nigxl
Apr 17, 2018 18:46:25 GMT
That looks very nice Wayne. Yeah It's a 3 pin connector with 3 separate stand alone ECUs. I've got the adaptor lead with power connectors which I think is working as a mate with snap on managed to connect to the airbag ECU and read faults. Failed to connect to the engine ECU though. I think my usb lead is a cheap copy that won't work so I need a new one with a different chipset.
nigxl
Apr 17, 2018 19:05:33 GMT
Oh if anyone has a spare fuel flap that would be good as mine is kaput. New genuine item ordered forget that
Last Edit: Apr 19, 2018 20:39:55 GMT by nigxl
nigxl
Also I may need an Airbag ECU part No: 60625181 Thanks
nigxl
Apr 21, 2018 19:03:41 GMT
So new USB with correct chipset arrived today with a hard copy of MultiECUscan 3.9, good instructions on how to alter port settings and rates and drivers to download for the cable etc. Worked perfectly but I needed the paid version as mine is a phase 1 car so I had to upgrade to 4.0 and now it keeps reverting to the home screen whenever I try to connect to the engine ECU Guess I need updated drivers.
That stuff baffles me but hope you get your head round it
nigxl
Thanks for that, yeah I have adjusted my computer as it should be done. Going to have another crack at it today after re installing the drivers again.
nigxl
Apr 22, 2018 10:27:11 GMT
Got it. I didn't have a steady 12V supply to the lead as I was powering it off my trickle charger and I'm guessing it didn't have enough guts. Picked up the cigarette lighter supply and everything is good again . Removing front coil springs is a different matter, can't get them to compress enough to release.
nigxl
Apr 22, 2018 14:52:18 GMT
And when they do compress you need some stupid Italian tool to hold the strut while you undo the nut or you break it like I did. Then it's bruised knuckles time and out with the chisel.
Apr 22, 2018 16:09:06 GMT
I say that if your knuckles arnt bleeding then your not trying hard enough, I hate it when you get days were your car is doing it on purpose just to p#ss you off
nigxl
Apr 22, 2018 17:15:24 GMT
It's every Fu****g day so far with this car. You'd think it would be grateful.
Apr 22, 2018 17:27:27 GMT
Hi there
i've run gtv's and spiders for quite a few years.
If you are wanting to work on the car you will need a ribe bit set. Like a square torqx.
Cheers - mike
Apr 22, 2018 17:28:45 GMT
Hi again
there's a specialist Alfa breaker over in Thorpe Arch, near Wetherby. He had quite a few gtv's and spiders when i was last there.
Cheers - mike
nigxl
Apr 22, 2018 17:48:12 GMT
Hi there i've run gtv's and spiders for quite a few years. If you are wanting to work on the car you will need a ribe bit set. Like a square torqx. Cheers - mike Yeah that's the one, cheers for that. Thought I would be able to get away with torx looking on Alfa Owners forum but obviously not this time.
nigxl
Apr 22, 2018 17:59:40 GMT
Do you have a particular set that you use Mike? Not really keen on cheap tools as I'd like them to last
nigxl
Apr 22, 2018 18:11:57 GMT
Hi again there's a specialist Alfa breaker over in Thorpe Arch, near Wetherby. He had quite a few gtv's and spiders when i was last there. Cheers - mike Thanks but that's a little too far for me.
Apr 22, 2018 21:12:27 GMT
Hi again there's a specialist Alfa breaker over in Thorpe Arch, near Wetherby. He had quite a few gtv's and spiders when i was last there. Cheers - mike Thanks but that's a little too far for me. Only an hour and a half from me though, handy to know that cheers
Hi again there's a specialist Alfa breaker over in Thorpe Arch, near Wetherby. He had quite a few gtv's and spiders when i was last there. Cheers - mike Thanks but that's a little too far for me. Hi i'm not sure f the make as I have had them for 20 years or more Cheers - mike
nigxl
Think I might have to invest in some of these too
