Jan 26, 2018 19:43:58 GMT
Evening Folks,
my previously reliable air compressor has started misbehaving itself. when it's filling and gets near the cutoff pressure the air pump is making a strange noise that sounds distinctly like metal on metal grating and it sounds ready to stall, the top section of the air pump is very hot to touch as well.
If i let it cool down again then it fills fine until near the cut off point again when it repeats the above, I've checked the oil level in the pump and it seems fine, is just below max on the dipstick. I don't know much about compressors so could do with some advice on what to check
thanks, Chris.
Jan 26, 2018 21:52:09 GMT
It might be...
Compressors (mine at least) doesn't have valves in it like a car engine. It has a couple of metal flap valves that swing on a couple of metal pins. They are sucked open and blown closed by the air movement. Sadly I don't have photos. One of them can tap the top of the piston when the pressure in the receiver is high. It sounds to me like a metallic rattle on my compressor. Almost like loud pinking on on a petrol engine.
If mine is achieving pressure I don't worry about the noise. But if the head gasket is leaking it'll rattle more and not achieve pressure. Or if the valve is bouncing (I think on mine the head gasket puts some pressure on the flap valve to bias it shut) it'll struggle to get pressure. At that point I take the head off, cut a new gasket from gasket paper and turn over the flap while I'm in there.
They do run hot by the way. Compressed air gets hot. That's why turbos have intercoolers. It's also why you need to drain the tank each night. Hot air carries water which condenses in the tank and can rust it out from the inside.
James
slater
Club RR Member Number: 78
Jan 27, 2018 20:22:16 GMT
Strip the pump and have a look. Could be a number of things really..
Jan 27, 2018 22:21:58 GMT
I rebuilt my compressor pump last year, the conrod bearings were starting to seize so i emery papered them and cleaned everyone up. Now run it on 5w30 motor oil. Smells lovely when the compressor warms up!
Feb 12, 2021 21:14:44 GMT
As much as I understand that you want to fix your air compressor I'd rather go with buying a new one as there are many discounts available if you look around at the moment.
Feb 23, 2021 13:22:09 GMT
I always chose to buy new things as they are easier to work with and lasts longer rather than keep fixing something broken. Not sure what you guys thought of as the best choice in 2019 but right now I have a very nice Dewalt which I bought for a low price! I was never a big fan of having my own air compressor until I had to use it for other work at home and the workshop I'm working. It's more convenient to never have to waste time in a gas station anyway, let alone that you can really get some true quality if you compare all air compressors kylesgarage.com/best-air-compressor-under-200-top-6-reviews-and-buying-guide/ that are being sold for about $200 .
Last Edit: Feb 26, 2021 0:55:10 GMT by doorzz
