Sept 4, 2007 13:06:08 GMT
This is whats been causing the hold up. Having had some advice on what socket to get, and where to get it (A/F tools having gotten pretty rare these days!) Paul and I could do a little more strip down The input shaft is a known problem on abused trannies but this one seems to have survived my abuse of it OK. rear (direct) drum and shaft assemblies also checked out when stripped. this is the front drum, this baby had run dry and the clutch packs were toasted. Also notice the scoring due to band slippage, the bands are pretty much fubar too. At least the sprag is in good shape no bother, all the plannet gears were good, even the little support bearing chappies looked almost like new. I've left it with Paul pending parts arriving.
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Sept 4, 2007 14:40:36 GMT
not too bad all round then, good to see its on its way
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Sept 4, 2007 15:40:48 GMT
I think I've got an AF socket/wrench set........D'oh! Didn't realise it's hard to come by that stuff! Anyway, glad to see it's coming along Will be nice to see it going again! What's the plan with the box back in - anything else need doing straight away or just going to smoke about in it?
Sept 4, 2007 15:49:30 GMT
it needed to be a deep type socket and a bihex pattern. Needed to be special ordered but no big deal. I can really recommend Cromwell Tools for that. Top guys and friendly service too.
Box is going back together with a mild valvebody / shift improver kit, possibly a B&M vacuum actuator, decent external fluid cooler (rather than using the rad)
I've started painting the bottom of the Olds as it was surface rusting and I've seen how these things go from a bit of surface rust to fuggin great holes in no time before.
Its kinda tempting to attend to the bopdy and paint woirk while its off the road. If only so when I take it for the MOT to get it back on the road I don't have to put up with the incessant moaning about how all my cars look like complete curse word from my tester...
But it would be easier to get it painted properly once its on the road again and I can take it ot a proper booth to do it rather than trying to shuffle round it at home.
Sept 4, 2007 15:58:48 GMT
Hat off to anyone brave enough to delve into an autobox for a rebuilt! As usual, top work.
Peugeot 307sw - Suzuki SV650S - MX5.
