May 18, 2020 17:37:51 GMT
This caught the wave of logistics all the way through the postal system. Very surprised to see it here. It was sent Saturday from Colorado (for equivalence, that's further than Rome is from Birmingham). For $3. A couple of the other pieces haven't made it to the post office yet. Phil
Last Edit: May 18, 2020 17:38:49 GMT by PhilA
May 18, 2020 23:12:27 GMT
Did a little work on the radio after work tonight. The chassis tang broke off the center lug connector when I went to bend it down to the chassis. That sucked, so I pulled the socket apart and made a new lug end. Something that to the chassis first with my gas torch then bent it down and soldered it to the remains of the lug with my iron so as not to burn the phenolic. Reassembled, wired up and tested with a 9v square pp3 battery. Output pegs my meter off the scale set to 1500 VAC so I say it works still. Phil
Spent tonight dissecting the volume and tone control circuit. Discovered that this set has automatic loudness compensation- what the LOUDNESS button on a HiFi does. Boosts bass and treble at low volume to account for your hearing curve.
That's pretty sharp for a car radio
Phil
May 19, 2020 18:50:44 GMT
I need to get some screws and make a set of standoffs for the Bluetooth board. There's enough space for it down by the volume control; ideal place as that's where it needs to inject signal and there's switched power right there.
I think I will probably need to get an external antenna for the board (it has a socket) because the metal case will be pretty good at keeping the Bluetooth isolated...
Phil
On a whim, I bought a nice locally themed, locally made keying for my keys. Phil
Just had a look on Earth where you live. An airboat would have been just as appropriate! It's a tad watery down your way.
Just had a look on Earth where you live. An airboat would have been just as appropriate! It's a tad watery down your way. Moist.
May 20, 2020 18:25:39 GMT
Starting to amass quite a little collection. Got 2 more yet to arrive. Phil
penguin45
Still welding......
May 20, 2020 19:11:10 GMT
Computer keyboard. Valves. Irony.
P45.
May 20, 2020 20:10:17 GMT
Those valve look like they are lurking on a street corner with intent , ready to give any poxy silicone chip a damn good kickin !
May 20, 2020 20:29:55 GMT
Those valve look like they are lurking on a street corner with intent , ready to give any poxy silicone chip a damn good kickin ! The Analog Gang, the meanest bunch this side of the B+ rail
Last Edit: May 20, 2020 20:33:43 GMT by PhilA
May 20, 2020 21:04:26 GMT
Outstanding! You're a nutter Of the very best kind obviously Nick
Last Edit: May 20, 2020 21:04:45 GMT by vitesseefi
1951 Pontiac Chieftainglenanderson
@glenanderson
Club Retro Rides Member 64
May 20, 2020 21:15:36 GMT
I have an elderly Ferranti transistor portable that still just about works, aside from the fact that there's nothing on LW or MW to listen to any more. I've just splashed out a whole tenner on an ebay special bluetooth receiver and amplifier to see if I can graft it in, along with a new speaker, and have it working in a more modern style.
Shame. Here, MW is still very much alive and in use with some halfway decent programming. LW was never a thing.
remmoc
May 21, 2020 21:02:21 GMT
Got a lamp i made from a knackered gearbox , the rest of this is interesting Voodoo
May 22, 2020 16:44:06 GMT
14C5 power output tubes arrived. The rest of the parts that I need to actually start are still in New Orleans. Maybe they'll arrive tomorrow. Phil
May 23, 2020 21:31:34 GMT
Rebuild begins! Fixed the high voltage power supply and tested it: Great success! Phil
@glenanderson
May 23, 2020 21:48:03 GMT
That is impressive. Does the hum die down as the unit warms, or is it always in the background?
May 23, 2020 23:21:39 GMT
That buzz is persistent; it's how it makes the high voltage. A little bleeds over into the speaker but it is quiet- even more quiet with the rebuilt filter cap with bigger caps now.
I was going to ask how many different type of tubes there are, then, how long do they last, but then I was wondering "how do they work and what do they do?". This would be a grossly unfair question(s) for me to ask, so I'll go look at Wikipedia and report back once I've learned a little ...
Here's a better question: how did you get interested in electronics and was it an interest/education you got as a hobby, or all learned in school?
Best, John
