You may recall a few months ago I finally got the correct indicator stalk fitted to the Invacar and took the opportunity to move it over to the left hand side, which makes far more sense from an ergonomic perspective. This did however leave a rusty patch where the stalk assembly used to sit. This has been bugging me for some time...now I've got new grips it sticks out even more. So took the opportunity to splash some fresh paint around. Won't be quite that shiny once it dries, should tidy things up a bit though. Edit: Yep, that looks a bit better! Not perfect if you peer at it too closely, but it's a lot less scruffy. Just helps make the interior look a little less shoddy I think.
Last Edit: Mar 9, 2021 22:25:25 GMT by Zelandeth
Current fleet: 73 AC Model-70. 75 Rover 3500. 84 Trabant 601S. 85 Sinclair C5. 06 Peugeot Partner 1.6HDi.
Mar 10, 2021 17:08:37 GMT
Package arrived this morning to allow me to finally hopefully properly sort the throttle cable on TPA. I know I probably still have a load of cable somewhere in the garage...but this was all of £0.88 a metre so I wasn't going to lose sleep over trying to find it. The important bit is the cable end being the right size to fit the twist grip. Which is one of these. For future reference when I forget.I fed the cable through from the cabin end as I've always found it behaves better doing it that way. Every time I've tried feeding it from the engine bay it ends up snagging on something. Then trimmed the cable once it was attached to the cable end. This has to be done before fitting to the twist grip or it's not possible to slot the barrel in. Then basically just put things back together before securing it and trimming the excess at the carb end. I've left enough excess that if it snaps right at the barrel in the future that I'll have enough cable to repair it. For the first time I have a throttle which is bodge free and has a nice smooth action through the full range. That will make driving nicer. While I was in the garage I tackled something else I'd been meaning to do for a while - finding somewhere out of the way to stash a spare CVT belt. That will do nicely. Despite what it looks like in the photo it's sitting clear of the brake lines to frame right, it's resting on top of the master cylinder at the rear. I'll be finding a spare 17mm spanner shortly and leaving that attached to the belt, meaning I'll have everything I need to change a belt at the side of the road if I ever have one fail out of the blue again. Not really expecting it as I'm sure that was down to me using an ancient belt that had been poorly stored, but it's an easy eventuality to prepare for so just seems smart.
Mar 10, 2021 17:18:36 GMT
Every bit of progress continues to improve this little car.
You do this well.
Mar 11, 2021 19:50:16 GMT
Just a quick bit of work done today between the showers. With TPA having passed the 1000 mile mark a week or so back a service was on the cards, a few bits of which have already been done. Today though was the turn of the ignition system. The points and rotor arm were still the original ones which were on the engine from KPL when she was originally dragged out of a field. However as the ignition system just worked I'd left things alone! Now the engine is in a car in regular use though and I've tracked down a source of the right parts it's time to sort that. New points in and the gap set to the correct 0.4mm. New rotor arm was then fitted. This is quite a different style to the one which was on here and is a bit taller. Looking at the old distributor cap though it does look as though it was only just touching the lower edge of the contacts in the cap, so I do wonder if the fitted one was correct. A new distributor cap then finished things off in this department, the proper one having finally escaped from its extended stay in customs limbo. The eagle eyed among you might spot that the air filter has also been changed. It's only got 1000 miles on it, but having been present during all the painting, filling, sanding painting (repeat several times) I figured it was probably worth changing. Only the finest OEM parts used of course! I was not really expecting there to be any obvious change to how the engine ran as she's always seemed quite happy. The idle is definitely noticeably smoother though! Whether there will be any difference when actually driving will need to wait until a test drive happens. Two jobs coming up in the engine bay. First being that I really need to adjust the fan/dynastart belt tension as the rearmost one is flapping about quite a bit. Before I can do that though I need to figure out where in my disaster area of a garage the impact gun is as everything else I've thrown at the nut on the fan pulley has failed to shift it. The second job is to fabricate a proper battery stay. The bungee cord and zip-tie solution was absolutely fine when TPA was primarily held together by duct tape and hope, but those days are a fair way behind us now and it's *really* bugging me. Shouldn't be difficult to come up with something, just has taken a while for it to get to the top of the to do list.
While it was a bit breezy really for driving tiny three wheeler vehicles with a kerb weight roughly equal to that of a postage stamp today, I wasn't about to let that get in the way. I wanted to see if the last few jobs I'd done on TPA had any impact on the way she drove. So she was the chariot of choice for today's errands. Short answer is yes. I definitely wasn't getting quite full throttle before. Most noticeable when cruising at 60 now, there wasn't a huge amount of travel left (it was very mushy anywhere beyond about half throttle) whereas cracking it open at 60 now results in a very distinct additional bark from the intake and the pace being picked up quite a bit quicker. Wasn't doing any real higher speed testing though today as the roads were too busy and it was too windy. She is definitely running smoother too...which is nice even though I didn't really realise there was any improvement to be made there beforehand. By complete random chance when I pulled up back home today the odometer stopped showing 427 - appropriate for an AC built car!
Mar 24, 2021 22:54:41 GMT
Modern cars are just so ridiculously huge aren't they? Stopped to grab a couple of better photos on the way home as I've been wanting to grab a couple for profile picture type applications for the web page etc. The curse of that streetlight strikes again - got a shadow on the roof this time. ...And reflection on the lens from the back of the phone case in the other photo. I'd honestly forgotten that I'd ordered a replacement for the horn that I fitted way back when I first resurrected her as it's proven very intermittent. Fact is the electrical system just isn't up to an air horn...It'll work fine if you're blatting along at 60, but trundling along at 30 it's 50/50 whether the compressor will run fast enough to actually sound the horn or just make pathetic croaking noises. Arrived with a load of needless plastic tat over it to try to make it look "modern" I assume. Thirty seconds of levering with a screwdriver later... Far better! Will get that fitted next time I'm in the garage. Half the size and about a quarter of the weight of what's in there just now. Yes, I could have taken the Xantia today, could have taken the Jag...Nope, I wanted to take TPA because we're honestly at a stage now where she's just a fun little car to drive. Overtook several cars on the A5 on the way back home - much to the surprise of the drivers! I was making a deliberate point of holding her at an indicated 70 (honest...) for a good few minutes as I wanted to see what the temperature did. On a very slight uphill gradient (which let's face it is about the best we can expect her to maintain it on...The fact this car can DO 70 is enough of a surprise for most people) it peaked at 165C, which is pretty much smack on 1/2 way on the gauge - which I'm absolutely happy with. I'm measuring this from the left hand cylinder head, which being shaded by the oil cooler should always be the hot one. Given blatting down roads at motorway speeds wasn't really in this car's design brief was why I wanted to make sure the temperature wasn't slowly creeping up when travelling at higher speeds.
Mar 24, 2021 23:48:51 GMT
Given blatting down roads at motorway speeds wasn't really in this car's design brief... Given my age, I remember these all too well. What I don't remember is ever seeing one go more than 20mph! Also, when thinking back to the derogatory names used for these vehicles in those days, it really makes me smile to read your enjoyment of "blatting" around in this!
Mar 25, 2021 21:59:57 GMT
Brief interlude into the "occasional distractions" category... I may have had a moment of weakness on eBay a few days ago... Been a long while since I last saw one, but it popped up in one of eBay's "we think you might like..." emails which have been increasingly dangerous lately since I went on a buying spree of ancient calculators a couple of months ago. Still want to add an NC200 to the collection at some point, a friend had one while I was in secondary school and I always greatly coveted it. Just haven't seen one at a price I'm willing to pay yet. This was less than £50 including shipping though which I was quite happy with. Hard to believe there's only four years between these two when you look at how much more of a coherent, polished looking product the NC100 is than the PPC which honestly looks like someone found a bunch of bits in a surplus warehouse and bolted them together (which *is* basically what they did!)... Though from a purely architectural point of view, the NC100 is arguably more old fashioned, being Z80 based rather than 8086 (well, a clone thereof anyway, NEC V30) for the PPC512. They also share one major gripe...lack of a display backlight!
Mar 29, 2021 22:37:32 GMT
Finally got around to sorting something today on TPA which has been making my teeth itch for over a year now. Spot the difference. (Aside from the distributor cap.) Before: After: Yes... finally dealt with this horrific bodgefest. These are the original battery hold downs. Sadly as I was completely unable to find the original form factor battery (or indeed what type it even was), they're basically useless. Oh, and here's a reminder why bungee cords and cable ties are not a permanent solution. That had been pinched between the rear wheel tub and the chassis rail and had rubbed about 2/3rds of the way through. My solution has been to cut a couple of bits of M8 threaded rod to roughly the right length (a little over 6") and fasten a bit of webbing between them - this is a bit of seatbelt originally from KPL I think where the buckles had completely rotted away to nothing. I heated a metal rod up to red hot before using it as a punch to make two holes. This melts the fibres together and prevents anything from fraying. Not too worried about that anyway. Ever tried to tear a seatbelt, even if it's already frayed halfway through? Finished article... It's tightened up sufficiently that the battery is completely secure. If I have issues with it ovalling the holes out I'll replace it with a strip of angled steel instead - but I'd really rather avoid the need for metal across the top of the battery if I can avoid it given the layout. I might go back and bolt a lip onto the tray though just so there's then *absolutely* no way it could conceivably slide free then. It can't go anywhere the other direction as the wheel tub is in the way. Probably overkill...but I'm a fan of doing what I can to keep Murphy's Law at bay. It's really not a heavy battery either, probably half the weight of your average car one. I had someone ask me on another forum what the labels on the slam panel were all about - the answer is "me getting fed up of realising I need to consult the manual in the middle of a service one time too many." Couple of photos from while she was out in the sun today just for good measure too. Really need to remember to paint that rear wheel arch...I just can't see it from in the garage so keep forgetting there are still white filler spots visible there. Noticed I've got a drip from the sump plug... that's what I get for being a cheapskate and not just replacing the copper washer (which I noted was well mangled originally). No idea why I didn't just change it given I have them in stock. Oh well...on the plus side at least I'm not dropping a huge amount of oil to change it!
She really is beginning to look like new! And go like it, I suspect !!
jamesd1972
Club RR Member Number: 40
Good idea on the webbing mount, might have to pinch that for the tractor ! James
Mar 30, 2021 10:56:41 GMT
She really is beginning to look like new! And go like it, I suspect !! Wouldn't go that far, the bodywork is still a horrible mess in many places, I've not been worrying too much about that though. Mostly been concentrating on the bits that make her go and stop and the interior. Those areas seem to be doing fine enough though!
Mar 30, 2021 18:51:19 GMT
As mentioned above, TPA has been marking her territory since the last oil change. This is because the idiot doing the service for reasons utterly unknown decided to refit the rather dog eared copper washer rather than replacing it. Which would have required him to walk all of four feet to pull one out the box. This has now been rectified. On the plus side, the sump only holds 1.75 litres of oil so I haven't wasted much by changing it twice in 200 miles. On the downside, the sump only holds 1.75 litres of oil, so you *really* want it to stay inside the engine. While I'd got the sump empty (again) I figured it wouldn't hurt to take a look at the sump strainer. I had been checking it religiously for the first few oil changes as quite a bit of sludge was initially washed out - but subsequent checks revealed nothing so I'd left it be for a while. Reckon it's probably been untouched for 650 miles or so now. Any slime present today? Nope. Clean as a whistle (well, a very oily whistle...but you get the idea). The grainy looking bits at the far edge are attached to the gasket. No deposits in the basket at all. I think with regular oil changes and the sort of driving I do I can probably drop pulling this out down the service interval list a bit. It's worth keeping an eye on, but definitely doesn't need to be pulled out with every oil change or anything like that from the looks of things. Later in the afternoon I found five minutes to fit the new horn properly. Aside from needing to fit the proper foam pads in the fuel tank frame (which I do now have in stock at long last) it's *almost* looking vaguely orderly under here now... The spare belt got in the way of the catch for the hatch so has been relocated to in a bag under the seat for now. I'm probably going to attach a couple of the down points for said bag on the fuel tank supports when I have them out to fit the anti vibration pads so it can stay up front, but somewhere actually out of the way.
Out and about today. No photos sadly as I was running late and had to just about double the route length due to me having not realised things were closed (the fact this is Good Friday had completely passed me by, as my brain still thinks it's March 374th 2020. Glad to report that the sump plug does indeed now appear to be oil tight. Though we definitely do have a weep from the diff on the offside, so I'll need to look into changing the driveshaft seal at some point. It doesn't seem to be enough to show on the level, just enough to make a horrible mess. Level has never visibly dropped between checks. But it doesn't take much to make a huge mess. Given the state of the outside of the diff casing (I chipped of congealed mud and oil the best part of an inch thick when I had it out between cars) I'm guessing it's probably been like this for decades!
Yesterday I started to address some remedial bodywork on the rear of TPA. I'd had issues with a crack appearing to the left of the engine cover, which was basically because I'd done an appalling job of getting the new glass fibre I had laid down to adhere to the underlying bodywork. Hopefully I've done a better job this time. I've managed to get a lot smoother finish than I did last time - basically because I decided to ditch the applicator and form it by hand (wearing gloves obviously). This was WAY easier. I also used the excess left over to smooth over some of the horribly rough bits on the other side (this is where I started out rebuilding the rear apron so is where the fabrication was at its roughest). Chuck a bit of paint on there after I've hit it with some sandpaper to knock off any high spots and it should look better I think. Still be as rough as the North Sea in a hurricane, but better than it was. -- -- -- Today some additional fibreglass and several coats of resin applied to the back of TPA. Bit of sanding obviously needed and it's never going to be (even close to) perfect, but should definitely be an improvement. Even before I've done any sanding I think you can see how much smoother the finish is. Perfection isn't the target here, "presentable" is what I'm aiming for.
Did a bit of sanding back today...and after about half an hour remembered precisely how little patience I have for that sort of thing and how much my back (which I'd already hacked off during a tip run earlier) hates it. So quickly got to a stage of throwing my hands up in the air and saying "Sod it, that's good enough, throw some paint on it." I didn't realise quite how much even this had improved things though until I looked at a couple of older photos though... It'll do for now! Car has been in the garage without moving for long enough now. Plus I'm still planning somewhere down the line to A: Hopefully get some actual moulds made for the rear apron and B: Chuck it at a body shop to have a few things sorted out more professionally. So I'm not spending too long on this - dealing with the crack I'd had issues with on the nearside and keeping the car presentable from 30 paces is good enough for me.
40 mile round trip done in TPA today (Dunstable and back), and spent the vast majority of it being held up by other traffic. The woman in the Fiesta who kept slowing down to 30 while looking at her phone then accelerating back to 70, then repeating roughly every 60 seconds got old in a hurry. Was very glad to get past her once we got to a dual carriageway. TPA actually needs a wash now as the heavens opened halfway back. While the lack of an intermittent wipe function is a bit irritating, the tiny wiper actually copes just fine and does a decent job of clearing the screen. So long as you're moving the water all seems to stay outside too. Which is nice as it helps keep the windscreen from steaming up. Has made me really appreciate quite how knackered the roads in MK are! Felt like I was driving on a freshly surfaced formula 1 track compared to driving around locally here.
How am I ever going to tell which car is mine out here...Oh...wait... I get the impression that while it may have taken a while for us to tick over the first thousand miles the second one will take anywhere near as long... That's just under 500 miles in two months. One of the bits of trim fell off the inside of the offside door last time out, so today I decided to call time on the spray adhesive and got some old school goop involved. The trim was then firmly wedged in place while that sets. I reckon this will stay stuck a lot better. Can see me redoing most of these in the same way at some point. Summer will be the real tell when things get warm. Also on the subject of doors...I completely randomly spotted today that the weatherstrip between the two sliding window panes on the nearside (the offside one is missing) was installed backwards...I apparently totally failed to notice that there was a plastic side and a felt side when I installed it. Does a far better job of stopping the draught when the window is closed now! Only took me approximately two years to notice. Ten points for observation to me. Oops. Annoyingly it appears that even with the level sorted that we do still have a slight oil leak. It looks like it *might* be actually coming from the oil pressure switch as the whole area around it looks a bit wet. Have given the general area a good spray down with degreaser so we can have another look after the next trip out to see if it's the culprit. Would be nice as it's a cheap and easy part to change. Not holding my breath though...My gut feeling is that we're looking at a leak from the crankshaft oil seal. The belts are in a state as you can see too. They have been loose for a while now...but lately have been getting a bit ridiculous. Aside from the increasingly unhappy squeak every time the starter is operated from cold, it's never good when you can SEE how slack a belt is. Yes, that is as floppy as it looks. Especially the one nearest the camera. The reason I hadn't done something about this sooner was simple: I'd been completely and utterly unable thus far to shift the nut on the Dynastart pulley. The belt tension on this engine is adjusted (like on old VWs) by adding or removing shims between the pulley sheaves...so any tension adjustment involves removing that big nut. While there are two holes in the fan to allow you to wedge it in place - the nut was tight enough that these holes were ovalling out from the torque I was applying. Right up until the point that I *finally* spent an hour turning the back of the garage upside down and unearthing the impact gun. In approximately 0.3 seconds it buzzed it straight off without it seemed like any effort whatsoever...Didn't even have to lock the pulley... Sometimes you just need the right tool for the job at hand. It's not a tool you'll use for every job (and using it for the wrong one can cause you no end of headaches...), but really is an absolute godsend when presented with something like this or trying to get a wheel nut that's been done up by Kwik-Fit to 10,000,000,000 times more tightly than it needed to be. This was less than £50 and for the three jobs I've really used it for so far I reckon has already more than paid for itself in saved time, sweat and spilled blood. Just make sure if you get one to get a good quality set of sockets to go with it. The other reason I wanted to get this lot apart was so that I could actually clean up the pulley running surfaces...After this engine had spent a good number of years sitting outside in the weather they were unsurprisingly in quite a state - I'm honestly surprised that the belts didn't just self destruct given the state these were in. Definitely beyond the point of "self cleaning" at this point...so out with the carbide mop. Realistically I could do with a new set of pulley sheaves, but the heavy, rough pitting that will shred belts is gone at least. The fan hub (which forms the rear face of the pulley) got the same treatment. Again...It really has seen better days, but is a lot better than it was. The belts will want replacement now as running on the pulleys in that state has unsurprisingly wrecked them. I'll grab a new pair next time I'm in the vicinity of Motorserv. They're not exotic or expensive so I'm not worried about that. They are at least properly tensioned now though (if anything a little over-tight in the case of the front belt). Not really too worried - they'll be getting replaced shortly anyway - I'll spend a bit of time ensuring that the replacements are tensioned as close to as per the manual as possible. Quick test revealed that the "chirp" on activating the starter is indeed now gone. I had also completely failed to appreciate quite how much noise the belts were making at high engine speeds...The engine is SO much quieter and smoother when revved now. Will be interesting to see if that's at all obvious when on the move - though given that about 85% of the noise you're aware of is CVT and gearbox I rather doubt it.
Apr 20, 2021 23:56:55 GMT
Decided to have a better shot at cleaning the Dynastart pulleys up on TPA. There is deep enough pitting that they'll never be perfect, though I think this should be good enough for the job...given that the previous belts lasted the best part of a thousand miles and still worked once the tension was adjusted...if I go through £14 of belts once a year or so I'm really not going to lose any sleep over it. Especially given they started out like this. Sadly Motorserv only had one belt (Gates 6262MC for reference) so I'll need to swing by tomorrow to pick up the second one before I can fnish reassembly.
