tristanh
Routinely bewildered
After clogging up the workplace with projects for years, I finally dug deep (literally and metaphorically), saved and took a loan, but at last I've a decent shed at my own house. 45 feet by 30 inside, 2x4 inch block with beaded insulation in the cavity, 6 inch slab of smooth concrete floor, with lots of steel in it, loft in one end, and a small loo. The roof is steel cladding, in a style reminiscent of a standard fibre cement slate roof. It worked out about 10k more expensive to build than a traditional steel shed, but it's literally metres away from my house, and in full view as you drive past and drive in, so I wanted something that looked more "house-ish" 2019, year of the garage.
tristanh
I started in February, as groundwork took place, you can see how close to my house it is, on the right of the picture. A few quick days later, we put the floor in, once the steel frame was standing and the foundations done. My nephew is the centrepiece of our family, so we did the obligatory "date the cement and put his footprint on it" Well, we're only human after all..
tristanh
Steel frame was done by a local engineering firm, all certified. Timber purloins rather than steel, as the planned roof needed timber battens, so a lot easier to nail to existing timber.
Superb building. Well done.
rickygolf83
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Now that's a shed. 👏
tristanh
Jul 17, 2019 10:15:32 GMT
tristanh
Jul 17, 2019 10:23:33 GMT
Quite a bit of battening in the roof. The nerd in me likes the way the uprights and roof carrying steel is bolted at an inclined angle, also you'll see the expansion joints in the floor. A simple consaw slit, later hoovered and refilled with a strong flexible grout.
tristanh
Aug 10, 2019 14:08:48 GMT
tristanh
Aug 10, 2019 14:15:40 GMT
So, got it blocked, felted and battened, then the roof went on. Metal cladding, in a style similar to a normal fibre cement slate. Then, to mark my 40th, a roadtrip. It was even cooler this year, as as well as 2 of my best friends, my sister and my 2 year old nephew came too. He's ruined already, loves cars and being in the garage. He enjoyed the trip too. A week or so.later, the shed progress had to be escalated, as I had a wind problem.. 😂 with my temporary storage. I wasn't laughing at the time.
Last Edit: Aug 10, 2019 14:16:57 GMT by tristanh
tristanh
Aug 14, 2019 23:17:40 GMT
I lashed on (lots) of white paint once it dried out, luckily I had the use of an airless sprayer. A Godsend. I decided that the toilet was ridiculously big too, so shortened it by about a metre after that pic above. Then, after ringing a bunch of floor paint suppliers, I rented a concrete floor grinder. Apparently there's no point painting onto the "fat" or "cream" that's on the surface of floated concrete, it's like a biscuit. And even though the floor looked great after being floated, as it dried and shrank, marks appeared. So cue a whole helluva lot of dust, and a full day swinging the grinding machine left and right. It was strangely therapeutic and relaxing though. And not difficult. The supplied hoover was way noisier. Lots of this,.... Made marks like this disappear.
tristanh
Next step was insulation. The wall cavity had bonded beads, I had myself convinced that spray foam was the way to go on the roof, til some concerns were raised by the company supplying the felt. So in a full about-face, I ordered 48 sheets of 8x4 foot foil covered insulation, got a few mates to help and rented a scissors hoist. A day did the bulk of it, and another day on my own finished it. I think it looks much better than the foam, brighter too, and worked out considerably cheaper. My electrician mates rocked up this week then, and I now have power! 20 double sockets, 5 x 16a sockets, and 2 at ceiling level, that can drop to a 2 poster. 2 highbay LED lamps, similar to these www.ie.screwfix.com/robus-sonic-led-high-bay-150w.html?utm_source=Google&utm_medium=CPC&utm_campaign=Shopping&gclsrc=aw.ds&&gclid=CjwKCAjwnf7qBRAtEiwAseBO_Hi6Zll55Wc0YOJUI9x7fkQuNVHNbf-LNPqoCUwgtT6u5DBTj70HlxoCR10QAvD_BwEAnd 6 LED lamps in the style of a twin fluorescent lamp. It's bright... Oh and 3 warm white lights for outside. Next big jobs are benches, shelves, racking for spare shells and a 2 poster.
tristanh
Aug 27, 2019 10:30:49 GMT
Any suggestions for a cool retro / vintage / steam punk type wall clock, either garage, Fiat / Lancia or VAG (water cooled) related?
Aug 28, 2019 14:05:19 GMT
That insulation must have cost some money🙈. Was contemplating getting it for my own workshop but couldn't stretch the budget anymore.
tristanh
Aug 28, 2019 23:30:48 GMT
That insulation must have cost some money🙈. Was contemplating getting it for my own workshop but couldn't stretch the budget anymore. It was well over 2k to spray foam it, sheets cost a little over half that. Plus a couple hundred more for screws, washers, timber, rolls of flashing tape, and hire of a scissors lift. And IMHO it looks so much better.
tristanh
Sept 21, 2019 15:06:33 GMT
So, to continue the theme of living off of noodles (only when they're on offer 😄) for the foreseeable future.. Something big happened this week.
tristanh
Oct 14, 2019 23:24:38 GMT
Plugging away, with the addition of a red stripe to break up the walls, and 2 coats of 2 pack floor paint. Darker than I'd ordered, but hey, it's good for hiding oil leaks I suppose...
Last Edit: Oct 14, 2019 23:26:51 GMT by tristanh
Ritchie
Club RR Member Number: 12
TedShed. Ritchie
@ritchie
Club Retro Rides Member 12
Mint, I plan to do the same at mine sometime, but it's not half expensive. I fancy incorporating a bar into mine, the projects might take slightly longer though.
tristanh
Oct 15, 2019 12:26:52 GMT
Thanks guys. Few mates calling this weekend for a bit of a "blokes meet up" so finishing touches like shelving in the loft, painting the girders in the walls and hanging posters to be done then. I'm quite happy with it tbh. I struggled for years without a shed of my own, to have a decent one now is just, well, it gives me a warm fuzzy feeling.
