Aug 14, 2019 15:25:14 GMT
As above. I was given a full bottle of gas today. I reckon it's worth my while to buy a regulator and use it over the disposable cylinders I use now. Will it work well?? Any ideas what LPM I need to set it too?
Aug 14, 2019 15:31:36 GMT
That's all I use, as its cheap and all I can get in the depths of Lincolnshire!
Aug 14, 2019 17:46:11 GMT
used to use it many moons ago courtesy of one of the best landlords ever. not quite as good as argon-mix but good enough.
(rip mossy!)
Aug 14, 2019 18:55:22 GMT
What size bottle is it? Might be able to assist with a regulator if it helps?
Aug 14, 2019 21:33:38 GMT
First you need to know if its pure CO2, I believe its sometimes mixed for the food and drink industry, might be with nitrogen, not sure.
If it is CO2 its a much better idea than disposable bottles.
Try 10 lpm, you might need more especially outdoors.
It is different to weld with than Argon mix, not as nice and you will need to adjust your welder but you will manage just fine.
Aug 14, 2019 22:14:44 GMT
What size bottle is it? Might be able to assist with a regulator if it helps? 35litre. 1565796236869 by quickrack, on Flickr Help is good!
Ritchie
Club RR Member Number: 12
Food grade CO2 for mig??Ritchie
@ritchie
Club Retro Rides Member 12
We used to use it all the time, it actually took me a while to adjust to Argoshield when I started using it. Over the time I used it I thought it was fine, and TBH I don't see a huge difference with the argo. You can also use CO2 fire extinguishers if you turn them upside down. A mate of mine got a load of these free and has been using them for years. They do tend to freeze up a bit though on a long weld. If you don't like it, it's a good excuse to set up a beer keg in your garage.
Last Edit: Aug 15, 2019 4:37:58 GMT by Ritchie
Make sure you have plenty of ventilation and don't use it in a confined space
It will come in handy even if you never use it
avg
Used fire extinguishers for a while no need to turn upside down. Local extinguisher company glad to get rid of out of date bottles as they cant do anything with them
Aug 15, 2019 20:24:56 GMT
12-14 lpm is what's recommended, it should work fine but never as nice a weld as argoshield light.
What size bottle is it? Might be able to assist with a regulator if it helps? 35litre. 1565796236869 by quickrack, on Flickr Help is good! Still looking, but I think one of my sons has lost/given away the one I had, so don't wait for me, sorry about that!
Aug 16, 2019 13:22:35 GMT
Still looking, but I think one of my sons has lost/given away the one I had, so don't wait for me, sorry about that! I appreciate the effort and the offer nonetheless! Thanks.
