PM Grizz; no need to reply if you wish.
I deliver pallets of goods to high street stores, often through the front door early in the mornings.
Our strict instructions are to tail-lift them out of the truck onto the ground next to the tail lift, and the store staff are to take over from there, dragging pallets across uneven pavements.
But it rarely works out like that. Some of the pallets weigh roughly a ton and need a helping shove, especially up slopes and over bumps. On the other hand, at some stores it works out best for me to stay in the truck and just lower the pallets down - the store staff are waiting to take them by the time I get that far and have an easy trundle into the store, and if I were to take them off the tail-lift the delivery would take a lot longer.
So it all depends. I try to help out where I can, but it's really a case of finding the most efficient handover in each situation. I do hear a lot of stories of drivers who have got too used to standing about on the back of the truck though!
Your driver couldn't sue you of course - you only asked him, didn't order him. He would have to sue his employer for putting him in that situation, but that might mean no more job; his employer might try suing you but if you only asked for help and the driver agreed, it wouldn't be clear-cut.
Since your roof sheets are so long, the supplier would have to send a driver's mate or a truck with a hiab crane if they offered an unloading service officially, but I bet they tell their drivers not to touch the panels at all, and let the clients arrange unloading. Cost-cutting.
If there's nothing to that effect in the small print of your order, or nothing about an optional extra fee for an unloading service, then the supplier may be just fudging it and you may have scope for redress. What if you got injured because the driver would not help if he didn't? Who would be liable? Their small print might be an interesting read.
I suspect the supplier relies on the same tactic as my employer - the stores have to take the pallets in however it can be done because they need the goods. They could refuse to accept them given good grounds, but they can't ever afford to.
I could tell you a few stories - such as a store staff member whose official role was to replenish front-of-store display shelves, who broke her leg by falling backwards whilst dragging a pallet over a pothole - but I will stop there.
In your case, you clearly want the sheets and probably (as far as the supplier knows) have a team in place waiting to install them; therefore you are very unlikely to refuse to accept them just because you have to unload them. Chances are (the supplier is gambling) that your roofers will help out.
Likewise their driver is put in the same situation - you made it clear that the sheets couldn't be unloaded without his help, so in effect you were calling his bluff and suggesting that you would refuse them. So it was in his interests to help unload, even arguably at his own risk, rather than take them back. In my case, taking stuff back would involve (and has on occasion) unpalatable hour-long argumentative phone calls to the depot and/or other senior managers, designed to get me to make the delivery no matter what, and to get the store to accept it no matter what.
The only time I did take a whole delivery back was when it was loaded on a 16ft high trailer but the shopping centre had a 14'6" height limit!
PS. I did reply to Him
Last Edit: Nov 19, 2020 14:40:50 GMT by grizz
I have had, back when I was driving a lorry for a living, some “interesting” deliveries.
Like the chap who ordered 600 Christmas trees, to be delivered to his house, and who was apoplectic to wake up in the morning to find a 40’ curtain side artic on his drive. Even more when the driver (me) pointed out that my job was to drive the lorry, his job was to unload it. He didn’t get his trees.
Another time at Aldi’s warehouse in Essex when they got very upset with me because I refused to unload the lorry with their powered pallet trucks without instruction, or proof from them that I was insured to operate it. They didn’t get their dogfood (and there was nearly a riot as the other drivers on the bays nearby realised what was happening).
Generally speaking, it’s entirely down to the customers’ attitude whether a driver will get involved in physically unloading a wagon. Particularly if the goods are heavy, awkward or dirty. Would you have offered him a shower afterwards? Would you have been ok with the lorry parked there for however long if he’d hurt himself? My mate broke his foot helping to unload once, then had to spend two days in agony driving back from Italy because our employer wouldn’t have paid him (or only statutory sick). He had the weekend off and spent the next two months driving around on pain killers while it healed.
Folks who order a lorry load of stuff need to be able to handle it when it arrives. My heart used to sink when I got a private address on a delivery note. I once had a bloke in Birmingham order a full roll of carpet. I ended up putting a strap around it to the nearest lamppost, and pulling the truck forward. He had about 12 cousins trying to pick up a 5m long roll weighing the best part of 500 kg. Maybe they’re still at it.
I have had, back when I was driving a lorry for a living, some “interesting” deliveries. Like the chap who ordered 600 Christmas trees, to be delivered to his house, and who was apoplectic to wake up in the morning to find a 40’ curtain side artic on his drive. Even more when the driver (me) pointed out that my job was to drive the lorry, his job was to unload it. He didn’t get his trees. Another time at Aldi’s warehouse in Essex when they got very upset with me because I refused to unload the lorry with their powered pallet trucks without instruction, or proof from them that I was insured to operate it. They didn’t get their dogfood (and there was nearly a riot as the other drivers on the bays nearby realised what was happening). Generally speaking, it’s entirely down to the customers’ attitude whether a driver will get involved in physically unloading a wagon. Particularly if the goods are heavy, awkward or dirty. Would you have offered him a shower afterwards? Would you have been ok with the lorry parked there for however long if he’d hurt himself? My mate broke his foot helping to unload once, then had to spend two days in agony driving back from Italy because our employer wouldn’t have paid him (or only statutory sick). He had the weekend off and spent the next two months driving around on pain killers while it healed. Folks who order a lorry load of stuff need to be able to handle it when it arrives. My heart used to sink when I got a private address on a delivery note. I once had a bloke in Birmingham order a full roll of carpet. I ended up putting a strap around it to the nearest lamppost, and pulling the truck forward. He had about 12 cousins trying to pick up a 5m long roll weighing the best part of 500 kg. Maybe they’re still at it. Totally get you on all the points Glen. And just to say, I always offer all delivery drivers (right down to my Calor Gas bottle guy a hot or cold drink, and the use of a toilet. I am possibly in the minority though.
