Mar 27, 2020 19:48:02 GMT
Mar 27, 2020 20:13:26 GMT
Brake linings first then D9010 is a semi rigid non-asbestos woven lining based on yarn spun for synthetic fibres impregnated with specially developed resins reinforced with brass wire for added strength and assistance with heat dissipation. This material has a high co-efficient of friction and is suited for light to heavy duty operating conditions. It is oil and grease resistant and also suitable for light to medium duty oil immersed conditions Hope this answers the questions raised
Mar 27, 2020 20:17:08 GMT
no idea on cost or availability but the smaller earlier beetle rear units would suit it better the the ones on it. we are really nit picking here though aren't we? Earlier Beetle anything = ££££££
Mar 27, 2020 20:20:06 GMT
figured... just not my "bag".
Mar 27, 2020 20:26:02 GMT
Door seals - no easy fix either - these are a glue on job - you need the correct adhesive - I use a heat resistant / high temperature trim adhesive (in other words it does not let go of what its holding in place when the sun comes out and makes the car hot) May I ask which product do you use? And how do you prepare the bodywork and the rubber? Do you degrease or the like? In the past I used contact glue from the DIY store like Pattex which was sometimes disappointing. I use an upholstery trim contact adhesive - as already stated it must be resistant to high temperatures - if you Google 'High temperature automotive trim adhesives' you should be able to locate a suitable product - I use a solvent wipe on both surfaces prior to applying the adhesive
Mar 27, 2020 20:37:34 GMT
Chris, forgive my ignorance, but why is Bob’s rear number plate fitted to the bumper yet yours is fitted to the boot lid? Earlier / later model I presume? David David - Bills car is a Javelin Delux model Mine is the lowly Javelin Standard model Which happens to be much rarer than the Delux models The early cars are different again with a thinner profile bumper - boot handle / lamp
Mar 27, 2020 21:00:10 GMT
Apparently it’s a jowett, might have some useful parts.
Last Edit: Mar 27, 2020 21:00:41 GMT by pauly22
Mar 27, 2020 21:08:40 GMT
So with the car now outside I could turn my attention to the interior metal trims These were just painted on the standard cars but were painted and then had a transfer applied to them on the Delux cars - said transfer was to apply a 'scumble' (wood grain effect) to the trim It was only a thin coating of paint and with this particular vehicle taking on a second life over the last 10 years of a mobile swimming pool all trims were quite rusty Place these back on the car against the new wool headlining and with the slightest whiff of condensation the rust would be absorbed by the headlining quicker than ink on blotting paper - and would leave the headlining badly stained Nothing for it other to remove the rust & prep them for fresh paint Front bench seat brackets too On to the panel stands And into primer Once cured I flatted the primer back ready for paint (paint is 2 pack / 2K) Regardless of what type paint you are using a 'mist coat' is always a good idea - sometimes referred to in the trade as a 'gripper' - so rather than apply a full coat of paint on the panels from the off you apply a light coat of mist - moving the gun quickly and set back a little more than normal - don't worry about coverage / shine or finish - what this does is supply a base key / adhesion for the following full coat and reducing the risk of paint runs 2 full coats later And once tack free was placed out in the sun to cure Sid had a wonder over to inspect the Javelin outside the workshop - but by the time I had picked my phone up he had decided it was too much bother and went back to sunbathe However with the final polish imminent I asked that he kept an eye on my polishing cloths that I had washed and hung out to dry More tomorrow
Last Edit: Mar 27, 2020 21:10:53 GMT by Deleted
Are you not allowed to use the normal washing line for your polishing cloths? Sid seems a bit umm round in the belly for this far out of Christmas. My ginger has a saggy belly from when he was fatter as a younger cat. He's quite lean now but his droopy belly sways when he runs.
Last Edit: Mar 28, 2020 6:44:45 GMT by varelse
Are you not allowed to use the normal washing line for your polishing cloths? Sid seems a bit umm round in the belly for this far out of Christmas. My ginger has a saggy belly from when he was fatter as a younger cat. He's quite lean now but his droopy belly sways when he runs. Sids belly just is his winter fluff - he's quite active & fit but not hyper and always weighs in at usual 4.2 / 4.4 kilo mark when he attends the vets for his annual check up
bstardchild
Club RR Member Number: 71
Mar 28, 2020 11:25:14 GMT
Sid seems a bit umm round in the belly for this far out of Christmas. My ginger has a saggy belly from when he was fatter as a younger cat. He's quite lean now but his droopy belly sways when he runs. Sids belly just is his winter fluff - he's quite active & fit but not hyper and always weighs in at usual 4.2 / 4.4 kilo mark when he attends the vets for his annual check up He's a lightweight "Stanley" at his last check up weighed in at a stone so frequently gets addressed as Stonely (Lisa says leave him alone he's just "big boned") He he is trying to ensure we don't go away for a weekend without him...... Ensuring that shredding is carried out correctly
Mar 28, 2020 22:03:07 GMT
Time to knock some more jobs off the list Bill had fitted another steering column to the car (for a reason that I am unaware of) - I asked at the time if he had checked the insulation & continuity of the horn slip ring - yes was the response - it appears that the yes response was 'yes the horn slip ring is faulty / knackered - has every time you turned the column to the left or the right it sounded the horn (pretty pointless fitting it in the first place then) So out came the column Then I separated the shaft - broken piece of insulation on the slip ring was allowing the ring to earth against the shaft hence sounding the horn when you turned the steering Problem being is that you have to separate the spot welded gear shaft off the column shaft in order to fit a new slip ring which is several hours of work I have never been shy of hard work but if I can find a more cost effective solution - then I will - I tried a bonded repair - then fitted the shaft back to the column - then tested the slip ring & feed wire back to the horn push on the steering wheel for insulation & continuity - net result success I could now refit the column Steering wheel & horn push - left to right lock several times and the only time the horn sounded was when I pressed the horn push The repainted window trims were refitted to both of the rear quarter glasses & the rear window Which then allowed for the rear seat to be fully fitted & fastened up With column gear change rechecked for configuration & selection split pins could be fitted to lock the selection rod knuckles - a little grease added to the ball pins Then inspection cover on the front toe board fitted Not far away from that final hurdle now
Last Edit: Mar 28, 2020 22:05:48 GMT by Deleted
Mar 28, 2020 22:18:59 GMT
Bet you’ll be glad to get something different in the workshop.
Mar 28, 2020 22:23:32 GMT
This chap is getting a totally different car back from the one he gave you - I hope he realises that !
Mar 28, 2020 22:31:10 GMT
looking very good Chris!
Mar 28, 2020 22:36:58 GMT
Bet you’ll be glad to get something different in the workshop. Hmmm - Next job - guess what - its a Jowett a very different Jowett though and it will be interspaced by a MG at a stage in the not too distant future - then there's another Jowett - Hmmm - come to think of it there's a Jowett after that Jowett too - all of differing specs / differing works etc so it should not get too boring for you all (I hope)
Last Edit: Mar 28, 2020 22:38:22 GMT by Deleted
Hmmm - Next job - guess what - its a Jowett a very different Jowett though and it will be interspaced by a MG at a stage in the not too distant future - then there's another Jowett - Hmmm - come to think of it there's a Jowett after that Jowett too - all of differing specs / differing works etc so it should not get too boring for you all (I hope) I doubt that very much!
Always an entertaining and educational read, Chris!
JP
Bet you’ll be glad to get something different in the workshop. Hmmm - Next job - guess what - its a Jowett a very different Jowett though and it will be interspaced by a MG at a stage in the not too distant future - then there's another Jowett - Hmmm - come to think of it there's a Jowett after that Jowett too - all of differing specs / differing works etc so it should not get too boring for you all (I hope) You sound like my old boss describing my job. Yes it's just grinding flat stock all day but they're different sizes so it won't be boring. Yeah right... 😉
Mar 29, 2020 20:51:14 GMT
Front screen surround trims & the rear view mirror fitted So the front bench could now be fitted - easier to place the seat in without the brackets attached as the seat is very heavy Then attach the brackets The dulux cars have a wind out adjustment for legroom (standard cars have a much simpler seat mechanism) Arm rest fitted Another job off the list Carpets next - Bill has supplied these - from what I can see he purchased them in 2003 and has left them semi rolled up in a large polythene bag with no end of curse word pilled on top of them - hence they have heavy creases that will not come out even though I have had them laid out flat with weights on the corners for about a month - Although they look ok they are of a poor quality manufacture Underfelt first Note the foot well for the rear seat passengers Its one thing fitting cheap & nasty carpets - but cheap & nasty carpets that have been poorly stored for a significant period is another For some reason the set did not come with underlay for the front floor section I used the front carpet for an initial pattern and then trimmed it to fit The fitted the carpet Which at first does not look too bad But its short on either side to the point that it does not meet the threshold I have to say it - 'I hate working with curse word' To make the best of a bad job I glued a vinyl strip down under the edge of carpet and ran it into the door threshold plate - then fastened the carpet down with a couple of cup head screws - not how the factory would have done it but the factory supplied the cars with decent carpets that fitted when new and not some backstreet trimmers cack handed attempt Not often that something exhumes my patience but its normally working with rubbish quality products that does - I called it a day More tomorrow
Last Edit: Mar 29, 2020 21:23:59 GMT by Deleted
