So next job, done on Thursday, between meetings and customers. Oh, and helping Mickey. He loves a fire. Windy outside, but I decided to start the long overdue refelting of the roof. Having added that little piece out front changed,the dynamic of the job, plus making it a bit more awkward to reach onto the roof with the flat head nails. This piece of felt landed on the floor three times before I threw a length of Used decking on it to keep it in place till I got the first few nails in. When I had the shed built, I specified it to be made two lengths of shiplap taller than standard, in order for me to be comfortable doing woodwork in there. Add a concrete plinth and it gets taller. Used a ladder to get on top, and of course when I had done the last sheet, my back refused to let me get back on the ladder.... Managed to after a bit. And finally, done. Well, almost, as I need to remove the wall down the right side wall which has collapsed over time. When I got back up at the house, there was a knock on the door and Mickeys wife dropped off two packages, one for me. Sent by Craig’s wife and decorated by his daughter. South African style rusks. (Check google) Sally came over after 7.00pm as another potential lodger had messed her around, not actually coming to look when she was waiting to show the room and house. I was knackered and ordered a SMALL PORTION OF FISH ND CHIPS.that Sally picked up on the way to me. Yes, it really is a small portion, and we still did not finish all the chips. Mr Fox got his share.
It’s full speed now for Dennis and his NASCAR truck build. With the bedside panels and tailgate fitted, more fettling followed. Tailgate fitted. With the amount of power that’s going to be put through the rear end, Dennis decided to add the rear spoiler to add to downforce and also stability. Adjustable supports to fine tune downforce to suit different race tracks. Lovely Smaller units above the closing chains. Rear will get closed in for aerodynamics and also looks. Next job up for today is to go buy some new plugs. You may ask why would you need power inside the truck. Maybe I will leave that for you guys to answer......... Pretty obvious ehh. .
Jun 10, 2020 13:19:07 GMT
Worth posting here too. Any carport builders out there ? So for the clever engineering and applied geometry types out there. I am sure this is not a difficult thing, and if you add in CAD then even easier. Right....... I will try explain and hope it makes abstract sense to some of you. Simply put, I want to build an approximately 5 meter Long by 6 meter Wide carport, in front of and to the right of my existing garage. Part of the 5 meter “depth” has to overhang the existing garage door without impairing its opening Then........ I have a woodwork shed, built on a 200mm high plinth, and also slightly taller than average where the 5 meter side, away from the garage wall, needs to overhang the shed roof, while allowing a sloping drop off for rain and melting snow that tapers from the entrance side. It also faces into the majority of our wind and rain direction at that low end. I want the 6 meter wide front end and entrance span to be as non intrusive as possible, so uprights need to be against the sides of the overall area. Which means a potential upright support pillar at 4 meters against the garage front gable wall between the doors, leaving as much as a meter overhanging at about 2.6 meter or 8’6” off the floor and supported from an upright post with cantilevered support outward. Make any sense yet? Right. The rear post, next to the woodwork shed is near 5 meters from the garage rear corner, but needs to still overhang the shed to create the 6 meter width that I am looking to create. Out at the front of the carport, the 4th upright pillar is going to be about where the brick red colour wall is at the moment, that wall plus the grey wall are all coming down and the wall is getting rebuilt about where the red wall is now, including post no 4 the front one, which is at 6 meters from the garage. I am happy with a short lifespan roofing solution of ply and glued down felt roofing which one would hope will make 8 years before needing replacement. So...... How do I address the weird geometry on two planes as well as ensuring the energy/mass transfer is done sensibly? Amateur plan drawing. Idea of where the posts would go, showing offset and set back. Let the fun begin.
Jun 10, 2020 13:53:17 GMT
Have the canopy higher than the shed. Don’t fox-picture about with multiple falls.
Jun 10, 2020 15:35:02 GMT
I'd agree, make it go over the shed roof, build a perimeter frame out of 8x2 then sling some 6x2 across the 5m.
If you go for something lighter than ply and felt like opaque polycarb you might be able to downsize the timbers.
I'd also connect it to the garage wall to give it more stability.
LAndy
Jun 10, 2020 17:07:35 GMT
Man, I miss proper fish and chips! Truck is looking awesome too!
Previous retros: 92 AX GTi 92 Scirocco Scala 94 80 sport 87 Golf Cab GTi Current retro: 1965 Clark Cortez YouTube Website Instagram
Jun 10, 2020 20:43:19 GMT
Have the canopy higher than the shed. Don’t fox-picture about with multiple falls. I do not want it crazy high. I have some ideas. I'd agree, make it go over the shed roof, build a perimeter frame out of 8x2 then sling some 6x2 across the 5m. If you go for something lighter than ply and felt like opaque polycarb you might be able to downsize the timbers. I'd also connect it to the garage wall to give it more stability. Still playing with materials in my head. Man, I miss proper fish and chips! Truck is looking awesome too! Yes, good fish n chips is hard to beat. Truck ?
Jun 10, 2020 21:01:04 GMT
Russians.... Stas in Siberia Doing his day job. Sunset Cooking pork steaks, we may collaborate on a cook book one day And 5 hours of time zone difference away, Vladimir was elsewhere in Russia in his workshop, having a beer, wearing a familiar Primark T-Shirt. Seems dark beer rules. Later, Sally popped in to drop off two sets of vintage Halogen spotlights, from a friends loft. Minutes after posting about going to the scrap merchants to look for some trolley wheels, in order to build a cab trolley, but only scoring a wheelbarrow for neighbour Sam,. A buddy, Fil “Sparkplug” from Cambridge posted up these pics, offering free home delivery...... This week. Yup, life certainly is good Wood is rotten, but I was only looking for wheels to reuse. Suddenly more pieces were falling into place.
Jun 10, 2020 21:30:30 GMT
Getting the paving corrected as part of this carport build is necessary The camera loses some of the damage perception but a plank gives you the idea at least. While out at at the shops and in the scrapyard on Saturday, Mate PaulF whose hydraulic press I used for the Chevy Blazer suspension parts and whose brake line making kit I got to use to make up the C10’s new brake lines And I were chatting on Messenger Video, as you do, when he asked me what job was next, so I mentioned that the paving, posted above here, has to be repaired and the base compacted and redone. “Do you have a whacker plate or compactor ?” He asked, of. Course I did not, so he offered to go fetch his from a friend who had used it and deliver it to my place in an hour or two. Plus have a coffee and a chat. Bargain !! Couple of hours later a Nissan Cube reversed down my drive. Giving birth to this handy tool. The weather turned in the afternoon which stopped play, but a good weekend in all. Saturday evening sunset. Sunday rolled in and I had planned to get started on lifting the paving and repairing the subsidence Facebook said it was 6 years since the last MOT on the C10 But Sally who came over by 08.00 had other ideas as the weather still sucked. Also, I had managed to get a second short term lodger, a welder on a maintenance contract at a local power station. So it may just be 7 weeks or less, but cash ion the bank is cash in the bank. So Sally insisted I clear out some space for the new guy. She also has a new lodger, which will help fill the hole her cars engine blowing up had made in her savings. So it seems I was stuck indoors all day. Found some food from 2009 and more recently. Not impressed with Sally Poking the Bear. Chatting with Craig at one point, he was photobombed by Lilly. Back to cleaning the house, every surface, flor etc washed and cleaned. Sally is a menace with a camera. Eventually got it all wrapped up, and to be honest, I am pleased, and thankful for all the help she gave me too. Hope to find time over the next weekend to sort the paving if the weather plays along.
Your mate delivers you his whacker plate then you call him a tool!
Fine friend you are.
Jun 11, 2020 14:26:10 GMT
I'm sorry, but "delivering a whacker plate" seems like the worst kind of euphemism!
There is an old traditional saying: “Never drink with a Russian unless you are a Russian” Last night, through the wonders of Whatsapp and technology, I joined Vladimir and friends Oleg and Yelena in Olegs garage for a drink or two. Vodka, Beer and Bacardi flowed for over an hour. Between our broken Russian , English and Google Translate, we had a good visit. As we know, if you have no photos, it did not happen. Yelena was hostess, pouring vodka and matching the guys all the way. Charming lady and mother of Olegs three daughters. Following my previous visits with Vieux and guided tours of his shop and his neighbors shops, I would absolutely recommend you reach out to him via PM to exchange numbers and have a chat or text conversation. Whatsapp is free after all. это отличный способ поделиться нашими культурами и интересами. спасибо владимир
Your mate delivers you his whacker plate then you call him a tool! Fine friend you are. Took a moment, but of course, the Cube gave birth, Paul just revived the machine, which like many Chinese tools, need constant revising and tightening of nuts. I'm sorry, but "delivering a whacker plate" seems like the worst kind of euphemism! Straight into the gutter we slide. But I was happy.
Jun 12, 2020 20:00:02 GMT
Continuing on this path the carport construction enlightenment I thought it worthwhile asking about using some Aluminium scaffolding I was thinking a tapered structure, or flat structure, but mounted on a slope. Covered in industrial profile sheet metal roofing materials. Once again, I like the idea of lightweight construction and also premanufactured Layher Alloy Lattice beam supports. Any scaffolders on here know more ?
Last Edit: Jun 12, 2020 20:02:14 GMT by grizz
No photos as Photobucket messing around last 12 days and they do not reply to their Helpdesk. But..... First Covid-19 Boot-fair of the year. Rain was forecast, soon;y 1/3 of field filled. Still got lucky. Needed a multi plug adapter to repair/replace one I drove over years ago...... £1.00 each or take the lot for £5.00 so I got 9 units. Also bought 14 GU10 lightbulbs for £5.00 And a very nice garden rake for £2.00 Came home, had breakfast, now headed out to garage to mix some cement in @johnnybravo ‘s mixer to lay some more high density blocks in the ‘compressor room” that my interfering friend Paul Y suggested I build Next to the woodwork shed while relocating the wall on the drive. Those blocks are heavy for sure..... 1500mm x 750mm and 1900mm high with a double glazed door and frame if I can find one to fit the hole at the place I get my used glass and glazing stuff should be good. Good idea Paul. .
Last Edit: Jun 21, 2020 8:52:32 GMT by grizz
Didnt realise anyone was still being bu££-*$#ed by photobucked....ditch the con artists grizz and use postimage or one of the other free hosts.
Didnt realise anyone was still being bu££-*$#ed by photobucked....ditch the con artists grizz and use postimage or one of the other free hosts. Problem is.... After 10 plus years nd half of that subscribed for a bigger cache, I am 14000 photos deep with them. If I knew how to move all of them, retain all the links etc.... I would. Seems for now, and the future, I am subject to regular reaming. If I stopped, it would mean 8 forums to stop contributing to.
@johnnybravo not sure what you quoted, but the pics show where your mixer saved my life so far😉
My back objects to most of the lifting I do now, so this helps a lot.
Buy a Donkey.
Last Edit: Jun 21, 2020 9:08:16 GMT by grizz
Jun 21, 2020 10:08:05 GMT
Didnt realise anyone was still being bu££-*$#ed by photobucked....ditch the con artists grizz and use postimage or one of the other free hosts. Problem is.... After 10 plus years nd half of that subscribed for a bigger cache, I am 14000 photos deep with them. If I knew how to move all of them, retain all the links etc.... I would. Seems for now, and the future, I am subject to regular reaming. If I stopped, it would mean 8 forums to stop contributing to. I’m not quite as deep as that, but I am in the same boat. It’s a pain in the posterior.
