Hi,
I thought I would try a post on here to see if you lot may be able to help me.
I'm currently in the process of fitting air ride to my Mk2 Granada. I have the tank, compressor, management and air lines but all I need to sort out now is the bag themselves.
The problem that I have got is that the damper runs through the middle of the spring on the front and rear of the Granada.
Now obviously I can replace the spring with the bag and relocate the dampers, but I wondered if anyone knew of any bag on the market that had a hole through to put the damper back in its original place?
I'm not shy of a bit of fabrication but it would make life a lot easier if the dampers remained in the original locations.
Any help appreciated!
