Jan 10, 2019 13:38:18 GMT
Hi all got an early start on the camper today. The wardrobe is now fully fitted including a shelf.I have also started to fit some bits of extra trim for the owner, chrome door handles and mirrors. Tomorrow should see the small top bed made and fitted and then I can fit out the high top and ceiling. Cheers - mike
Jan 11, 2019 15:51:28 GMT
Hi all not a huge amount done today, I was up half the night with my grandson as some fool (me)gave him cake with lots of smarties and stuff on so he spent the night running around like the duracell bunny. I got a few more blingy bits on. There's wind deflectors fitted to the front windows and a wind / stone deflector fitted to the bonnet. I have cut the hole and fitted the table mounts to the table and floor, fitted the table storage clip and redesigned the panel that seals off the battery and heater as I wasn't happy with it. The water container sat to high and was not secured so I have cut out the top of the panel and it now sits 8cm lower on a panel installed above the heater so is now secure and easier to remove etc. The blank for the bed is cut and just needs covering in lining carpet. Cheers - mike
Jan 12, 2019 17:19:18 GMT
Hi all had a few hours on the camper today. Have started making the panels for lining the high top sides and ceiling. The sides are cut and lined ready for final fitting and the ceiling ones just need covering with lining carpet. I have also rewired and moved the original courtesy light so that I can fit it in the high top side panel. All being well tomorrow will see the last of the panels made for the ceiling, there are 2 led down lights to fit and a larger led light. Cheers - mike
Jan 15, 2019 17:09:05 GMT
Hi all
have had a steady couple of days on the camper.
Added some running boards,finished making and fitted the last trim for the rear doors,cut and fitted the nose edge trim for the floor around the sliding door,have thoroughly trialled the electrics, boiled my first kettle of water and have had the fridge running.
On the downside, the main battery seems to have died so have fitted a new one this afternoon.
Tomorrow will see a full service including pollen filter, oil fuel and air filter and an oil change.I have also spotted a dead bush on the passenger side front wishbone so have got a pair to fit as well.Plus whilst i have the front in the air there's a bull bar to fit so looks like i will have a busy day.
Cheers - mike
Jan 16, 2019 10:53:33 GMT
Hi all
Made an early start before the rain arrived.
Got the service done without any issues.
As its now raining i'm going to fix the top bed in and do the final fit of the ceiling and side panels so that will be the conversion done apart from the final valet and sorting the curtains.
Tomorrow looks better for weather so the front wish bones can wait.
Cheers - mike
Jan 17, 2019 16:21:29 GMT
Hi all got a bit more done today I spent most of the morning changing the front wishbones. Although she passed her mot with no issues I was not happy with the way she drove as there was a little twitch when coming of the power. On checking I found the nearside front wishbone bush looking a bit sad and the drivers side looked to be split. Once the old ones were off it was easy to see they were knackered. Even the rear bushes looked a bit soft. The new ones went in without a hitch and she now drives much better. Thats all for today as its not got above 2 degrees and i'm frozen to the core. Cheers - mike
Jan 24, 2019 16:35:56 GMT
Hi all got a bit more done on the Vivaro I removed the huge safety bar type rear bumper and step and replaced it with a new standard rear bumper. I have fitted an awning rail. The new rear bumper didn't come with reflectors so pooped over to the local Renault man and picked some new ones up. Whilst I was there they were bringing in a minibus for breaking so managed to nab the b post trim. On vans they finish 2 inches short so as to not foul the bulkhead but on mini buses they cover the full b post. I had a couple more bits on bling to add, a leather gear lever boot and a matching hand brake boot. The gear lever went on ok but the handbrake boot would not fit plus I broke the hand brake lever trying to make it fir so that needs replacing now. Anyways she's nearly, the next build will be on a Peugeot Boxer, can't wait. Cheers - mike
Jan 29, 2019 16:12:57 GMT
hi all working through the last few jobs on the Vivaro. Yesterday I fitted the curtain rails and made the curtains and tie backs. I have removed the earlier curtains and must say the traditional curtains are much better. Spent an hour changing the handbrake lever as the old one got damaged trying to fit a new gaiter. I have also made and fitted a retainer for the small top bed. I added soft edge trim to make it a bit more user friendly. I have also been going through the interior cleaning and sorting out the odd niggle here and there. It should be finished tomorrow all being well so I will be going for a run in it on Wednesday, weather permitting. Cheers - mike
Jan 30, 2019 15:54:15 GMT
Hi all finished the last few bits on the Vivaro earlier. Made and fitted the last two bits of trim, fitted the tie backs for the curtains. All she needs now is a final clean of the floor, a good hovering and a wash and polish outside. I'm off to Cleethorpes in her tomorrow to collect some bits and bobs for my next build and try everything out so will have a cuppa in her and fire up the heating etc. Cheers - mike
jules
Very nice. Enjoy following your build threads.
I took delivery of this little beauty today. To say I am over the moon is an understatement! The bespoke services offered by Mike are second to none and his background knowledge is awesome! I wholeheartedly recommend a conversion by Mike to anyone.
Looks great 😀😎,
Looking forward to the next one now!
lightyearman
GYJDM - Grimsby based Japanese car club - Find us on Facebook
Feb 11, 2019 11:52:48 GMT
Hi all up bright and early this morning as I had customers to deal with. Got the single passenger seat removed and the new double passenger seat fitted along with a new swivel base. Hope to get the split charge system sorted this afternoon all being well. Cheers - mike Hello there! What swivel mechanism / bits have you used for that twin passenger seat swivel?
'89 Honda CRX siR Glassroof Flint black fully restored track beasty '90 Nissan S13 Pignose - pass the mig wire '86 Mini - matt orange, 13" Wellers, Project 2018 '97 LDV Convoy home built camper/tramper van '04 Saab 9-5 Aero HOT. Anyone want it? '91 Honda VFR400 NC30 17,000 km from new '87 Honda XR80 4 stroke baby crosser '03 Mini Cooper S - honestly, they are fun... '15 VW T5.1 LWB daily brick
Feb 11, 2019 16:07:17 GMT
Hi there
its a kiravan double seat swivel. Its purpose made for the trafic / vivaro and m1 crash tested.
They are around £340
Cheers - mike
