Mar 24, 2020 17:18:39 GMT
Umhed and procrastinated for a few weeks Wasn’t sure about mixing 70’s and 60’s styling Wasn’t sure about drilling into expensive door cards and metal But Was bored today ..... so ...
Jun 27, 2020 17:13:20 GMT
Been busy with bits and pieces .... lots done on others cars too Timing chain done , gear change rebuild... and lots more Start with photos of these NOS Period Lucas covers never been on a car Suits the green/ yellow of lotus badge
Last Edit: Jul 8, 2020 23:42:40 GMT by rob1380
Jun 27, 2020 21:31:58 GMT
As mentioned , have been juggling jobs on other cars This one, new shocks all 4 corners , new bump stops and dust covers on front , new top mounts, one new drop link bar ( had to cut one off) , rear bump stops ( previous owner taken off completely) , new tyres all round , ands and down and paint of underside / suspension Have worked on suspension of other mini too ( will post pics) ... that was a super 2 weeks !
Last Edit: Jun 27, 2020 21:36:33 GMT by rob1380
Suspension cones Trumpets replaced with hi -lots , sorry no pic Front shocks - old ones weren’t even returning on compression. New hydrolastic bump stops on order Replaced bulbs and seals on rear lights Will run at standard height until everything settled then will lower a little A trip out in nice weather
Last Edit: Jun 28, 2020 9:17:34 GMT by rob1380
Jun 28, 2020 12:29:06 GMT
Been fiddling with styling
Jul 20, 2020 21:56:18 GMT
The driver / co driver names were a bit of a style gamble....
But managed to get myself, wifey, all 5 kids and one grandchild onto car.
I think because of colour of text and flags I it works really well ... there is definitely a mix of styles and motorsport influences on car
Jul 22, 2020 19:24:56 GMT
Aug 15, 2020 10:08:39 GMT
It’s my birthday ...... I’ll accept PayPal Big thank you to Alex ( friend, neighbour , hanger on) for fantastic gift Personalised lotus box .... for all the bits and pieces .... will be great for all the homemade cinnamon swirls at the meets next year ! Just to clarify 1971 is age of car ... I’m a full year younger .... just saying
Aug 15, 2020 14:04:59 GMT
A couple more essential birthday gifts ...
Oct 11, 2020 13:12:45 GMT
Oct 18, 2020 16:27:52 GMT
After my initial investigation It turns out the whole tyre was flat and not just the bottom ! Ah well, I lucked out there . Got local tyre fitter to break bead on both sides so I could dismantle and rebuild Tiger seal the inner joint ( sorry no pic) .. then try and get tyre back on !!!!
Oct 24, 2020 10:52:15 GMT
Tyre back on thanks to local fitter - let’s see if this holds air , I had thought about a home tyre machine , but seeing the effort and power needed to break bead and get tyre back on with a pro machine I’m not going to bother
Oct 28, 2020 18:27:24 GMT
Wheels were off so had my ‘winter poke around’ ....so many jokes/ thoughts! First off, front subframe needs another rub down and paint in (many) places - it is 50 years old ! Cleaned/ wiped inner arches , suspension etc... no major surprises until ... Investigated the never ending hunt of oil leaks on a mini Driveshaft oil seals ... I have bits for that as it’s been leaking for longer than I should have left them . Weeping sump plug ... have ordered a new copper seal and a dowty rubber seal washer - will decide what to refit when I drop and change oil over winter. And ..... this lovely hole was a surprise ! What looked like a bit of mastic stuck on/ in gear change housing turned out to be a 50 year old rubber seal that had decided enough was enough and just crumbled under my disapproving stare! Part ordered.
Nov 21, 2020 11:45:52 GMT
Well the rebound buffer ( just one side as wheel was off) fitting took seconds ... in fact it took more time to find a long screwdriver than it did to fit it. The gear selector rubber was a bit more of a chew as I had to drop the selector off the box ( thought I might be able to push it through from outside) .... then could I realign the bolts!! ?!! Anyhoo ... all done Other side rebound to do then , the other ‘special’ bits
Nov 22, 2020 15:02:31 GMT
I normally put winter wheels and tyres on my ‘daily’ mini but have sold it on and my 2 remaining minis are too nice to be pressed into service over winter ... Tig youre it ..... Fiat panda 100hp with steelies and winter tyres on .... bring on the snow
Last Edit: Nov 22, 2020 15:57:47 GMT by rob1380
Nov 27, 2020 15:09:17 GMT
Other side not as bad, but worth a swap Slight split in boot .... will keep an eye on it... will replace on next next shopping spree While under cars .... rubber bung on backplate missing ( mini 40) ... reinstated ... with finesse Taking bits off for next job
