Don at Fatsco Transmission is checking stock to see if they have a replacement pressure regulator in stock. His computer said no, but he said he gonna go rummage in boxes to check for me.
New pressure regulator on the way.
That sounds like a good thing and hopefully quicker/easier fix - even if my speed-reading made me think it was coming from Fatso!
i cant remember phil is this fundamentally the same as my 4 speed in the temptress ? good luck with the reg , i hope it works .
i cant remember phil is this fundamentally the same as my 4 speed in the temptress ? good luck with the reg , i hope it works . Yup, same transmission. The regulator has softened the issues, but the issues remain when it gets pinging hot still. I'll be trying to get a replacement valve block that'll either work better than this or provide a mix and match of parts to work better. Phil
What's this? It's been vacuumed, washed and waxed. Something's going on.
i cannot remember i suggested this before phil , is it feasable to put a couple of connections on the sump of the box , and run a line to a little oil pump and a rad ,then back again , so the oil never gets hot enough to have the problems with the box your having ?
i cannot remember i suggested this before phil , is it feasable to put a couple of connections on the sump of the box , and run a line to a little oil pump and a rad ,then back again , so the oil never gets hot enough to have the problems with the box your having ? In this instance I believe it's not so much an issue that would be solved by cooling the oil; it's a thermal expansion problem, coupled with high mileage wear. I had put the pressure gauge on it after changing the regulator, and at least now it modulates the main line pressure properly (it would not perform that relative to throttle position before, it would get hung up and keep the pressure low, then suddenly jump up as the piston became free). Baseline is 60psi, with an increase to about 80psi when you've got your foot in it. Selecting R brings it up 120-150psi (averaging about 135) which is correct. The transition from Dr to N causes the line pressure to drop briefly to about 40psi. What I saw when it started to act up was that it was correctly holding 60-80psi when hot, but at the point it decided to change gear after getting hung up, a brief drop (a fraction of a second) to about 40psi before resuming and holding 60 once the gear had engaged. So, something is expanding at an inconsistent rate and getting sticky as it warms up. Reducing the oil temperature a little will likely not help a whole lot, as the valve body (alloy) is bolted to the transmission case (cast iron) and the shuttles, pistons and valves inside are all steel. Something's out of tolerance but I cannot find what it is. The main pistons move freely, the shuttles were a little rough but cleaned up.. unless it's a portion of the way it works that I don't fully understand, I'm stumped. Outside of taking it all apart again and sticking it in the oven to see what jams up, I'm out of ideas, hence looking for a replacement valve body. Phil
Last Edit: Oct 8, 2022 12:02:00 GMT by PhilA
it would be interesting to measure the oil temps , just in case they are outside the oils tolerance .
i know when i ran a c4 automatic, with a clutch , instead of a torque converter , on the rd in the v8 turbo tvr , after about 45 miles it would sometimes get iffy ,and behave oddly , a cooler fixed that .
i had thought i would get away with it because no torque converter making heat , but no .
it would be interesting to measure the oil temps , just in case they are outside the oils tolerance . i know when i ran a c4 automatic, with a clutch , instead of a torque converter , on the rd in the v8 turbo tvr , after about 45 miles it would sometimes get iffy ,and behave oddly , a cooler fixed that . i had thought i would get away with it because no torque converter making heat , but no . In general the primary source of heating the oil in an automatic is from the shear forces in the torque converter. The fluid coupling in the Hydra-Matic doesn't have that issue, being direct coupled. Also, in top you're generally not pushing that much torque through the coupling. Idling, the speed of the driving torus is reduced by being powered through the first epicyclic reduction gear. They found that only when being used to run light armored vehicles, behind a 200+ horsepower V8 did the Hydra-Matic need a cooling system. And that was with old type A fluid. The transmission doesn't get too hot that I cannot touch it after a drive.
Went out, got it nice and warm. It's been sat 30 minutes, and it was acting up when I was out (though worked really well for the first couple miles). Pointed underneath at the oil pan of the transmission. (Machine set to metric for your pleasure) That's honestly not what I would call too hot. Even worked real hard it doesn't really get much above 90°C and that's got Dexron 6 in which is stable to nearly 200 °C.
A little extra-curricular reading tonight. On my scratch paper, the band/clutch combination for each gear. Note the DOUBLE TRANSITION VALVE (pointed to by pencil) which is meant to be triggered by the 2-3 valve. What it does, when enabled, quickly dumps the front gearset into reduction (where it is for 1st gear). It overrides the gear selection valves. So, if the DTV is stuck on, F is in reduction all the time. In 1st that's not a problem, that's where it's supposed to be. 2nd is no change to the rear but swap the front to direct drive. If the DTV is stuck that won't happen; the selection from 1-2 keeps the gears in 1. When 3rd is selected, the DTV should operate, dropping the front gearset back to reduction and putting the rear in direct. Thunk, straight to third. It does that. Then, fourth selected, no change until I snap the throttle a few times which causes enough pressure change to make 4th actually happen by shuffling the DTV closed again. (If it sticks open, 1 and 2 are the same as 1, and 3 and 4 are the same as 3 on my paper, giving only 2 gears- at the shift point for 3rd) Exactly what happens! So, if all goes well I'll drop the transmission tomorrow and pull the DTV out (haven't pulled that out in a while because it's in the top of the valve block) and check for burrs, out of round, scores etc. That should fix it. The reason the new regular made a difference is that the main line pressure now varies- that change seems to be about enough to get the DTV to shift back under spring pressure. Phil
Last Edit: Oct 9, 2022 4:29:47 GMT by PhilA
well worked out that man !
well worked out that man ! I've gotta fix and prove it yet, but the theory is sound.
Last Edit: Oct 9, 2022 12:03:24 GMT by PhilA
Yup. That was definitely the problem. It's still not perfect but I didn't want to go all hog-wild in case it wasn't. I'll redo it and get that polished better.
what bit am i looking at ?
what bit am i looking at ? Magnetic bowl full of screws from the side pan and other fixings on the left. Valve block on the right, goes under the side pan with all the pipes coming to it from the governor. This bit, just in fewer pieces. Lives here.
Last Edit: Oct 9, 2022 19:38:34 GMT by PhilA
Again, drained and removed. That valve there. Right there. It's been dropped (like them all). Removed that burr and reassembled. Test drive- cold, very good. Hot it now changes to 4th by itself but 1st gets hung up still, but can be made change by snapping the throttle shut above 5mph. Improvement, for sure. I think the spring needs to be replaced, it's a bit weak. Phil
most excellent . i see that valve.. right there !
Oct 10, 2022 14:21:48 GMT
I guess at this point in time... Most of the mechanical pieces are in useable condition.
The body needs attention. I've been avoiding it, but it looks like I cannot ignore it any longer.
Plus, the paint is all beaten up now; that's one reason I was avoiding doing anything, to keep the shine as long as possible.
Thoughts?
