samta22
Stuck in once more...
Club RR Member Number: 32
Seeing you squeezed in there would be worth keeping it stock for the comedy factor alone, however for commuting duties it would be a little dangerous if not mildly uncomfortable I'd imagine... A plan for the Saturday at Goodwood next year is forming...
May 22, 2018 10:16:25 GMT
And then there is you.....
6’8” in your socks.
You should be able to fit one size 12in each footwell.
May 22, 2018 14:54:38 GMT
Bubble roof or perspex dome - like the one on the Moon buggy in Diamonds are forever?
May 22, 2018 15:42:26 GMT
And then there is you..... 6’8” in your socks. You should be able to fit one size 12in each footwell. And herein lies the problem.... I am size 13 😂😂😂
May 22, 2018 15:43:36 GMT
Bubble roof or perspex dome - like the one on the Moon buggy in Diamonds are forever? Subtle little change that unless you know where to look, wouldn’t be immediately noticeable 😊
May 22, 2018 16:56:55 GMT
Subtle little change that unless you know where to look, wouldn’t be immediately noticeable 😊 In keeping with the rest of the vehicle. Nice. 👍😂😂
v8ian
May 22, 2018 17:13:14 GMT
You have 2 roofs, 2 sets of pillars, do a roof chop in reverse, a roof lift!!!!!
May 22, 2018 18:09:37 GMT
You have 2 roofs, 2 sets of pillars, do a roof chop in reverse, a roof lift!!!!! Stick around,I make you famous....😂 I don't raise the roof,I lower the floor...😂😂
Last Edit: May 22, 2018 18:10:51 GMT by Deleted
May 22, 2018 18:44:00 GMT
make a double cab
May 22, 2018 18:54:33 GMT
^^ That kind of comment can only come from the other side of the Boerewors curtain 👍😂😂😂
May 22, 2018 19:03:21 GMT
cab-ri-o-let!!
May 22, 2018 19:03:57 GMT
true, but i seem to recall your inspiration came from here, somewhere between the boerewors and the biltong
May 22, 2018 19:16:24 GMT
You have 2 roofs, 2 sets of pillars, do a roof chop in reverse, a roof lift!!!!! Stick around,I make you famous....😂 I don't raise the roof,I lower the floor...😂😂 Titanium skid plate low?
Stick around,I make you famous....😂 I don't raise the roof,I lower the floor...😂😂 Titanium skid plate low? ....Not a bad idea. I do actually have some offcuts of titanium,surplus to my needs 😎
May 23, 2018 21:05:14 GMT
I started making parts for this project 2011. Don't even want to hazard a guess as to the number of hours I spent on it. Ran for the first time in Overloon, Holland,last weekend
luckyseven
Club RR Member Number: 45
May 23, 2018 21:12:59 GMT
French tank moving forwards? Did you get the gearset installed back to front?
May 23, 2018 21:27:44 GMT
May 23, 2018 21:37:42 GMT
I am glad it's done. I am proud to have been a part of it. I have more drawings of parts in it,that probably any body else on the planet. And yet ,after the thousands of hours spent on it, I will probably remember it for the simplest of simple parts The cap on a emergency petrol can. Gave me a fizzy feeling looking at it after I made it..😁 One of those,"Damn I am good " moments, that don't happen very often 😊
Last Edit: May 23, 2018 21:51:26 GMT by Deleted
May 23, 2018 21:50:22 GMT
I started making parts for this project 2011. Don't even want to hazard a guess as to the number of hours I spent on it. Ran for the first time in Overloon, Holland,last weekend Saw some photos of it next to a King Tiger which made it look like a Dinky
May 23, 2018 21:52:15 GMT
...And slow 😂😂😂
