1951 Pontiac Chieftainpeteh1969
@peteh1969
Club Retro Rides Member 107
Feb 23, 2019 10:16:21 GMT
A question to others not so much Phil sorry, Is there a type of Fogger available in the UK not LPS-4 I have searched and not found and they are cleaners and greases rather than a spray oil?
I want to use something other (better) than WD40 if possible.
Last Edit: Feb 23, 2019 10:16:41 GMT by peteh1969
Feb 23, 2019 12:44:39 GMT
I'm sure- best people probably to ask would be boats/marina type places, as marine engines often get lain up for long periods in damp conditions.
Phil
Feb 23, 2019 20:40:33 GMT
I had heard one pot down on compression last time I ran the engine.
Having pulled the head off and rotated the engine, the exhaust valve on no.8 was jammed open.
Turns out the bolt holding the manifold on was leaking past the gasket and it had drawn the coolant in, and gotten into the valve stem and jammed it up.
Much P'Blaster and hammer handle later it's free and moving merrily.
I'm so glad a sidevalve is non interference!
Phil
Bought some new scraper blades and set about on the cylinder head. Brass brush on the combustion chamber. Scrub scrub scrape scrape. Repeat. The pistons wipe clean with a little carb cleaner. All coated in protective oil for the night. Big storm rolling in, I've given up being in the garage, it's hot and windy. Phil
eternaloptimist
That’s looking great.
Feb 24, 2019 18:03:15 GMT
A question to others not so much Phil sorry, Is there a type of Fogger available in the UK not LPS-4 I have searched and not found and they are cleaners and greases rather than a spray oil? I want to use something other (better) than WD40 if possible. peteh1969, You might look into Duck Oil (Swarfega product). A friend of mine swore by it both as a penetrating oil and to prevent rusting, etc. Very fine oil. Craig PhilA : Keep up the good work, loving the straight 8!!! C
Last Edit: Feb 24, 2019 18:05:24 GMT by craigrk
Feb 24, 2019 18:37:48 GMT
Feb 25, 2019 16:14:48 GMT
pleasure... like a challenge.
Feb 26, 2019 15:33:19 GMT
Power went out last night, so I went to the garage, lit my kerosene lamp and carried on work with the cylinder head. It's not great, but it's not bad. The front end of it appears to have been weeping slightly. I'll see what it looks like once it's cleaned up; it may just not have been cleaned properly. Phil
Flat face of cylinder head. Acceptable. Phil
@peteh1969
Feb 27, 2019 10:45:37 GMT
Phil
Do you know what the Slot/Cut Out in the compression chamber of 1 & 8 is for?
Feb 27, 2019 16:49:07 GMT
Really, I have no idea. It's on the intake port side, so possibly end of run flow alteration? Your guess as good as mine, I'm afraid.
Phil
Feb 27, 2019 18:34:35 GMT
Soon I shall be splitting the gearbox from the engine.
You can tell this is wartime engineering; there are 30 bolts securing the flex plate to the fluid flywheel, then a further 6 bolts holding the gearbox bellhousing to the engine.
Overkill, anybody? The flex plate is fixed with 6 bolts on my truck.
Phil
Feb 27, 2019 19:10:52 GMT
No, but it's a pain to undo! Phil
Last Edit: Mar 1, 2019 3:41:04 GMT by PhilA
Made the first pass over the block deck with my blade. Looks good. No signs of visible cracks between the bores, the liners haven't moved and everything's in pretty good shape, if not dirty. Second pass to follow, then the head bolt threads to be chased, a thorough clean and oil. Phil
totti
Hi! Do you think the block is fitted with liners?
Greet
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
