Some great work done there again! Maybe a silly question but should the car be sstanding on its wheels when you do these structual repairs. Because it is a convertable, it will always sag a bit Thanks again for posting these projects as it is a fair bit of work and great fun for us! Peter Peter - The car is based upon a very strong tubular chassis (designed by the legendry team at ERA - English Racing Automobiles) - there is not that much flex in the chassis - but its a fair point that you make and should always be considered - I have seen this catch others out before today on convertibles fitted with weaker chassis structures
Last Edit: May 12, 2020 7:23:56 GMT by Deleted
GN, with this being such a low productions car, would the exterior panels have been made with English wheels and other traditional handcraft technicques (as opposed to being stamped)? Thanks, John John - Absolutely the panels were all formed by hand and tested / tried against a buck - the rear shroud section is made up several pieces and the bonnet in 11 pieces - it would have been pretty heavy going too its all 2mm + thick alloy sheet that its formed from
I hadn't realised before that the rear suspension seems similar to a Frogeye Sprite with the upper torque link and lower sort of quarter elliptic arrangement....I also didn't know about the ERA connection. However I did know that they were highly regarded and competed at Le Mans in the 50's....I think?? Great work - as ever GN!
I hadn't realised before that the rear suspension seems similar to a Frogeye Sprite with the upper torque link and lower sort of quarter elliptic arrangement....I also didn't know about the ERA connection. However I did know that they were highly regarded and competed at Le Mans in the 50's....I think?? Great work - as ever GN! Phil - Its torsion bar suspension all round - and yes very much a Le Mans competitor - winners of the under 2 litre class in 1950, 1951 & 1952 - very much a underrated / under estimated car
Some great work done there again! Maybe a silly question but should the car be sstanding on its wheels when you do these structual repairs. Because it is a convertable, it will always sag a bit Thanks again for posting these projects as it is a fair bit of work and great fun for us! Peter Peter - The car is based upon a very strong tubular chassis (designed by the legendry team at ERA - English Racing Automobiles) - there is not that much flex in the chassis - but its a fair point that you make and should always be considered - I have seen this catch others out before today on convertibles fitted with weaker chassis structures Thanks Chris. I found out that when i put my P5B on 4 axle stands on the jacking points, the doors do not close as well as when the car is standing on its wheels.Luckely i did the sill and other structual repairs with the car on axle stands under the axle and front suspension so all was fine.
Peter
What were/are the ugly welded strips in the front wings for? Semaphores?
May 12, 2020 11:18:32 GMT
What were/are the ugly welded strips in the front wings for? Semaphores? Mark - Originally yes - obviously someone has plated over them with gas welding - just something else for me to sort
May 12, 2020 19:18:50 GMT
So I tackled the nearside structural welding today Really just a repeat of the work that I did on the offside yesterday But now I could complete the B post base & extend the repair On both sides Then tied the support tube into the inner sill And that is the structural welding completed on the nearside This is the original floor support brace but its been messed with before today so I am going to replace it with new Spans between the inner sills Like so Just need to cut & weld in the new seat support braces in the morning But another quite productive day - more tomorrow
Last Edit: May 12, 2020 19:23:17 GMT by Deleted
May 12, 2020 19:51:11 GMT
See what you mean about a rigid chassis. You’d never believe that was from the era it was, remarkable.
I can feel how solid that is becoming again from here, Grumpy!
super nice!
JP
Seat support braces cut & tacked in Fully welded & dressed back ![](https://img.retro-rides.org/i/v/grumpynorthener/daa7adb4ea13.jpg) Now I need to make a start on getting the A post repairs more permanent This is a fiddly time consuming job to get right It involves the door being removed & refitted on several occasions in order to keep checking the clearances & hinge positions Trimmed back & tacked up The door gets refitted at this stage and any minor adjustments made prior to fully welding the repair areas up Strengthening plate added to the base of the A post to provide support for the lower hinge that is bolted beneath it Fully welded on the two faces And dressed back I have a repair section pre made to close the front face of the A post But there are several other jobs to undertake first before losing the access - one of them is sort the remaining areas on the outer face of the post out - its seen several er lets say fillered over repairs I(if you can call them repairs in the first place) - more later
May 14, 2020 11:29:33 GMT
looking great, those cars look like a perfect example of how not to design a car for corrosion protection!
May 14, 2020 18:21:15 GMT
looking great, those cars look like a perfect example of how not to design a car for corrosion protection! Kevin - Its like all cars of that era - nothing was thought about when it came to preventing rust ingress
May 14, 2020 19:12:34 GMT
Another day sorting the A post out - Its a critical point - get it wrong and nothing else on the car will fit - so its steady progress - measure 3 times - cut & weld once etc Floating plate made up in order make the bottom hinge nuts captive - just retained by a couple of spot welded tangs Cleaned the inside face of A post panels up And then applied a 2 coats of Hydrate 80 to them Welded a blanking piece to the end of the sill cavity I like to flood the sill cavities with cavity wax Via a couple of pre drilled holes - these will be sealed with grommets once the car is completed Next was to sort out the remaining areas on the A post face panel - the car originally had semaphore trafficators fitted to it when new But these tend to get deleted and replaced with flashing front & rear indicators - owners then have the trafficator aperture welded up / plated over has this is just a point of water ingress - that's exactly what they had done here - only not very well - gas welded with heat distortion around the repair areas and although I could not see it when I placed my hand to the rear of this area I feel a open seam Old repair section of the A post face removed - if left the open seam would have created issues further on in the cars life New repair section formed and shrunk on the flange edge to form the curvature Tacked in Fully welded & dressed back Top hinge support brace being trial fitted Bolts to the bulkhead chassis mounting Then to the top hinge - Need to set all this up to determine the hinge plate location on the brace that has to be welded insitu Then the A post support brace A post closing panel - still requires a few more adjustments prior to being fully fitted - the a post support brace gets plug welded to rear face of the panel and the hinge support brace bolts through the panel on the hinge back plate But whilst I have the access now is good time to seal the seams - More tomorrow
Last Edit: May 14, 2020 19:15:06 GMT by Deleted
May 14, 2020 22:30:11 GMT
That top hinge mount is crazy! John
Last Edit: May 14, 2020 22:31:19 GMT by jjeffries
That top hinge mount is crazy! John John - The very early production cars did not have this fitted or the diagonal A post support brace back to the bulkhead - It was quickly found that the early cars suffered from the top door hinge sagging & scuttle / bulkhead shake - hence the early cars were recalled and the two braces added - later cars like this one were all factory fitted with the braces as standard to rectify the problem
Last Edit: May 15, 2020 6:27:17 GMT by Deleted
May 15, 2020 19:47:27 GMT
Front A post closing panel now trimmed to fit But I had to remove the bottom flange on the A post in order to slide it in At the factory this panel would have been fitted from the rear to abut the flange and the door face of the A post fitted last - hence the flanged swage edge that they could access with spot welds With door side face panel of the post remaining I don't have the luxury of being able to access it with the spot welder - hence it will be plug welded Welded Dressed back Brace welded to the bulkhead And the top hinge brace Now fully fitted Shims made up for the top door hinge & fitted Note my use of hinge alignment location pins - these get removed once the hinge is bolted up in the correct location The 2 brace apertures to the bulkhead return panel will require closing plates fitted around them but I will deal with them once I have the offside A post completed then I can make a matched set up for both sides Bottom door hinge refitted And the door rehung ![](https://img.retro-rides.org/i/v/grumpynorthener/1ac0ad04c04c.jpg) Hinge alignment pins used throughout The door gapping still needs work but is basically where I need it in order to panel the rest of the car Its tight at the top front edge on both sides (normally is on all Jupiter's) - this I shall deal with in conjunction with the upper bulkhead repair around the windscreen frame mounting Rear edge is ok at the top But very poor in the side profile at the bottom - I will deal with this has I rebuild the lower part of the B post - plus the entire section of the outer quarter panel is being replaced from the swage line down Just the spotweld indents drilled to complete the nearside A post And found time to weld the propshaft cover into the front bulkhead - which just requires dressing back I will make a start on the offside A post in the morning
Last Edit: May 15, 2020 19:54:06 GMT by Deleted
May 16, 2020 10:48:41 GMT
Having done a couple before must really help sort out in your head the order each process has to be done in... it would certainly do my head in - I'm getting stressed just reading about it! Great posts as always, love the detail and how it all comes together and makes sense at the end of each sub-process! Thanks.
May 16, 2020 12:49:25 GMT
Having done a couple before must really help sort out in your head the order each process has to be done in... it would certainly do my head in - I'm getting stressed just reading about it! Great posts as always, love the detail and how it all comes together and makes sense at the end of each sub-process! Thanks. Yes it does help knowing what direction to head in - just has well I only have another 4 Jupiter's in the pipeline to restore over the next few years ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) (amongst other restoration projects) - but I like doing the write ups has much as the physical restoration side of things - plus it documents the restoration for the owners
Last Edit: May 16, 2020 19:57:28 GMT by Deleted
May 16, 2020 20:03:50 GMT
A few bits advanced this morning Propshaft cover dressed back after being welded in Made a start on the offside A post - door removed to allow access once I had drilled for hinge alignment pins A post face & base repair panel that I had previously fabricated tacked in Inner door face to post patterned up Fabricated & trail fitted Ready for tacking up and then the door can be refitted to check for fitting & tolerances More on Monday
