Well, good morning bus fanatics.
We’ve been back to Aylesford for another day working on GKE 68.
My first job was to refill the engine with water and see how many leaks it had. It had a couple of obvious ones, both on the thermostat housing.
I tried nipping the bolts up but it didn’t help. Just take a look at those bolts. You can’t get a ring spanner or socket on them because they are too close to the housing. You have to use an open ended spanner. However, some of those bolts are also close to other things (such as that fuel filter below it) so if you do get a spanner on you can’t actually move it without hitting something. I wound up unbolting the fuel filter so I could push it out of the way and swing the spanner.
The drips were the sort of drip that might sort themselves out or could pour water all over the floor. Should I bite the bullet and strip the housing down or risk it and hope they seal up? Well, as I’d already taken the fuel filter off I suppose we should just do it properly eh?
Here it is getting rebuilt with some gloopy stuff.
The engine sump seems to be dry so it’s not leaking oil just at the moment. That’ll change when we start the engine again. The gearbox is pretty soggy though. There are access plates on each side of the casing and they are both leaking. The one on the left is just an access plate so it’s easy. The one on the right has the selector forks on it though. We’ll ignore that until we find out if the gearbox actually works properly. It’ll need an oil change after a few hundred miles so that would be an ideal time to seal up the cover plates if it doesn’t need more serious work.
Speaking of the engine, the plan for next time is to get the engine running again and see if it’ll build vacuum. Then we can find out if the front brakes work. If they do we could put the prop on and drive it round the garage. I say “could” because I very much doubt if that’s happening any time soon. We’d need a driver’s seat apart from anything else.
While I was unleaking the engine Ian was fitting a new oil seal to the rear axle. By way of proof here’s a photo of a big socket and some other random tools.
Er, no, sorry, I didn’t crawl underneath to take a photo. There is an oil slick down there you know! There are limits.
My next job was to try and fit the windscreen. That comes as two parts. The lower third is fixed into the cab and doesn’t move. An aluminium trim holds it into the frame. That should be easy.
The upper two thirds is mounted in a chromed frame and can swing open along the top edge for ventilation. Sliding the glass and rubber seal into the frame is going to be the bigger pain in the tushy so we’ll do that first.
Or maybe we won’t… I couldn’t get it in. The two sides would slide in but then the seal across the top of the glass hit the frame it would not go in.
Part of the problem was that some of the screws that hold the frame together protrude a little into the channel.
There is one on the top side of the channel too so the seal gets nipped between the two. You can see how the top one has hooked the seal and pulled it round the glass.
Easy fix, just back the screw out. Right?
Nope. Wrong. The frame was in one piece when it was chromed.
So even if I could get the screws out I’d ruin the chrome.
I had three attempts at getting the glass in while using increasing amounts of Norman’s hand soap. Norman, you remember, is the chap who runs the bus company where GKE lives.
Eventually I gave up and chucked it in the car to do on the bench at home.
Here are all the bits back at home.
It’s a lovely frame don’t you think?
First job was to use the air cut off tool to grind down the screw heads down a little.
Then, with some liberal lubrication, we’ll try and slip it into the hole. It’s going to be tight so we’ll need to be firm but we also need to be gentle.
Why are you giggling at the back?
So, did I get it in or did I shatter the glass all over the garage?
Of course I got it in.
I had to give it a good thumping with the rubber mallet though… Nah, not really. I was using that and the wooden wedge to settle the rubber seal in. It went together just fine.
I have to say I was a bit nervous about this job. I’d have been really annoyed if something had gone wrong and I’d bust it. It’s safely wrapped in a blanket under the bed at the moment. I don’t trust myself not to break it if it stays in the garage.
You know how it is, you wait a lifetime for a bus restoration project to come along and then two turn up at once.
Ian had mentioned another project he was involved with a few months ago. It’s another double decker being rebuilt but this one is in private hands. Ian wanted help refitting the radiator so on Sunday I went along to a top secret location deep in the heart of Kent and found this…
We got the radiator back on and installed that wheel arch you can see.
The restoration work on this thing is absolutely lovely but it has a fair way to go. You can see the paneling is missing from the lower deck. It is still fitted to the top deck. This bus but has been kept under cover so it’s in much better condition than GKE was. GKE sat outside for years and suffered badly as a result. Much of the wood framing on this one is original.
So what is it, what’s my involvement going to be, and will we be getting a restoration thread on this too?
What is it? It’s a post war Guy Arab chassis with a 6 cylinder Gardner LW engine and a Park Royal body on it. It’s a low bridge body so it has a sunken walkway in the lower saloon and upstairs it has four across seating and a lowered walkway down the off side.
What’s my involvement going to be? Well that’s a damn good question. I have more projects than I can cope with at the moment and I really don’t need another bus. That said she’s a bit of a honey and I am interested. Ian and its owner seem keen to have another pair of hands to work on it. Almost certainly I’m going to wind up helping out but probably not to the extent that I’m involved with GKE.
Will there be a thread on it? I doubt it. Partly because I’m not sure how involved I’ll be but also because this bus is in private hands and I don’t know what the owner would think. But I will let you know if / when I go over and what we get up to.
We’ll see how things pan out. Could this be the beginning of another long term relationship or just a one night stand behind the bus shelter? Time will tell.
James
