Oct 30, 2018 21:53:17 GMT
Last Edit: Oct 30, 2018 21:53:37 GMT by Deleted
Oct 30, 2018 22:46:05 GMT
Like you say it not about the money as I'm not planning on part with it that one's Been advertised for a while now he also had some parts for sale momentum been a bit slow as the darker nights and work but have been chipping away at it bit by bit another couple of weeks and the inside should be ready to go back together fingers crossed
Maneged to get the front panels bolted back in and got them in primer it's starting to come together again
Looking for a bit of advice was going to put the wiring loom on the morris commercial lc3 but in the manual it's wired positive earth my question is if I swap the the wire around earth to is it then just a matter of swapping the wires on the coil around or is there more to it than that
Morris fgk30 1967glenanderson
@glenanderson
Club Retro Rides Member 64
Pretty much. Hardly anything is actually polarity sensitive. Wire it as per the standard diagram, but connect the negative terminal of the battery to earth. You probably won’t even need to flash the dynamo if it’s not been used for a while.
Thanks for the advice just wasn't 100 percent sure will see how I get on
Nov 28, 2018 20:46:53 GMT
Had a play about with some rattle cans just to see how the colours Go together This is what I'm going with also moving the cab into a work shop this weekend as it's been to wet and dark to work outside
Nov 28, 2018 20:58:06 GMT
glad your back
Nov 28, 2018 21:26:12 GMT
Progress is progress!
Good to hear you got a workplace sorted for it.
Nov 28, 2018 22:41:50 GMT
Dash pod looks nice.
Nov 28, 2018 23:08:12 GMT
this is and has been my resto i look forward too see
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Morris fgk30 1967retrolegends
@retrolegends
Club Retro Rides Member 94
Nov 29, 2018 17:07:42 GMT
Green and White then? That's going to look lovely 👍🏻 Are you going full on Roadline?
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
More like this only it will be cream not white
Good call to use cream, avoid the stark white.
Looking for some advice I've used this high biuld primer on the roof I stripped it back to bare metal and was told I'd would be ok to apply this primer straight to the metal as I did now been told by another guy I needed to use a etched primer first as it will blister or peel so not sure if I should take it all off again three coats by roller or leave it. Any one
You don't need etch. Advert states outstanding adhesion - if correct you are fine.
I would have advised using 2K epoxy sealer/primer as it sticks like the proverbial brown stuff to blankets and is amazingly strong as well as being nearly waterproof.
Very few painters use etch - it can cause a lot of paint issues with reactions if you don't know what you are doing and is somewhat old school now.
When I was 6 in 1976 dad took one of these to a quarry in kirkstone pass. It was on such an incline with big dangerous cliff edges we didn't know if we could make it so we parked up and walked it first. I was so scared I walked it back down and would not get in. I walked it up and watched dad drive it which it did easily. On the way down I hopped in and could see massive drops through the threepenny bit Windows. Love your build, always look for it. Keep going mate cheers jed
Love old story's like that
