Sept 28, 2021 23:53:09 GMT
Yesterday with fuel basically impossible to come by it was obviously a good idea to take out the most economical member of the fleet to run my errands. Especially as I had a can of petrol in the garage for the mower... enough to add about a quarter of a tank to the gauge in TPA. Been a while since I got any new photos of her, so grabbed a few while we were out. Guessing she will be out and about quite a bit this week!
Current fleet: 73 AC Model-70. 75 Rover 3500. 84 Trabant 601S. 85 Sinclair C5. 06 Peugeot Partner 1.6HDi.
Distraction time... Ugh...my head gasket set which has been stuck in customs since the middle of the week apparently is now on its way back to the sender according to the tracking. Deep joy. Fine, will go see if Motorserv can get the necessary bits in tomorrow. In slightly less depressing news a little parcel arrived this morning. Buried within an improbably large amount of bubble wrap was this. As with many things which arrive in the post for me this falls under the heading of "was very expensive when it was new." Around £140 - in 1973. That equates to somewhere around £1500 in 2021. So what is in the case then? A calculator...you probably guessed that already. Albeit a very expensive one for such a basic feature set. This is the important bit. This is a Sharp EL-805. The first pocket calculator ever to make use of a liquid crystal display. Rockwell actually got there first to use an LCD in a calculator the previous year, but they were AC powered desktop units...which didn't really take advantage of the low profile nature and low(ish!) power consumption of the technology. Sharp were the first to really take that step. Yes, I do have the three models using the Rockwell design on my eBay saved search list, because I absolutely want to get hold of one of them obviously! This isn't the LCD technology you're used to. This was the first commercially applied form of the principle, a dynamic scattering mode (DSM) panel, rather than the twisted nematic displays which took over after only a couple of years. The more modern displays use polarisation changes to block or allow the passage of light, whereas DSM displays simply are totally clear when unpowered or are opaque when power is applied. These early displays were very fragile and used an order of magnitude more power than later display technologies. While they had their limitations they are extremely striking looking things. The EL-805 was particularly noteworthy in that the whole calculator more or less is built on the same panel of glass which the display is constructed from. You actually view the display *through* the circuit board which is quite unusual. This turned out to be a technological dead end really but nevertheless was an interesting approach back in the early 70s. I will of course get some photos of that setup with the case off when I get a chance. Very glad to have finally got hold of one of these, it's a model which has been on the radar for quite a long time. The last few I've seen have sold for well into three figures so I was quite surprised that the cheeky offer I submitted through eBay was accepted...not complaining though! The big brother to the EL-805 was the EL-808 which I managed to get hold of last year. This was a far larger portable desktop calculator which was clearly designed to showcase the new display technology at its best. If such things interest you, some more information on that one can be found over here.
CaptainSlog
Club RR Member Number: 180
Oct 12, 2021 16:31:24 GMT
Is anyone else having trouble with the photos? or is it just me?
Oct 12, 2021 21:05:36 GMT
Is anyone else having trouble with the photos? or is it just me? They're hosted on ImgBB. I've seen them now and then get hit by false positives from ad-blockers for brief periods before the whitelist rules get updated. Not having any issues seeing them myself on any computers/devices I have access to.
Oct 12, 2021 22:28:53 GMT
always visible to me.
Never visible to me, but that's because of the work VPN. If I turn that off the photos appear after pressing F5.
No problem seeing them on my phone though.
Oct 13, 2021 14:30:30 GMT
i cant see images either, but having chronic issues with nearly 50% of the websites i visit coming up with security warning (about expired ssl certificate) which is what happens if i right mouse and open the image in a new tab
only started happening about a week ago
Oct 13, 2021 17:09:23 GMT
No problems here with Zel's or any one else's pics. Just left click on one, and go to ImgBB for his album.
CaptainSlog
Oct 15, 2021 12:50:23 GMT
No pics - on my Tab S7+
Pics on the Merc thread are ok though! - scratch that - no pics there either.
CaptainSlog
Oct 15, 2021 13:00:35 GMT
Never visible to me, but that's because of the work VPN. If I turn that off the photos appear after pressing F5. No problem seeing them on my phone though. Now you say that I tried my VPN via Ireland and all the pics are there? Sorry for the hijack Zelandeth!
Oct 15, 2021 13:20:19 GMT
as this is an occasional distraction i'm deeming it ok anyway by a trail of breadcrumbs i found out yesterday its our hardware firewall blocking your photos. not your photos per se, but its rejecting the SSL certificate of your image host. its a very specific issue but actually a global one for any website that uses an SSL certificate issued by lets incrypt, which BBimage do... www.fortinet.com/blog/psirt-blogs/fortinet-and-expiring-lets-encrypt-certificates
jimi
Oct 15, 2021 19:09:56 GMT
I'm not having any problems seeing the images, their always there My website ssl cert is from Lets Encrypt, I'm not seeing any problems with it This image is from my website
Last Edit: Oct 15, 2021 19:12:42 GMT by jimi
Oct 18, 2021 17:37:43 GMT
While waiting on parts from Mercedes for the S123 I figured it was a good opportunity to get a service item on TPA I'd been putting off done. Gearbox and diff oil change. What came out was quite grim, not glittery though, just very degraded. Was really thin and seemed to have lost a lot of its lubricity. The oil that went in last year was from a very old container, and even though it was still sealed I think it may have broken down over time on the shelf. The new oil that went in today was actually new and hopefully will fare better. While I was in there I took a look at the condition of both CVT pulleys and the belt - these items live quite a hard life so it's worth checking for any signs of distress whenever you're in the area, especially as we've been experimenting with a current belt type rather than the exact one originally specified. Everything looks fine though, looks like the Dayco HP2020 belt is able to stand up to the job. It's been on there since last August and has about 1500 miles on so far. Main reason I had been putting it off was that getting to the level plug for the diff is an absolute pain in the tail. It's not quite so bad now I've done it a few times as I know where it is (you can see it or touch it, but not both at the same time), but is still bloody awkward. I'm sure the intended way of changing the oil was to have the car on a lift in which case it would be dead easy. Having the original seat would make it easier too actually as the backrest can be easily removed from that, not possible on mine so you're working around it. I've found that cracking the level plug off from in the engine bay but then unscrewing and removing/refitting it from in the cabin and then doing the final tightening from the engine side seems to be the easiest solution. The "light scattered showers" the weather forecast predicted this afternoon proved to be anything but. "Persistent and mostly heavy" was a better description. So we got a few more typical photos of her out and about rather than just when it's nice and sunny for a change. My weatherproofing improvements have definitely helped, though I do still have a little water getting in around the offside of the windscreen occasionally. Somewhat to my surprise, the demister actually does just fine when you're on the open road so long as you keep a window cracked slightly - problem is that as soon as you drop below about 50 it basically ceases to have any effect whatsoever - and the cabin being so small means that it fogs up very quickly. Obviously there's no way to direct air to the side windows either so you really do need a demisting cloth to live in the car. Windscreen wiper does a better job of clearing the screen than you'd think with how tiny it is, though an intermittent wipe function would be nice...you really want two hands on the handlebars whenever possible so having to keep turning the wiper on/off gets a bit tiresome after a while. Not that I generally plan to use the car regularly in monsoon conditions, but if I get caught on a longer run in poor weather it's nice to know that it's not a huge problem.
Oct 18, 2021 18:50:09 GMT
I have a Velleman windscreen wiper delay kit on the Land-Rover. It works really well and cost less than a tenner. You used to be able to get them from Maplins, but no doubt they’re still available elsewhere online.
Oct 18, 2021 19:11:32 GMT
Oct 18, 2021 19:15:22 GMT
I bought a Vellmann recently from a link on this forum. I think it was from Vellmann directly.
Nov 21, 2021 20:16:28 GMT
Made a point of unearthing TPA in the garage today and clearing up enough of the mess that I can actually walk through the garage again. She got somewhat buried when I was clearing out the van prior to a weekend away a couple of weeks ago.
Last time I didn't drive her for a couple of weeks she played up a bit, refusing to idle properly and generally behaving as though there was crud in the carb idle circuit. This sorted itself after about an hour of driving. Sure enough when started up today she behaved exactly the same. Engine would rev just fine, but fall on its face as soon as the revs dropped to idle.
This was the point at which I spotted a very likely cause of issues - that the carb was visibly wobbling independently of the engine. Both mounting nuts were barely finger tight.
With them nipped up (which is fluffing fiddly because of poor access), she started and idled absolutely perfectly. So I'd obviously had a huge vacuum leak from the carb base. I'll stick a couple of shakeproof washers under the retaining nuts next time I get a chance.
Goodness only knows how long that's been causing a leak to some degree... curious to see if there's any noticeable change to how the car runs in general now. Hopefully get her out for a drive in the next couple of days so we can find out.
Aside from anything else, it's been a few weeks and I've missed driving the little rattle box.
Having unearthed TPA yesterday it was time to take her out for a run today. This was intended to be a quick half hour run, but we ended up being out all afternoon, getting home well after dark. After a bit of a race against the sunset I did manage to get to my usual photo spot as the sun was setting. So has the carb being loose been an issue for a while? Yes I think it has actually. While outright straight line power is much as it always has been the engine feels much more responsive now than I can remember. Especially that point between where the clutch has just fully engaged and you get to 30 or so. Need to see about sorting the window catches and replacing the missing weather stripping between the sliding sections as it was a bit chilly at a couple of points today! Also really should have a look at the voltage regulator and see if I can bring the cut in point down a bit. It only really comes properly on charge on the open road, which is far more of an issue when you've got the headlights on. I may well try to pick up a second one as I've heard from a few people that setting these regulators up is a bit of a dark art...and I don't want to break it!
maf260
Dec 16, 2021 11:38:28 GMT
This was posted on a Faceache group I sometimes frequent. I think it's you...
Dec 16, 2021 18:47:36 GMT
Yep, I'm on that group too and spotted it yesterday evening. Nice to see a photo of the car actually in motion.
Kind of amusing seeing the variety in the comments!
