While I like a bit (ok, alot) of dish and a bit of -ve camber, that is fairly extreme. Not wishing to rain on your parade, but as someone who has run small chassis Triumphs pretty low in the past (but not that low!!), I can tell you that the handling like that will be beyond scary, especially on bumpy/undulating roads, and you'll need to negotiate good terms with your chiropractor/osteopath...... In grip terms it probably will drift with ease as that represents the worst of all worlds with massive -ve camber and wide tyres stretched onto even wider rims preventing them from even attempting to conform to the road surface. When that low, bad things happen at the back in terms of track and toe change and bump steer will be a particular problem at front. IMO to get that look and be able to drive the thing as well, you need to be on air so you can pop it up a bit when driving. Also be aware that the driveshaft breakage is not often down to torque (happens on 1200/1300 cars as well and they don't have any), but stress raisers caused by wheel bearing wear and oil seal lips on the driveshaft - plus constant flexing - which is worse on very low cars with loads of -ve camber. 3 wheels on my wagon and no brakes either...... Nick I think we all agree with this.......But just look at it!!!
smith4
Mar 31, 2018 20:06:47 GMT
Thanks all again for your comments and likes Nick - thanks for your info.. Bump steer - yep, will be bad. Some cars (eg: MGB) you can bolt the tie rod ends/steering rods upside down to decrease bumpsteer, but I don't think this is so easy on the small chassis Triumph cars. I am looking into a way of decreasing the bumpsteer. Sadly the rack cannot be made higher as the replacement engine won't allow that so I can't use that solution. Rear track and toe changes will be minimum due to the much reduced suspension travel. The main problem here is the connection of the leaf spring to the vertical upright, and even using poly bushes, there is still a noticeable twisting motion, which is where the toe changes are noticed. I have an idea to minimise this twisting motion to hopefully a more acceptable amount, but it won't be fully removed until I can achieve a rear CV/wishbone setup at some point in the future. Driveshaft stresses - I knew about the wheel bearing wear but wasn't 100% clear on the oil seal lips. Even Summer Brothers 'un-breakable' race axles I believe have snapped on one or two race Spitfires, so the only way to really remove the chance of this happening is a CV/wishbone set up. Until then, regular rear wheel bearing changes will have to do
smith4
Mar 31, 2018 20:12:45 GMT
While I like a bit (ok, alot) of dish and a bit of -ve camber, that is fairly extreme. Not wishing to rain on your parade, but as someone who has run small chassis Triumphs pretty low in the past (but not that low!!), I can tell you that the handling like that will be beyond scary, especially on bumpy/undulating roads, and you'll need to negotiate good terms with your chiropractor/osteopath...... In grip terms it probably will drift with ease as that represents the worst of all worlds with massive -ve camber and wide tyres stretched onto even wider rims preventing them from even attempting to conform to the road surface. When that low, bad things happen at the back in terms of track and toe change and bump steer will be a particular problem at front. IMO to get that look and be able to drive the thing as well, you need to be on air so you can pop it up a bit when driving. Also be aware that the driveshaft breakage is not often down to torque (happens on 1200/1300 cars as well and they don't have any), but stress raisers caused by wheel bearing wear and oil seal lips on the driveshaft - plus constant flexing - which is worse on very low cars with loads of -ve camber. 3 wheels on my wagon and no brakes either...... Nick I think we all agree with this.......But just look at it!!! Jonsey - thanks, you nailed it
smith4
Mar 31, 2018 20:21:30 GMT
So, finding some photos of the shocks, they are from Gaz, and out of their catalogue but they have to build them when you order. The front ones are wider and made so they can take really heavy springs, and the rears are narrower as they don't needs to take the same heavy spring rating. I got the springs made up from a place in Sheffield as they had good reviews and were very reasonably priced. Here's a rear shock with spring: The bushes were sadly the wrong size, so I ground down some poly bushes to fit as a temporary measure to mount the shocks until I can get some proper bushes made up.
smith4
Mar 31, 2018 20:34:18 GMT
smith4
Mar 31, 2018 20:35:34 GMT
Edit: Rood should be Roof!
Mar 31, 2018 20:38:49 GMT
passed the mog test!
smith4
Mar 31, 2018 20:48:26 GMT
On GT6s, or at least the early ones, the steering column is adjustable slightly for length and height. But to get it in the best place for me, it needed to be made a little lower. To do this, I bought some high tensile threaded rod to replace the long allen bolts that hold up the column into the under-dashboard mounts, and made up some aluminium spacers to space the column lower. I need to neaten up the spacers, but they are solid. I also needed to re-drill the bulkhead with a lower hole for the column.
e28
Mar 31, 2018 21:00:12 GMT
As a GT6 owner, I am watching with interest!
92 NSX 77 528 83 635csi Turbo 95 540i/6
smith4
NON-HISTORIC UPDATE! Got a miraculous bargain of an original aluminium GT6 grill for £2! It was all matte black, so I cleaned the matte black off the horizontal bits and gave a light sand and from a distance they look chrome. Also, I taped in the headlamps for a quick looksee. Looks like GT6 is happy with it's new grill!
smith4
Back to historic updates . . . So, I thought the sills were okay and just needed a little welding on the bottom and inside to join them up, bit after my maye so kindly came to do that for me, the sills were found to be a bit too dead. So a sufficient piece of metal was tacked into place across the door gap and the whole inner/outer sill section cut out 😲 The A post was a 'bit' dead too, so that also had to come out!! A new piece where the bolt bolts through the floor to the chassis here had to be made: Now nice and solid . . .
smith4
A whole side of inner sill, outer sill, sill strengthener, A-panel, and sill end was bought to weld up the huge hole in the side of the GT6! ☺ My mate set about welding them in, starting with lining up the new A-post. And then the sill strengthener. The outer sill was a pain and didn't fit properly. The horizontal lip across the top of the outer sill was too short, so I had to bend it flat and use some of the vertical bit to make the horizontal bit longer so that it fitted better.
ivangt6
Club RR Member Number: 132
1967 Triumph GT6 (Smith4)ivangt6
@ivangt6
Club Retro Rides Member 132
You're tackling the exact bit I left off with. I think that sort of inner lower a-post bit is available. It had already been replaced on my car. There is also a stiffener that attaches where the chassis mounting bolt goes through the outrigger and sort of curves down inside the inner sill. Very neat work, looking forward to the next update and that grill is a great find! (Edit) should have waited 5 min longer to post New sill looks goooooooood
Last Edit: May 1, 2018 18:48:50 GMT by ivangt6
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
smith4
smith4
Rear and rear valance area were really bumpy, really noticeable with the etch primer . . . So I bought a large tin of light-weight car filler and begun:
smith4
That's all for tonight!
ivangt6
@ivangt6
Wow you work fast. What sort of setup are you using for paint?
smith4
This is all hisSPAM pretty much, so over the last three years !
Paint is all rattle cans. Upol etch primer, Tetrosyl trade grey primer, Tetrosyl trade white gloss (all these from Ebay) and cellulose yellow from nearby paint place.
It will be a daily driver so I need something I can touch up myself easily, so point me paying loads for a profession respray.
smith4
Meant to say its all pretty much historic - don't know how the SPAM got in there!!
