PhilA
Byte Wizard
Jan 10, 2022 20:12:26 GMT |
Glad you're enjoying it. I drove one and it felt like the least exciting, most grey porridge vehicle. It just did car things in a very efficient but at the same time incredibly bland way.
But, that was coming from driving a little Italian car about, so maybe I was judging it unfairly.
This afternoon I decided to have a look at the key to see if I could do anything to tidy it up. I also wanted to get into it to confirm if it had an immobiliser chip in or not so I knew which type of spare to order. Currently I only have the one key and that's always a recipe for stress in my mind. The key looked like this...which is why I was determined to try to tidy it up a bit.  The fact that the tape was decomposing and sticking to every bit of pocket lint (or in this house, the omnipresent dog hair) was also rendering this high on my to do list. Like a complete and utter idiot I didn't wear gloves while pulling this to bits...and of course the mixture of electrical tape and duct tape had both well and truly started to decompose into the stickiest goo known to human kind. Said goo is now all over my hands, desk, keyboard, mouse, phone, probably in my hair - and all over everything within about a 500 metre radius. Rookie mistake. Oddly when I pulled it apart I couldn't see anything wrong...all three bits of the assembly click together firmly, and the flexible membrane on the side with the remote buttons on isn't split. Testing the two CR2016 cells showed they were both fine, so I just reassembled everything after a good clean. Oh, and yes it appears the van does have an immobiliser as there's a chip in there.   Sure enough, the light on the key did flash when buttons were pressed...so I went out and walked through the key synchronisation routine, resulting in... We appear to have fully functional remote central locking again. I'll take that as a win! Though I did notice this mess in the engine bay when doing a check for oil leaks following the change yesterday...  Which is moderately concerning. I know this van did at one point have an aftermarket alarm (which doesn't appear to function), so I wonder if this was a result of a refusal to shut up one time to often - the loom tape does make it look different to the main vehicle loom, which is why my first thought was alarm. I will definitely be checking to ensure there's not power there shortly.
Current fleet: 73 AC Model-70. 78 Vauxhall Cavalier 1.6GL. 85 Sinclair C5. 90 Mercedes T1 (208D) AutoTrail Navajo. 02 VW Caddy SDI.
Taking a closer look at that wiring mess reveals the tail is attached to the aftermarket alarm sounder...so that's definitely thoroughly dead then. Good thing I erred on the side of "I don't think so" when asked by the insurance company if it had an alarm. I'll pull that out then and see if I can find the other end of this to at least confirm that there's no power going to it. Yay, I get to stand on my head under a dashboard again! On the running theme of seeing if I can get vehicle systems back up and running I made a run over to Formula 1 in Newport Pagnell so this could happen.  While the AC system was totally flat when I got the van I had noted on my first inspection that both service caps were loose, plus the condenser looks way newer than 20 years and 100K miles...have to wonder if a new one was fitted at some point and they just never bothered gassing it up? I still have a bottle with some dregs of dry nitrogen from goodness only knows how many years ago, which in its last gasp shoved around 40psi into this system a few days ago. Checking this morning showed the pressure hadn't visibly dropped. Having something in there had also allowed me to check that the compressor clutch worked and the compressor ran - albeit only for a couple of seconds as I had no idea if there was any oil left in the system. It was a tense 30 minutes while the system ran the vacuum decay test (which basically is a leak check to see whether any air leaks back into it) was carried out - zero decay reported. Which says the system should hopefully be gas tight. It also shows it's reasonably dry (as water boiling off from the drier core etc would result in a *small* bit of vacuum decay). Machine was happy with all of the tests and charged properly. Real test was going to be starting up, pushing the button and seeing what happened.  I should really have had a camera pointing at the service gauges to video it, but suffice to say they behaved exactly as expected. It's a bit hard to tell you'd think when it's all of 6C outside, but the system was definitely working. Suction line definitely got cold and there was heat quickly apparent on the liquid line. Definitely colder than ambient air coming out the vents too... exactly what we were after. No nasty noises from the compressor (that I can hear over the rattle of an SDi idling next to it anyway...though I'd by lying if I didn't admit it's a lot more refined than an XUD). Having working AC should really help me deal with the bit of damp in the cabin. Basically we'll run the heater at "as warm as I can deal with" on recirc with the AC on for a while and see if that helps. As the air con dehumidifies the air passing through it, that will help actively pull water out of the cabin. Next significant jobs in mind: [] Exterior clean. [] Dismantle and clean EGR system as it sure it's thoroughly sooted up. Especially given I've no idea how long that vacuum leak had been playing havoc with things. Can't see any obvious signs of it having been apart before, so it and the intake pipework will be well due a clean if that's the case. [] Paint front bumper so it looks slightly less scruffy. Longer term I have an idea in mind regarding the paintwork as a whole...open to inspiration that others might have too though. I'm already finding myself really quite attached to this little van so I'm going to try to make a reasonably tidy job of things. The rust around the window over the cab will be getting sorted and we'll see what we can do for the offside rear quarter too before the aforementioned larger scale paint job too. What colour do *you* think she should be painted?
If your going to respray it, it should stay the colour it came out of the factory. Then there is no need to faf around with door shuts, or under bonnet paint. Its a good colour, even though fairly common.
Jan 14, 2022 12:35:20 GMT |
Some good results all round with this - central locking, aircon, etc. Nice work. White, with the Vatican City flag on the doors to be a pretend Popemobile?
Couple of days ago I pulled the heater controls out and sorted the illumination. Not really important, but the lighting not working was bugging my OCD something rotten. Just the one lamp lights the whole set of control knobs via a bunch of light pipes in the unit and the faceplate.  Sorted.  Which makes the dash look a thousand times better I reckon.  Just something about being able to see that lamps are out in the dash to me always makes a car feel shoddy and neglected. Of course about ten minutes later I spotted the light in the cigarette lighter is still out...D'oh! No big deal really, I need to take it apart again anyhow to sort the temperature control knob. This is currently controlled by a cable sticking out in the cubby hole by the gear lever. The reason for this is that a bit of plastic has broken off the back of the mechanism here.  There should be a metal clip there to grip the outer sheath of the cable (as on the red and white cables at about 4 o'clock in the above photo. Everything to the right of the red line here is missing.  This is a really common issue with these it seems, usually resulting in the heater being stuck on hot, as when you turn it down rather than pushing the cable inner which operates the air blend flap, the whole cable just gets pushed away from the back of the control assembly. Fortunately the control assembly was fitted to several VW models and used for a few years so they're not hard to find. I've ordered a used one (for a whole £12) which looks to be intact from the photos, and will add some strengthening to the underside of that area to hopefully prevent this happening again. There's no point really in trying to repair the one in the car at that sort of price, especially as three out of the four lugs which it's secured to the dash by have also snapped off. The silver paint isn't bad, but it's just a bit bland for me. I'm just not a "resale silver" sort of person. Given that the basis of this van is a 6N Polo, there was something I had in mind even before I'd picked the van up. One of our neighbours back in the late 90s had a Polo which I always thought was exceptionally smart as it was a Harlequin special edition. For those who haven't heard of it, This is a Polo Harlequin, courtesy of Wikipedia . This is a very, very, very quick photo edit I did to put my thoughts down on "paper" to have a think about how to execute it.  The fact that my van doesn't have a cargo door complicates things slightly as all the original cars were 5-door examples. Using the rear door colour on the whole rear quarter solves that, but then you also need to change the colour of the rear bumper as it's shared with the rear door which on the car would have had a different coloured panel between them. It may not ever even happen, but it's definitely an idea I intend to pursue. The bonnet has a few dents in, so just finding another in the correct colour would save me having to paint that and sort those in one shot. Sadly I suspect finding the blue leather rimmed steering wheel and gear lever the Harlequin cars were fitted with isn't likely to happen at an agreeable price, as a little colour in the cabin wouldn't be a bad thing. A few folks have suggested that a vinyl wrap may be a more sensible way to go than repainting everything, so that will definitely be looked into. A couple of bodywork professionals will be contributing thoughts here too as I want a couple of rusty areas properly repaired before we start painting/wrapping anything.
Harlequin and noticeably different wheels. So people know it is “Special” I always think that if you are making the effort to repaint a car, it has to be stock standard or radically different like this. My dad used to have no issue with getting a 3 year old car colour changed, maybe where I get it from. My first car, a 79 Datsun 140Y, came back in late 1981 from the operational area on a pass and it was not white anymore. Three years later it was painted again, blue this time for my brother.  Change is good. Your paint may only be limited by your budget. I say go big.
Jan 16, 2022 20:21:05 GMT |
Harlequin and noticeably different wheels. I’d keep a look out for the 16” alloys which were optional on the Harlequin… standard fitment was the Polo 16v
Ich habe kein Geld!
Harlequin and noticeably different wheels. I’d keep a look out for the 16” alloys which were optional on the Harlequin… standard fitment was the Polo 16v I actually think the wheels on there look okay, though they really need to be properly painted and with black or dark grey centre caps. It definitely won't be getting bigger wheels or lowered suspension...the ride is firm enough as it is and I appreciate my spine remaining intact! Softer shock absorbers are something I may well look at down the road. Today was time to have a look at the EGR valve to get an idea of how gunked up the system really was. By the standards of most modern cars it's thankfully pretty easy to get to. The arrow is pointing at the vacuum actuator rather than the valve itself, but you get the idea.  Given the position of the securing collar I don't reckon it's ever been off. However the innards weren't anywhere near as bad as I was expecting.  Yes it's pretty grim, but I'm not unused to seeing these things totally choked solid on far newer vehicles. Probably about 0.5mm worth of caked on gunk the whole way round. The other side of the valve is more disgusting as it's sticky, tarry curse word as the PCV system feeds into the EGR circuit right next to the valve. I did dig an appreciable amount of gunge out of the valve body, but it definitely wasn't totally choked nor did it seem to be sticky.  I'd also been able to confirm that the valve is sealing completely and consistently when closed. Reassembled everything...and absolutely no difference. Very slightly surging engine speed still there (it does exactly the same at any engine speed I found, regularly once a second), along with excessive smoke on light throttle. Definitely have vacuum at the EGR valve, and you can hear it physically snap shut if you pull the vacuum line off. It however doesn't really have any noticeable effect on the running of the engine either way. One thing I did notice is that when this behaviour is present, the rev counter also behaves slightly erratically, randomly twitching upwards from the actual engine speed - and it seems to do it more when on the throttle than off. Then out of nowhere, the engine completely smooths out. The note deepens (because the flap on the intake, which I assume works in partnership with the EGR valve is now fully open), and the diesel clatter becomes a little sharper, so something has obviously changed - I'm guessing with the injection timing. Checking the EGR at that point shows there's no vacuum present, so the ECU isn't calling for the EGR system to be in operation. It's also noteworthy that after this point when things decide to behave that the rev counter twitching also stops I'm increasingly convinced these two symptoms are connected in some way. So I don't think the EGR valve is the cause of this issue...bit it's definitely *involved* in it. Think the next step really will be to find someone locally with VCDS and get a look at some real-time data. Everything being fly-by-wire here makes guessing pretty pointless... imagine on a newer car we'd have a check engine light illuminated - but this car doesn't have one! The rev counter misbehaving being clearly tied into it is making me think camshaft/crankshaft position sensors? Or however else the ECU gets the engine speed/position data...makes sense though if there's a disparity between the requested and reported engine speed, it would throw the fuelling all to hell. Think it's likely been like this for a while so I'm not worried about it really, but I'll be damned if I'm not going to try to get to the bottom of it. Especially as the van drives so much nicer when this fault is staying out of the way. We got any SDi experts on here? Oh...and I've ordered a replacement engine cover. Looks quick and easy to fit/remove unlike many, so I'm not adverse to its being there. Something which may well be getting changed in the not too distant future - which is a shame as they're only a year old - is the tyres. I had to brake moderately hard to avoid a suicidal pigeon this afternoon and discovered that these tyres really aren't great on a cold, damp road. Also the front ones have way more grip than the rears...great, aside from when all four wheels lock up, then the front regains grip well before the rear - which by then has started to try to overtake the front. It was a moderately firm braking manoeuvre, but I didn't expect quite *that* degree of upset. Even the big van would have been okay. Methinks some Uniroyal rubber may be in the future. I will get the tracking checked in the meantime though - not least because the steering wheel is slightly off straight and means I can't see about 2/3rds of the warning lights on the dash when driving straight ahead. Bit of a daft design there from VW. Likewise the switchgear most of which is hidden behind the steering wheel.
jamesd1972
Club RR Member Number: 40
Sounds like cold hard rubber meets slippy road as much as a poor tyre issue? I had a very low speed oversteer moment in the LR the other day which was a surprise and road didn’t look too bad. Suspect that max loading Suspension weights on things like this are so high that unladen grip at the rear and stiffness can be an issue.Be tempted to cross check the eu label on the rubber before making any expensive decisions. Surprised this didn’t have ABS. If the cars a keeper I’d be more tempted to look at a set of winter tyres as a solution, way more grip and you’d get a set of spare wheels for pretty much free as well. Weirdly winter tyres are also vey good on wet grass if that’s a factor on dog run usage. Going to miss the w123 updates but get why a cheap dog van like this makes sense, if it fits in and does a job well the slow boring factor doesn’t apply. Hope to get to the bottom of the reving issue inexpensively. James
westbay
Have you checked the throttle body? The tachometer fluctuation and engine surging point to this ... clean flap / butterfly and housing contact point with brake cleaner and an old toothbrush ... ..and check the state of the gasket
Last Edit: Jan 17, 2022 9:10:28 GMT by westbay
1995 Rover 416SLi Tourer 1965 MGB Mk1 Roadster
1984 Honda Nighthawk 650
Horsepower is how fast you hit a wall. Torque is how far you take that wall with you
Jan 17, 2022 12:02:06 GMT |
Have you checked the throttle body? The tachometer fluctuation and engine surging point to this ... clean flap / butterfly and housing contact point with brake cleaner and an old toothbrush ... ..and check the state of the gasket  If that would impact the behaviour of the tach then it's definitely a decent shout as it is pretty grubby. I really need to read up on the method of operation of this system...first time I've ever seen a throttle butterfly on a diesel engine (I'm assuming it works in concert with the EGR to balance flow from there/fresh air when that system is active). Need to pick up some more cleaner, ran out of it yesterday!
rodharris83
Day Dreamer...
Jan 17, 2022 13:04:46 GMT |
Harlequin and noticeably different wheels. I’d keep a look out for the 16” alloys which were optional on the Harlequin… standard fitment was the Polo 16v Here's a picture for reference...
Jan 17, 2022 21:36:59 GMT |
Polo Caddy I saw at Woerthersee one time, if it helps! and one I saw at Bug Jam
Last Edit: Jan 17, 2022 21:39:40 GMT by DarrenW
This surging behaviour seriously has me intrigued. Managed to catch it doing it again today and got a better video properly catching it. This clearly shows how it's essentially a regular "blip" approximately once a second that happens irrespective of the engine speed - and that during this behaviour she chucks out a shedload of smoke. You can always *smell* that something is off when it's doing this, the smell from the exhaust lingers for ages. If you're in a car following it, it makes your eyes water apparently. Physically disabling the EGR valve by removing and plugging the vacuum line to the actuator has no effect. I know the valve is moving as you can clearly hear it snap open or closed - and it sealed well enough that carb cleaner wasn't even seeping through the orifice while I was cleaning it yesterday. So I think the valve itself is innocent. However if I unplug the *electrical* connection to the solenoid valve which controls said valve, the problem completely goes away. Idle immediately smooths out perfectly (it sounds to me like the injection timing or duration also changes as the engine note itself does change too), you hear the throttle valve in the intake snap fully open, and the throttle response becomes perfectly smooth through the whole rev range - and we see absolutely zero smoke aside from the expected tiny initial puff of black if you absolutely boot it, and that's not enough to be visible in the headlights of a following car. Also notable that any noticeable smell completely vanishes too...it just smells like an early 00s diesel VW. Now I'm sure unplugging that would trigger an engine management light if I had one and I'm sure will have logged a fault code, and disabling an emission control device like this is illegal, so it's not a permanent fix...however it provides me with useful data to add to my diagnostic process and *definitely* puts the van in a less polluting state while I get to the bottom of the root cause. You've seen the cloud if you've watched the video above! I need to make my reading today working out exactly what the sequence of operation is for the various bits of the emission control system on this engine and how the various parts interact with each other. I get the impression that understanding how that lot works will shed some light on what might be happening. Decided that the Caddy could have a day off as errand running workhorse today so the main title of this thread can make an appearance!   Which went absolutely fine until I heard a suspicious "ding" at one point and saw something small and round disappearing into oblivion behind me. When I eventually found somewhere safe to pull over, the cause didn't take long to find.  Ah. That's sub optimal. The air filter element was still present, wedged between the chassis and suspension arm thankfully (as they're surprisingly expensive), however the cover plate and wing nut are long gone. Even if I could spot it, as with so much of MK there's nowhere safe to pull over to retrieve it safely as it's on a 70mph dual carriageway with no pedestrian provision even vaguely nearby. So I'll need to find a replacement. Thankfully it's a bit of standard Steyr-Puch engine rather than a bespoke bit of Invacar so shouldn't be difficult to track one down, even if it may mean getting a whole new air cleaner assembly. Guess we need to add "check air filter element retaining wing nut is tight" to the weekly checklist!
Today's automotive task: Get rid of this bodgery behind the heater controls in the Caddy.  This is a close up of the broken bit of plastic on the back of the heater control assembly.  Which SHOULD look like this.  Thankfully as I expected the base units are identical, just mine has a few extra bits on being from an AC equipped car. Mine:  New (used) one:  Underneath:  These (plus the white plastic lamp cover I later realised) are what need to be transferred over - and the faceplate obviously.  The greenish plastic thing in the middle is the light pipe which illuminates the indicators in the AC/Recirc buttons green when the headlights are on and the controls are off. It needs to sit in front of the main light pipe assembly, but thankfully that unclips easily enough. The one on the right illuminates the legends on the aforementioned buttons...and getting that sucker into position here is a royal faff, especially as you're acutely aware of what a tiny, fragile bit of plastic it is.  Really glad I had the sense to photograph the order these sat in before pulling anything apart.  This is what the top of the switch assembly looks like.  Whole new unit back together now with my AC specific bits added.  I initially didn't realise that the white lamp housing is slightly different, as the AC specific one is slightly shorter to allow it to fit over the additional light pipes. The part numbers are different, confirming I wasn't just being daft. AC one:  Non-AC one:  Though if you're doing this job you've likely got a complete but broken assembly in front of you anyway, so really not an issue. If robbing bits for an AC conversion though worth knowing you do need it. After a small amount of swearing at cables (they are *precisely* as long as they *need* to be). I wouldn't be at all surprised if that's a large part of how that bit got snapped in the first place. Wouldn't be hard to put a load of strain on there when installing a stereo or routing any wiring behind the dash.  Having all four mounting lugs now present both the heater controls and the black surround on the front of the dash is far more secure. While I was in there I pulled the cigarette lighter out to replace the failed lamp in that.  That has to be one of the most frustratingly difficult to access lamp holders I have ever come across. I did eventually though manage to extract and replace the lamp. Result being (finally) all of the dash illumination working.  Albeit with a moderately annoying amount of light leakage from the vicinity of the cigarette lighter. It really needs some assistance in the light-tightness department.  Next interior target will be the offside outer heater vent which is missing a large chunk of itself.  Which I have a suspicion will end up coming from the same breakers I just got the heater control panel from. I'll probably do the headlight control panel too as it's not securely fitted, I'm assuming because a mounting tab has broken or something like that behind it. The little storage cubby for documents under the dash being screwed shut with self-tappers may make it onto the list too as I can't unsee that now! Small steps, but nice to have fully working heater controls again without needing a cable sticking out under the dash. For the sake of £12 of parts and maybe an hour of time, hard to say no really.
Jan 22, 2022 23:56:32 GMT |
Been a little while since I had the time to do a proper update so let's have a catch up. The Caddy passed a nice milestone while we were on the way to an appointment a few days ago. Thankfully I had my other half with me so was able to get evidence of it...as I was on the M1 at the time I couldn't exactly pull over to grab a photo.   Hopefully many more to come. A surprisingly large parcel arrived - even more surprisingly quickly given it came all the way from Germany - for the Caddy. Got here quicker than some things ordered from an hour up the road.  Hardly mission critical, but definitely tidies things up a bit. Does make quite a noticeable difference to the noise level outside the van too so isn't entirely cosmetic. I usually hate engine covers, but this only takes about 90 seconds to install/remove and makes a good tray for putting things in so isn't a huge problem. Does look like it's taken about ten years off the engine bay though!   While I was rooting around in the area I dropped the new cabin air filter in. Dead easy to get to compared to many modern cars which require you to stand on your head in the footwell and/or dismantle half the dash.  I'm quite used to seeing these having never been changed so was half expecting a solid black rectangle of unidentifiable organic matter to come out, but it wasn't actually too bad. Definitely due a change but it's definitely been changed sometime in the last few years.  You may recall me noticing some horribly hacked wiring in the engine bay related to the obviously long defunct aftermarket alarm system a little while back.  Which had also left a gaping hole in the bulkhead.  I've now found that end of the tail (buried behind the heater box), and each of the wires has been taped, heat shrink covered then the tail as a whole treated the same way. The actual alarm module is buried up behind the centre console and I didn't have the patience to go chasing that further today. This lot was pulled out.  The above area now looks like this. By pure chance I found a bung sitting on the drive that was exactly the right size to fill the hole left by that alarm wiring.  Much tidier. A friend dropped by today with their fancy diagnostic gizmo to see if we had any fault codes stored which might give us a pointer on what's going on with the twitchy idle/EGR issues. As we had hoped there were a couple of codes stored.  The first of which is the interesting one. "Motor for intake flap (V157) - sporadic - open/short circuit to earth." The second code is expected as it's indicating the solenoid for the EGR valve being open circuit - because I've unplugged it. This is really useful as it gives me a component to home in on with my investigation. First port of call is to make sure the wiring to it isn't obviously damaged as it is quite exposed. Then we'll give it a good clean, which it really wants anyway. Tomorrow's task is going to be putting together the contents of this very heavy box, which arrived too late yesterday to do anything with...but should solve my pressure washer situation.   Should be a decent upgrade from a fairly low end electric pressure washer...and having 30 metres of hose to play with will be a massive help in itself compared to the four I'm used to. Putting that all together will be tomorrow afternoon's task. A silly little accessory arrived yesterday for the Invacar.  Suitable replacement for the keychain that I somehow managed to lose back at the start of the pandemic. Have also come up with a temporary solution to the air filter issue. This doesn't look in any way ridiculous...  To be honest it's basically only there to keep crud out of there until I can track down/manufacture a replacement for the missing bit of the cleaner housing. I won't be driving it like this given the insurance company may declare it's a performance modification...must be good for at least a 30% power increase of course! I think that brings us up to date for now.
Well this box arrived on Friday...  What was in it then? Well after about half an hour's assembly, this:  Assembly was about as simple as you could ask for - all the necessary tools and some PTFE tape were in the box.  The biggest complaint I'd seen from people in reviews of this unit was that they were managing to melt the hose that runs between the pump and hose reel on the exhaust. Have to assume they had it routed over the top of the engine...  Simple solution, route it down underneath and apply a couple of cable ties to ensure it can't get in the way.  Yes the reel is very obviously an afterthought they just managed to find space to bolt onto the frame as it does make getting to the pull start a bit awkward.  Really not badly though so long as you've uncoiled the hose, which you're meant to do before starting the engine anyway - and having onboard storage for the hose is worth it I think anyhow. Speaking of the hose... I've got used to the pathetic four metre reach on the old cheap plastic electric one, so having twenty metres to play with feels like utter luxury. It basically used to equate to one side and a bit of a car before you had to pick up and move the whole lot. This is the new setup...  That's not even using the additional ten metre extension that came in the box. That alone will make the job of cleaning anything far less annoying. Fit and finish is a lot better than I was expecting to be honest. Just a shame the polystyrene packing has reacted with the paint on the frame in one spot. Everything slotted, clipped or screwed together nicely as it was mean to and I had no issues with sharp edges or burrs on anything. Engine is your typical Honda clone which turns up on everything from go karts to lawn mowers to generators...and while I'd obviously prefer the real thing (or being me to be honest, a flathead Briggs), I've never personally had any issues with these on any of my equipment or anything I've helped others look after. If it was being used for hours on end every day, maybe. For a couple of hours every week or two it should be fine.   It does have a low oil shutoff, which is always nice to have on a piece of equipment like this. The detergent tank built into the base is a nice detail rather than just a hose dangling off to dip in a bottle (which inevitably gets either lost or broken) or an awkward thing you have to clip to the lance like the Nilfisk this replaces had.  As for performance? Well you'd expect it to have more punch than the 1400W electric ones given the engine here is rated at 5500W if my math is right (8hp). Yep...that's definitely the case...you properly have to brace yourself when pulling the trigger on this and use common sense as even with the wider nozzles fitted I don't doubt for a second that this thing will strip paint off metal if you're not careful. Hoping to give it a proper test in the week, today was just a run of a few minutes to make sure everything behaved, and allowed me to blast some of the worst of the gunk out of the gutters and after a dousing in degreaser, the engine bay of the Caddy. Not an oily engine anyway, just grubby from 20 years of use. The washer bottle is going to need separate attention, but it generally looks a lot cleaner now.  Cars are much more likely to get cleaned now as this reduces the hassle factor massively! List price for this is £379, though it was discounted to £330 when I ordered it - decided it was a good thing to stick the £100 or so of vouchers I've had sitting around literally for years to use for - plus my nan sent some money at Christmas too...so good excuse for a new toy I reckon!
Jan 26, 2022 22:08:47 GMT |
Very little to report as I've been running around all over the shop again this week so far. Horrible sounding clatter/rattle when the engine stopped on the Caddy resolved. Before:  After:  There was a good 3/4" of free play in the bonnet when latched and the nearside was rattling. I think looking at it the nearside hinge wants moving back fractionally too, that's a job for another day though. At least it doesn't rattle now. Broken driver's door lock pull has now been replaced as it was bugging me. The pull for the door lock on the driver's door was broken off at the top and it was bugging me. For the sake of less than £2 from a breaker it made sense to change it - they just unscrew.  Little details, but together they help make the big picture and make the car nicer to drive. I think tyres may be on the menu soonish. For all these aren't at all old they just seem to have virtually no grip when the surface is anything other than bone dry. 2nd gear wheel spin shouldn't be a daily issue on roundabouts with 64bhp on tap when trying to move off anything resembling briskly. Not really expecting to get any time to do much else this week as the diary is pretty full.
Jan 31, 2022 23:31:01 GMT |
Figured it was time that I did something about this.  I was getting fed up of having to shove it back into place every other trip. A tip from someone on another forum suggested that there was likely a spring clip meant to be holding things in place based on their experience on older VWs so I went looking. Sure enough I found one behind the headlight doing nothing.  Took a bit of figuring out that the spring was actually meant to fit into a groove on the back of the headlight, which has been deformed in this case so it doesn't fit very securely, the bottom edge kept popping out of the groove.  In the above photo you're looking into the hole the indicator would normally be in, the front of the van is towards frame right. Once I figured out how it was supposed to fit together it didn't take long to get it reassembled. That's looking at the back of the headlight from inside the engine bay. I've noted that one side of the plastic peg that the spring hooks over is cracked (which is why it's sitting at a bit of an angle) so it will need to be replaced at some point. Not a big issue as they aren't expensive. For now though it's properly fixed in place again and doesn't fall out if I brake firmly.  I do have a question though for folks who know these cars/vans better than me. Does anyone know how the radiator etc should actually be supported? The top of mine is currently secured by cable ties (having previously been hanging by the coolant and AC refrigerant lines) as there is no evidence of any viable means for it to be secured to the underside of the slam panel. I've also completely failed to find photos online of anything which looks like what's in place in my engine bay - not sure if that's just because AC wasn't a common option on the Polo/Caddy back in 2002 or if I'm just useless at internet searches. It's pretty obviously wrong in most cases though as the majority of them only have a position available for a single fan, whereas I've got two. The ones I have seen with dual fans show two which are very different sizes, and a plastic cowling...rather than these two which are pretty similar in size (the offside one is a bit bigger) and a metal cowl of quite a different design. So I'm confused.  I'm guessing that there should be some form of bracket/block/fitting...thing...that secures the radiator to the bolt through the slam panel on both sides.  There isn't a threaded hole or anything on the radiator for that bolt to screw into by the way - I did wonder if it was that simple, but no. Attempting to trawl Google for anything helpful has proven completely fruitless...and in fact about 70% of the radiators shown don't even have *any* tab/bracket etc at the top corners shown at all. I'm basing this on Polo stuff, as trying to search for Caddy specific things is completely hopeless as the search engine totally ignores 2002 and just spits out a plethora of matches for the current models. I don't think the radiator can be lifted very much as I think the bottom end (which feels like it's located by pegs rather than bolts given it moves pretty freely vertically) will then lift out of whatever retains it down there...which makes me think that there must be something missing between the slam panel and the top of the radiator. It's one of those situations where I know the solution is probably dead simple, but without a proper diagram of how it all fits together I'm just guessing. I could pull the bumper off to try to get a better look at things, but with it looking like something is actually missing I don't really know what that would gain me anyway other than being able to see that something is missing... The only other job I've done today was to replace the headlight bulbs. They looked pretty well done based on the condition of the filament and the new ones do seem a good bit brighter so I think they were due a change. Still not great, but I can actually see they're on in town now which is an improvement.
