Jul 26, 2019 16:23:37 GMT |
Afternoon all, a friend at work has just bought a 2006 Fiat Grande Punto as a cheap disposable runaround. It's pretty decent overall, but there's a couple of electrical problems (surprisingly enough for a cheap Fiat!), namely the passenger side window and the rear wiper not working. I've checked both motors and they're fine, so I suspect a problem in the loom, especially as the window keeps blowing fuses. Can anyone recommend a good auto electrician in the Wolverhampton area? I'm happy enough with older stuff but this is out of my comfort zone!
1968 Cal Look Beetle - 2007cc motor - [email protected] in full street trim 1970-ish Karmann Beetle cabriolet - project soon to be re-started. 1986 Scirocco - big plans, one day!
briang
Jul 26, 2019 22:28:48 GMT |
Sounds a bit like broken wires where they pass through the body into the door/tailgate. Might be worth a look for anything obvious before calling in the professionals? Brian.
robertferg26
@robertferg26
Sorry man, but I can give you the recommendation of an electrician only in Louisville. I worked with this Louisville electrician and I can really recommend him. I gave him a big check but it worth. I think that it is better to pay more but to be confident in a work that need to be done. Because good job need to be paid well. So, I advise you to search a professional and be ready to pay for his work. Sorry man, but I can give you the recommendation of an electrician only in Louisville.
