hello all
I bought a portable gas hot water system. It runs great. Hot water plenty buuuut only from the mains water. Not hand as my next trip will be about 3500Km and my hose is only 75 meters......
So I thought a watertank on the roof will gravity fed my hot water system. I does but the pressure is to low to get it going. I need at a minimum
0.3mpa or 43 psi.
I can buy a 60W 12V 80PSI (0.8mpa) pump on eBay for a few dollars.
My plan is ; Tank ....little length of garden hose to pump...little length of garden hose to hot water system....Is this the right set up?
Thanks a lot
0.3mpa or 43 psi.
Thanks a lot
