May 16, 2019 18:02:43 GMT |
A bit worried about the noise levels. Mine is around 99db at idle but at 3000 rpm its nearer 112! (at IVA distance measuring - quite near exhaust exit) Any idea how they test and how near the mic is? (drive by backed off is quiet)
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
May 16, 2019 18:38:12 GMT |
A bit worried about the noise levels. Mine is around 99db at idle but at 3000 rpm its nearer 112! (at IVA distance measuring - quite near exhaust exit) Any idea how they test and how near the mic is? (drive by backed off is quiet) Mine was over the limit last year - first reading was 108db and after a few tests it was within limit and passed - they will help you get through it 😉 it’s a static test and then monitored readings around the track.
Last Edit: May 16, 2019 18:39:39 GMT by GavinJ
bstardchild
Club RR Member Number: 71
May 16, 2019 18:39:08 GMT |
A bit worried about the noise levels. Mine is around 99db at idle but at 3000 rpm its nearer 112! (at IVA distance measuring - quite near exhaust exit) Any idea how they test and how near the mic is? (drive by backed off is quiet) Tell teh tester it's a long stroke - max rpm 5000
ferny
Club RR Member Number: 13
May 16, 2019 18:47:41 GMT |
Just paid for the autosolo, but can't find the edit button on the events site.
bstardchild
May 16, 2019 18:50:53 GMT |
Just paid for the autosolo, but can't find the edit button on the events site. Don't worry about it......... We've had way to much fun with the track side to do the same thing with autosolo Ping an email to [email protected] with I've paid
bshaw
May 16, 2019 19:08:47 GMT |
I just sent an email over about this, and messaged you on facebook haha, ffs, should've looked here 1st Well you have my order number in an email now, so I guess that's the "I've paid" email sorted. Cheers for accepting, didn't expect it tbh Hope I don't kill it, got a trackday end of the month too
May 16, 2019 21:22:26 GMT |
A bit worried about the noise levels. Mine is around 99db at idle but at 3000 rpm its nearer 112! (at IVA distance measuring - quite near exhaust exit) Any idea how they test and how near the mic is? (drive by backed off is quiet) Tell teh tester it's a long stroke - max rpm 5000 So I guess open headers are out then
A bit worried about the noise levels. Any idea how they test and how near the mic is? (drive by backed off is quiet) If it's anything like a normal track day setup the DB meter will have a long stick on it so it's tested at aprox a meter from the tailpipe
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
May 17, 2019 10:26:33 GMT |
Looking forward to the auto solo on Sunday morning
820
May 17, 2019 12:43:27 GMT |
The static noise test 105dB is it at a fixed RPM? thanks Jim Whoops missed this post as I said I would reply 75% of RPM limit No problem, you have enough on your plate these last few weeks. I did not apply in the end, next year definitely though. Have a brilliant weekend all.
