rickygolf83
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Oct 23, 2019 20:15:23 GMT
It's crazy when you think about it super rare did you find thst on howmanyleft.com I usually take thr car off the road in the winter months so onky 6 on the roads then Yeah, on there. Been a couple of other Antibes owners posted on this thread, quite a few of them accounted for then lol
Oct 23, 2019 22:40:48 GMT
As you can see my sunroof looks more basic than yours no screen and wind handle
Oct 23, 2019 22:41:19 GMT
rickygolf83
Oct 23, 2019 23:13:07 GMT
Tilt only 👍 i don't recall my mums one being able to be wound back, first car with a wind back sunroof was the Orion in my signature 😁
Will ask her and my sister, see if they remember 👍
Mine is tilt only just now, haven't investigated any further into why it only drops on one side. Bound to be something obvious 🙂
Oct 23, 2019 23:26:40 GMT
Yes i had it off last week it started leaking on me so quickly put some tape on finally got around to looking at it I took the sunroof off and gave the seal a good clean so much rubish in it so fingers crossed that's done it
Oct 24, 2019 14:41:10 GMT
Guess the blue was only available for a couple of years then...makes it even rarer I suppose!
Most sunroof issues with that type I've managed to solve by a very thorough clean of everything, making sure the hinges are adjusted right (if applicable, not all can be adjusted) and giving the rubber a good coating of silicone lubricant. It's strongly hydrophobic so even if the seal is a bit marginal it will tend to discourage water from finding a way in.
Had one a good few years back (can't remember precisely which car on sadly) which used to leak like a sieve if you went near it with a hosepipe and I spent many weekends trying to resolve it. Eventually I realised that despite that, it never leaked a drop in normal use, so after that left it well alone and was just careful when washing the car.
Current fleet: 73 AC Model-70. 75 Rover 3500. 84 Trabant 601S. 85 Sinclair C5. 06 Peugeot Partner 1.6HDi.
rickygolf83
Oct 24, 2019 15:38:45 GMT
Seems to be, was a cavalier colour i think! If I could ban sunroofs i would! My VR6, 1.8t mk4 and mk2 golfs have them but I do not open them at all. Seals are doing their job and I don't want to provoke them
Oct 24, 2019 17:09:35 GMT
Funny that in that I've never had any major issues with sunroofs that weren't resolved by a good clean. Only major leaker was in one Saab and that was purely down to neglect by a former keeper meaning there was a tree growing in one of the drain tubes. Ten minutes with some old curtain wire had that cleared out and it never caused me the slightest issue ever again.
One which caused the most irritation by a mile was the one in my first Skoda. Not because it leaked, but because any condensation on it used to drip right in my lap whenever I turned left of braked in the winter...
I do think ones which are used occasionally are probably more prone to trouble though...mine always tend to be open if it's even thinking about being vaguely sunny so don't tend to have the chance to jam up due to misuse.
rickygolf83
Oct 24, 2019 19:39:41 GMT
Only issues i have had have been since i moved to older vw's and their seals tend to dissolve after 20years 😁
No leaks into the cabins though lol
Oct 24, 2019 19:52:45 GMT
the pop-up sunrooves were dealer fit
rickygolf83
Oct 24, 2019 20:07:48 GMT
the pop-up sunrooves were dealer fit Nice, looks like it has lasted well. I take it no drain channels would have been created and it relies on a very good seal?
Oct 24, 2019 20:16:57 GMT
I looked everywhere for drainage holes I couldn't see them
Oct 24, 2019 20:19:49 GMT
Thanks for the tip about silocone lubricant I will try that. To be honest I am not really much off a mechanic only ever done very basic things
Oct 24, 2019 20:23:02 GMT
I have a dealer fitted tilt sun roof in my Astra, damn thing leaks like a sieve, seals are shot as are the hinges, no spare parts I can find anywhere, not can I find a different sun roof that will fit. Siliconed it shut twice and both times a few days later I've opened it without thinking
Oct 24, 2019 20:26:55 GMT
I did a bit off digging and though its branded gm on the latch i have been told by a sunroof specist that its a Britax Mk2 Sunhatch. And replacements are available but i want too see if the cheap fix works first
Ricky looking through your posts it looks like you had some issues with your heater i was wandering do your cental air vents blow hot air mine only blows cool air and i only get hot air from vents on windscreen
rickygolf83
Oct 25, 2019 10:36:01 GMT
My blower doesnt blow at all, got it moving then it seized up again!
I have one to fit but cannot see a way of removing its cowling on the rain tray without wrecking it so have left it be :-(
Hot air does come out the vents though, both to windscreen and centre console. No side vents on mine though 👍
Oct 25, 2019 17:08:35 GMT
Ricky looking through your posts it looks like you had some issues with your heater i was wandering do your cental air vents blow hot air mine only blows cool air and i only get hot air from vents on windscreen thats a vauxhall thing of that period, astras are like it too. p.s the heater blower are identical on mk2 astra and mk2 cavalier (that is to say the turbine/motor and the plastic housing) but the actual motor/turbine and resistor pack are identical on nova astra, cavalier
Last Edit: Oct 25, 2019 17:08:52 GMT by darrenh
Oct 25, 2019 19:25:05 GMT
Thx guys really glad i found this thread I may pick on your brains again
rickygolf83
Oct 26, 2019 19:30:31 GMT
Was out in Nova this afternoon, and can confirm that the centre dash vents only have cold air when hot to the screen! Every day is a vauxhall school day it seems! Had a wee fiddle with the idle position and mixture as it wasn't running right again, and struggled to idle without choke. Now idling well even with lights on etc... May be slightly high but all good in my opinion Got a thermostat, timing belt and pump to fit. Hopefully get round to that soon, but exhaust, front struts and bearings to do on the wife's 1.8t to do 1st....
