Darkspeed
Club RR Member Number: 39
Still doing the brakes - quite a few hours gone into this now Copper pattern and finished Kunifer M/C to front junction is complete and M/C to rear is 60% completed - Tomorrow I should get them both finished with clips. Once that's all done I can start bonding the panels on.
Last Edit: May 5, 2024 22:14:17 GMT by Darkspeed
Darkspeed
Darkspeed
Collected the paint today - may even use some of it on the cylinder head tomorrow and see if its a suitable colour.
Struck a few lines off the to-do list and made a start on the wiring. Just one last panel to bond and rivet which will be done after I have drilled a few holes for electrics cable management.
A small amount of time today placing orders for nuts, bolts and engine parts. Having placed all of the various fasteners in a larger bucket when I stripped the car there are hardly any that are the same length or the same brand even though there are only 4 sizes of M8 that keep most of the car together !
Photo's tomorrow
Last Edit: May 9, 2024 10:40:30 GMT by Darkspeed
Darkspeed
So, what did I manage today? The tunnel top panel got bonded on. Tested for wiring fit. And then bonded Made the loom good with some new sleeving and clipped it in - 8 cores to the rear should be more than enough Sides Brakes L/Ind R/Ind Fuel sender Fuel pump Earth And a spare by the looks of it Cut the slot for the handbrake No painting, so that's on the agenda for tomorrow as is a trip up the barn to collect a few more parts
Last Edit: May 9, 2024 21:42:08 GMT by Darkspeed
Darkspeed
May 11, 2024 22:26:02 GMT
Parts have arrived - a box from Burton containing +60 1300 pistons plus a load of gaskets, and a package from Namrick with the required nuts and bolts. The bracket that holds the handbrake cable and the rear axle flexi needed some tidying up as it looked but after a bit I deceided that the design was all wrong and inherently weak for the weight of the thing so I have made a start on a new stronger lighter version. And made a start on measuring up for the roll over hoop
Darkspeed
May 13, 2024 19:30:44 GMT
Darkspeed
May 14, 2024 21:47:55 GMT
Started to have a look at the wiring - Using a loom from another project to lay out the best route and make notes of what needs to be included. I will just have one loom that will run 3/4 of the way around the "U" of the engine bay. I will need to mount items like the ignition coil, horn and the fan switch relay. Whilst also trying to keep them out of the way and tidy.
Darkspeed
May 19, 2024 16:18:27 GMT
Darkspeed
May 20, 2024 22:14:26 GMT
A few hours work this evening. The fuse box and the relay bases are in, and a few of the connectors are done. Almost finished the fan wiring, just the power connections to make which I hope to get finished tomorrow.
Darkspeed
May 21, 2024 21:41:07 GMT
Sleeved in some vinyl this evening - Just need to drop a bit of heat shrink over the joins and some tape over the big T joint out of the bulkhead - I try and keep wrapping to a minimum and not a fan of the split conduit type stuff. Hope I have not forgot any cores - Switches and relays next.
Darkspeed
May 25, 2024 22:13:40 GMT
Last Edit: May 26, 2024 7:11:35 GMT by Darkspeed
teaboy
Make tea, not war.
May 25, 2024 22:28:42 GMT
Nicely rounded off brackets are much better.
I say black uprights.
Darkspeed
Hmmm.... I had near settled on Aluminium. This is mainly due to the G27 and the Litton having Aluminium uprights / axle carriers so it being a continuation of the theme of Grey Chassis - Black Suspension arms - Aluminium Uprights. Today's work will be interrupted by the F1 but the aim is to get more wiring completed, test a few circuits and order the roll hoops.
Darkspeed
May 26, 2024 20:59:13 GMT
And Aluminium it was - I think they look lighter which is almost as good as being lighter Not much wiring done as I made a brake reservoir bracket - I really should buy or machine up some dimple dies Get another day on it tomorrow so perhaps use that to progress the wiring - The speedo sensor is something I need to find and have a read about, as it may need to have the upright drilled to pick up on the disc mounting bolts.
Darkspeed
May 27, 2024 20:39:17 GMT
I fitted and piped up the brake fluid reservoirs - just a couple of grommets needed. The prop got cleaned and painted The front suspension is now getting assembled A very small amount of wiring was done - and some time was spent looking at possible coil mounting arrangements. Could not find the speedo sensor - not 100% on if I actually have one so that may need to go on the shopping list. Better get the block and pistons off to the engineers.
Darkspeed
May 27, 2024 21:23:43 GMT
Tank after its makeover And an electrical test Would be nice to think I will be giving it a run out on a summer night this year
Darkspeed
May 29, 2024 19:25:03 GMT
A quick couple of hours after work. Put the axle in It centred its self perfectly Which highlighted one issue I was aware of - The amount of thread engagement on the Panhard rod when in the correct position. And one I had missed - How close the prop flange runs to the chassis If you note on the LHS the vertical tube is to the left of the lower chassis tube - on the RHS it is on top of the lower chassis tube making it 1" closer to the prop - I believe that tube would be better at an angle following the line of rivets you can just make out. A miss is as good as a mile so I will see what happens through full axle articulation. It is also a bit closer as this is the big flange. As I am making a new Panhard rod 18mm longer I will fit a Rose joint on the axle end to reduce the amount of give provided by the rubber bushed ends. You will no doubt notice that I have not painted the axle yet - It is going to be used as is whilst I assess the 3.54 axle ratio and decide if I rebuild it with an ATB diff. As The axle will need to be fully stripped to paint it that can happen over a winter period. Almost a rolling chassis No wiring done today
mk2cossie
Club RR Member Number: 77
May 29, 2024 19:52:46 GMT
No wiring is a maybe, but still good progress there The axle location tabs look so much better now as well 👌
May 29, 2024 23:05:28 GMT
Every time I look at this thread in the menu list I always read it as an Elvira replica How can someone make a bracket & not radius it?
Darkspeed
May 30, 2024 15:56:19 GMT
Every time I look at this thread in the menu list I always read it as an Elvira replica How can someone make a bracket & not radius it? LOL - I am sure someone somewhere in the USA will have one .... to go with Lily Munster, Morticia Adams and Vampirella.... For me it would be Santanico Pandemonium. But only as I am a Tito and Tarantula Fan... The list of WTF! - WOE? - FFS! - Really! on an Autotune chassis is extensive.
