Petrol tank rust treated
Got some white paint for the alloys, ordered lime green speedline stickers for them and lime green vacuum hose has been delivered. Top of the tank is dry now
Bottom of the tank painted
You may have mentioned it and I have missed it. Have you got a target for when you want this back on the road by?
How easy is welding exhaust compared to bodywork? Something i have always fancied trying but not brave enough to do it.
You may have mentioned it and I have missed it. Have you got a target for when you want this back on the road by? How easy is welding exhaust compared to bodywork? Something i have always fancied trying but not brave enough to do it. I’m looking at early next month to have it done. I’m doing more 2mor on the car. Welding was ok on the exhaust would have been easier if I had nicer straight cuts about had some gaps to fill. Want to get this done as want to do clutch, flywheel if dmf, arb bushes and lower arms on the Gtv v6 at Easter. Plus full service, lower arms, cam belt kit, water pump, turbo and clean paint/grease pads/calipers as well on the fiat coupe After my family holiday in May I’m going to start on the 155 v6
Last Edit: Mar 22, 2020 19:36:40 GMT by alfabusso
Didn’t get a lot done today as only had 4 hours spare so got petrol tank reconnected, fitted new tank straps, exhaust, sorted the wiring on the engine and some more on the engine I’m thinking I might have to redo the tail pipe I got the Alfa 155 v6 out and had a look at what I need to get for it plus look at near side floor pans
Isn't it nice when you start putting re-furbed stuff back in! Keep up the good work.
Isn't it nice when you start putting re-furbed stuff back in! Keep up the good work. It is good Phil I did want to get the brake pipes fitted but moved the beetle & 155 v6 around in the garage as wanted to see what I still need for the 155 as it’s the next big project to sort
Put first coat of paint on the Vauxhall calipers this morning
Mar 16, 2020 11:19:35 GMT
Mar 19, 2020 11:41:07 GMT
Second coat of paint on the calipers
Mar 21, 2020 17:07:40 GMT
Done a bit more today. Removed front discs/pads, checked that the Alfa 155 v6 discs and Vauxhall vectra calipers/pads fit. The 33 discs are solid discs Fitted all the metal brake pipes, n/s/r wheel cylinder, fitted new connects on the temp, oil pressure sensor, max temp sensor and removed fuel filter but need new bolt for clamp
Mar 22, 2020 15:50:43 GMT
Painted 2 more of the speedlines today
Mar 22, 2020 17:43:56 GMT
Stickers on them now. Just need to get the tyre replaced on the fourth wheel then paint it. Plus need to ordered some more items this week for it
Mar 22, 2020 19:41:34 GMT
I won Recaro interior on eBay for £100
I logged in only to congratulate you on that purchase, nicely done! I'm enjoying your thread, keep it up!
