Aug 21, 2021 10:31:38 GMT
Try to fit the reel up in the roof, then you just pull the air line down to use it. I suspect the door framework will preclude me being able to fit it at ceiling height, but it will definitely be getting fitted as high up as I can manage if it's on the left hand side of the garage (which is the side I generally walk down).
Current fleet: 73 AC Model-70. 75 Rover 3500. 84 Trabant 601S. 85 Sinclair C5. 06 Peugeot Partner 1.6HDi.
Bit more progress today. First job was to reattach the air filter/muffler to the compressor as it fell off a while ago. Have gone for the epoxy putty approach first...if that doesn't hold I'll get the welder out and tack it back onto the metal stub screwed into the body of it. Was only a couple of flimsy spot welds originally there. Then it was a matter of shuffling things around, putting up an additional shelf on the rack and generally tidying. I moved the air hookup point and regulator a bit too with some thought for when the hose reel when it arrives - assuming it will fit - it will go somewhere in this vicinity of the red circle on the image below. Then there was far longer than it looks like generally digging around and trying to tidy things up. It does feel like we're starting to actually make some forward progress now though, which is a bit of a morale boost. Having bought the self-retracting hose reel for the air line has given me the idea to pick something up along the same lines for an electrical extension lead. The one I currently have was a seriously cheap one picked up from Argos about 15 years ago and is utterly maddening to use...time for a better one. It will be getting fitted at ceiling height as well in the same area as the air one. The overall mission here is to get as much stuff off the floor as possible to make it an easier place to work in. About time I sorted the garage door opener too. There's absolutely nothing wrong with the unit itself and it works perfectly, looks a nicely built unit actually. The issue is that we don't have either a fob for the remote receiver or key for the manual override switch by the door. So time to get a new receiver and new keyswitch fitted, then it should be fully functional again. Given the faffing around playing car Tetris that goes on every time I go to get the Invacar in/out of the garage that is something it would be nice to have working. Plus it bugs me knowing there's nothing physically wrong with it but I can't use it. It's definitely being a bit of a morale boost seeing this starting to take shape. It's needed to happen for far far too long. Should be able to deal with the huge pile of stuff I thought I couldn't move too as it's occurred to me that while we don't have a shed to put the garden furniture in...I do have a stinking great camper van don't I? No reason I can't just stash things in there while I'm working on the garage. Can't believe it took me a week to figure that out. I'm really not the brightest crayon in the box sometimes!
I think I need to copy your plan on mounting the smaller compressor I have, up high somewhere.
Such a simple solution to gaining a square meter of floor space, one always has to walk around or fall over them. Mine lives on a shelf, under my welding table.
Not ideal, but also out the way, though up on the wall is even better.
You could bring the line from the compressor first down to a comfortable "use height" for the regulator, to be able to adjust pressure, the back up to the reel. then, near where the line hangs, at about a comfortable "reach height", you could put a clip on the wall to hold the end of it to stop it swinging loose in the breeze.
Last Edit: Aug 22, 2021 8:51:52 GMT by bobdisk
An electric extension lead reel is also on my list of “things I’ll have by the time I’m done”.
I put my compressor in a lean-to outside the main workshop, rather than having it inside where I’m working. I have seen the results of a reservoir tank failure, and I don’t want to be in the same room as one if it ever lets go. I’ve rigged up an automatic drain valve too, which keeps it clear of condensate without me having to remember to drain it all the time.
Aug 22, 2021 10:37:18 GMT
I think I need to copy your plan on mounting the smaller compressor I have, up high somewhere. Such a simple solution to gaining a square meter of floor space, one always has to walk around or fall over them. Mine lives on a shelf, under my welding table. Not ideal, but also out the way, though up on the wall is even better. I wouldn't want to try this if it still had the compressor attached to it...way to heavy for hanging on a shelf then. Having the remote compressor is what made this possible. That's now living underneath that set of metal shelves. I guess the alternative might be having it up on the top shelf of something like the metal shelving rack (there are still two more shelves to be fitted to that) - though it would probably just wind up shaking everything off the shelves and rattling enough to drive you insane every time it started up. Being quite long but narrow makes this garage a bit awkward to organise efficiently without getting in your own way all the time.
Aug 23, 2021 23:17:28 GMT
Out for a run again today, needed to make a run down to Aylesbury and it was a nice day so TPA came out for it. While I do enjoy driving this car, and the vast majority of the time she copes very well. Was staggered by how nicely she cruises on the motorway for one, on the wrong road she can be quite tiring. Google decided to send me cross country, and I wound up on a relatively fast road with a horrendous surface. Ride is better than I had ever expected for a 400kg car on 10" wheels, but is quite bouncy. The seat does a good job of isolating the majority of the shock from the driver too. However being a glass fibre body the moment you hit anything whatsoever by way of undulation on the road you get all manner of crashes and rattles from the body. The interior is a LOT better than it used to be, but there's only so much you can do. The doors in particular are always going to be a major source of rattles without totally re-engineering the latches. I may look into doing something along those lines one day given I'm obviously going to keep using this car regularly and can't honestly ever see me selling her. You can carry more speed through corners than I think people expect, when you know the road and can see a good distance ahead. However when you *don't* know the road and the tendency for there to be hedges or walls right up to the side of the roads around here I did have to pull in a couple of occasions so as to not irritate the cars behind me. While she's quite happy to cruise at 50-60, she does take a bit of time to wind up - just as you would expect from a 500cc powered car from the 70s! The biggest cause of stress on that trip though was down to dealing with one of those road surface issues which are just inherently quite unnerving in a three wheeler with the single wheel up front - roads with really wobbly undulating camber issues. That does make her wobble around quite a bit...I don't find it unnerving really now as I've got used to it and know she's not about to hurl me off the road, but it does mean keeping a straight line line (especially with how direct the steering is) on roads like that is quite a bit of work. Not quite as bad as the Lada was on similar roads mind you! Coming home I chose my own route and just headed down the A418/505/5...far less daft a route. Much smoother and better in the visibility department...and I wound up being stuck behind a brand new Range Rover until I got to the A5 so I could overtake it! Really, really news to clean the windscreen. The amount of bugs splattered on there is unreal just now. Whole car could do with a wash anyway really...think she's only had one so far since being resurrected so far.
I would love to have been a fly on the wall inside that Range Rover when you overtook!
Aug 24, 2021 17:01:20 GMT
I do like reading about your adventures with TPA, one of my favourites on here!
Aug 24, 2021 22:33:09 GMT
I would love to have been a fly on the wall inside that Range Rover when you overtook! They had been bumbling along at 35-45mph for about 15 miles by that point and I was doing about 65 when I went past them so it would have looked on video like I was going like a bat out of hell! That's an annoying speed for TPA, she's happiest between 50 and 65 really, isn't a fan of sitting at speeds below that. I imagine a lot of that is that the CVT locks up at about 45, so you're really getting into the power band proper by that point. 60mph is about 4500rpm from memory so she's on song quite well by that point. I'm pretty sure the biggest limiting factor at that point is the carb. I do admit I'd love to build an ultralight open cockpit car with a highly tuned version of one of these engines (would have to be a track only job with how ridiculous the IVA requirements are these days), a 650 with a big (relatively!) carb and a manual gearbox in something weighing less than an Invacar could be a huge amount of fun. A parcel arrived from DPD earlier today containing this. Sadly didn't get time to look into getting it fitted today... hopefully tomorrow.
Aug 25, 2021 11:51:14 GMT
Make sure the mounts are substantial - they weigh quite a lot!
Aug 25, 2021 12:16:00 GMT
I'm pretty sure the biggest limiting factor at that point is the carb. Does that distributor have automatic advance/retard?
Aug 25, 2021 14:38:35 GMT
I'm pretty sure the biggest limiting factor at that point is the carb. Does that distributor have automatic advance/retard? Just centrifugal on these. Vacuum advance would probably make it feel a bit more perky, but the distributors have an annoying habit of fusing themselves into the crankcase so swapping out for another one isn't likely as simple as it sounds.
Aug 25, 2021 15:04:24 GMT
Does that distributor have automatic advance/retard? Just centrifugal on these. Vacuum advance would probably make it feel a bit more perky, but the distributors have an annoying habit of fusing themselves into the crankcase so swapping out for another one isn't likely as simple as it sounds. Weight driven change is all you really need. Makes me wonder if you could make the curve a bit more aggressive, being as it's not running on 2-star any more.
Aug 25, 2021 16:58:21 GMT
Just centrifugal on these. Vacuum advance would probably make it feel a bit more perky, but the distributors have an annoying habit of fusing themselves into the crankcase so swapping out for another one isn't likely as simple as it sounds. Weight driven change is all you really need. Makes me wonder if you could make the curve a bit more aggressive, being as it's not running on 2-star any more. To be honest, never even minding the curve, I imagine there's quite a bit to gain by advancing the timing a bit anyway. From what I recall the factory setting is quite heavily retarded. I guess one day I might see if my distributor moves...
Aug 25, 2021 18:06:48 GMT
To be honest, never even minding the curve, I imagine there's quite a bit to gain by advancing the timing a bit anyway. From what I recall the factory setting is quite heavily retarded. I guess one day I might see if my distributor moves... Put some penetrating oil on the base of the distributor every time you drive. Give it a few weeks, it'll work in and might get into the corrosion.
Aug 26, 2021 11:25:49 GMT
To be honest, never even minding the curve, I imagine there's quite a bit to gain by advancing the timing a bit anyway. From what I recall the factory setting is quite heavily retarded. I guess one day I might see if my distributor moves... Put some penetrating oil on the base of the distributor every time you drive. Give it a few weeks, it'll work in and might get into the corrosion. Yeah...4-and-a-bit degrees BTDC by the book. Reckon she could stand for that being increased a bit.
Aug 26, 2021 11:47:20 GMT
That's very similar to mine- it's much happier at about 15 degrees.
I had TPA out for a run down Dunstable way today, mainly because I remembered there being a set of roadworks down there which tends to cause quite a queue and the Merc gets warmer than I really like in traffic...so was an obvious choice. Ever since I changed the dynastart belts they have been quite noisy. Originally I'd just put this down to them needing to bed in...but after a few hundred miles they're still making a din. Looking closer I think I can see why. The inboard one isn't sitting properly. Same story on the lower pulley. My theory is that it's a bit too tight so is getting pulled down too far into the valley on the pulley. Now I've spotted that should be quick enough to resolve. Hopefully once I've shuffled shims around a bit the belts will quiet down a bit. In other news the 3/8" to 1/4" adaptors turned up so I could finish the air line installation work. Doesn't really look much different to the last picture, but this is actually now all hooked up and working properly. We did initially have one small leak at this join. This is why I use leak detector spray as I'd never have found it otherwise. I had just been a bit too stingy with the PTFE tape it seemed as on take two it sealed perfectly without any issues. I've left the system charged and will see if we've lost all the air by morning. I need to do a test to see how far I can reach with this and my existing extension (the yellow hose you've seen previously). I'm hoping that I will be able to get to the whole driveway and can just ditch the annoying plastic coily one which seems to exist for the sole purpose of getting itself tangled around everything and smacking me in the face when it comes free. Only task left on the air system until I call it good will be wiring in the power switch. The socket this is connected to is basically inaccessible (it's behind the tank) so is a pain to get to, but I obviously wanted a way to shut it off. I went for an industrial style switch as it was cheaper than an equivalent IP rated double pole rocker switch, which I wanted because I've had issues with dust and grime getting into none IP rated switches before. Plus I can just wipe this down if I get it covered in oily gunk, which will no doubt happen at some point. Once that's wired up I'm calling it done for now. Few little bits and pieces to do to optimise things (like replacing that flexible line from the receiver to the regulator with rigid line) but it will be absolutely usable then.
Aug 31, 2021 23:16:40 GMT
Can you spot the difference? Well the obvious one is the stainless screws now holding the door handle on (rather than the rusty flat head screws that used to be there). What you can't tell is that this is actually the handle which used to be on the other door. Something that I hadn't (for obvious reasons!) mentioned anywhere public was that one issue I had yet to deal with on TPA was that the nearside door lock was seized. The offside one worked fine...but I very seldom use that door as it's an absolute pain to close and likes to stick on the runners. Sorting it out is on the to do list, but I've not got there yet. I had come up with a bodge with allowed me to make it appear locked - but with a solid pull on the handle you could still open it. There was no way to actually lock it properly though. Today I finally got around to drilling out the screws holding the handles on so I could transfer the good one to the door I use. Then I set about seeing if I could get the seized lock apart and sort it. The answer was "sort of." It's still very sticky but does actually move now. Realistically it wants replacing though. For now though I've got it into a locked state...which given I don't use the offside door having it locked is just fine. You can still open it from inside - for example if I needed to exit that way in an emergency. The nearside door now locks and unlocks properly. Something I'd been meaning to do for ages so nice to have it ticked off. I mean security is very much relative with these cars...but it's better than nothing! Definitely slightly less worrying leaving the car parked up anywhere public. Especially in places like busy multi storey car parks for example. Ease of parking is definitely a plus with driving the Invacar. I remember those spaces being far tighter last time I was in this car park. I also wasted about half an hour...they have the stairwells in that car park set up as one way...one to go down, one to go up. I found the "down" one just fine. When I came to return to the car...could I for the life of me find the other one? Not a chance. Eventually I gave in and walked up the vehicle only route. Still haven't the foggiest where the entrance to the other one is!
