So it turns out I'm not very good at keeping project threads up to date. Or using reliable image hosts (facebook? What was I thinking?!).
Also can't seem to find the edit button, so the above posts will have to stay as-is for now.
I'll try and give a bit of info on the direction the little KP has taken over the past 14 months. May well have missed out some major bits, so please comment in discussion thread if I've missed anything vital! Plenty of stumbling blocks in what I naively assumed would be a reasonably easy project, so hopefully some good points come out that will be useful for others. Bear in mind my only real previous projects were stripping a Saxo for track days and modifying my MR2 with new seats, chopped springs and banded steels...
SO!
Yes, got some Work Equip 01's from Beaver
Shod them in rubber and got them bolted on. Arch gap present to an alarming degree, but this was imminently pre-nats '15 and I owned a socket set and some screwdrivers.
Plus I was a little busy trying to get some shonky twin 40 DHLA Dell'ortos running. Had never tuned a carb in my life at this point.
Eventually gave up on the rubbish linkage and bought a nice Mangoletsi one from Europe which helped balancing and throttle travel adjustment immensely. Seriously recommend these.
Miracle of miracles, I got the car running pretty nicely on the crabs. New exhaust had turned up the previous day and didn't need to change the tune too much. Would cold start okay, idle happily, keep a sensible temp (I think, lol Toyota gauges) and over my (whole) 30 minute test drive was happy throughout the rev range and emitted plenty of doorts. Oh, this was the night before Nats, sweet.
Nats started wonderfully, did a 4 hour burn up to Taupo after work the night before, stayed the night there, then set off for a further 4 hours to Coromandel the following morning. Cold starting an over-carbed 4k with a loud exhaust in a motel car park at 6am is a fun game.
Got stuck behind a boat trailer on the wiggly Coromandel coastal road for about 40 minutes, meant a lot of partial throttle compared with the all-or-nothing it had been getting up to that point, and that's when I noticed something wasn't right. A bit of hesitancy coming out of corners, a little coughing. Quickly developed to a bigger problem...
Plugs were coked to hell. I knew it was rich (safe, bruh), so cleaned them up and set off again.
Better, but quickly buggered itself again. Noticed fuel pouring out of the rear carb, forming nice little fuelly waterfalls from the trumpets. Damn.
Pulled the carb apart at Beaver's parents place, looked to be a float issue, the pivot for the float had broken and been bodged with a bit of wire at some point. Had worked for a while but the curse word fuel was almost certainly down to that. Abandoned the KP there, it would get shipped back thanks to AA plus (win), and I'd have a fun nats tagging along with Sparkle and Goat.
When I finally got it home, I swapped the original carb and some fresh plugs on to see if it would run. No luck, barely ran on a couple of cylinders, rough as curse word. Suspect overfuelling on 3 and 4 had washed the bores or something? Oh well. Was thinking of getting a 5k (1500cc 'big block' version of the 4k) anyway.
5ks were about $500 at this point for a runner. Not bad. Could rebuild carbs (arguably better suited to a 1.5 than a 1.3 anyway) and swap them over to the BIG BLOCK.
Bought one!
Oops. Looks like it needs a decat too.
Mate back home made me a keyring to celebrate this new direction:
Dragged the little green paperweight to Goat's workshop, and things started happening.
Massive shout-out to Goat at this point, couldn't have gone any further with the car without his help. There are definite downsides to moving to a new country and not knowing anyone, but one of the major upsides is meeting ultimate GCs that are willing to help out at any point.
4k took about 15 nanoseconds to remove.
Pulled off the 4age loom and sent it to that chap on trademe what chops wires. Meanwhile, fitted the SQ engineering waterline and dizzy relocation kits to get things more latitudinal than longitudinal. Lovely quality kits with pimp CNC, nice fittings etc. Shame its all covered up by 20 year old plastics but whatev's.
I'd also picked up an A-series bellhousing pattern k50 gearbox to fit the 4age. Transferred the shifter and tailhousing from the starlet k50 so it'd line up with gbox mount, prop, gearstick hole etc. Handy.
Got the engine and box sitting in the bay on trademe-special mounts (damn it Jim, I'm a vet, not a fabricator) but ran into a slight snag. The capped off dizzy mount was interfering with the firewall and the heater matrix pipes.
Modified the mounting points and moved the engine forward 20mm, and got one of the heater matrix pipes brazed on a little further outboard, and this just about sorted it. Still tight, but no longer interference fit. Obviously this also changed the position of the gearbox, but that would be a problem for another day.
Noticed at this point that the clutch cable locator on the gearbox had been chopped off by some enterprising dick somewhere along the line. Ballz.
Was having second thoughts about using a k50 behind the XTREME POWER 9000 of the blacktop at this point anyway. Suppose a bracket wouldn't be too hard to fab.
Oops^2.
T50 is about the same length as a k50, handy. Also came with a beefier and longer corolla prop.
The KP prop was too short, (we moved the engine forward 20mm, remember), so I had the corolla prop shortened and balanced to fit. While I was at the engineers shop I had them braze a second, wider pipe into the fuel tank pickup.
Now using the wide one as the feed to my Carter low pressure lift pump. This sends the fuel forward through 8mm aluminium lines I routed alongside the 6mm factory ones. When it gets to the engine bay it deposits it into an Ali-Express-Special surge tank with an integrated Bosch 044 that supplies the fuel rail. Return from the surge tank runs through the narrower diameter factory fuel lines and back into the tank through the original (narrow) pickup. Seems to work quite well! Hopefully not all too noisy when the exhaust is on, we'll see.
Starting to look pretty good in there now I reckon.
One of the big differences between T50 and K50 boxes is the T50 is hydraulic clutch rather than cable. Came at this from a few angles; ended up buying an ae86 master and slave cylinder, as well as some nice braided clutch line, but didn't want to curse word around with the pedalbox too much. A lot of the modified ones out there looked a bit compromised, with big flex forces on the pedal where bits of steel bar had been tacked on to get it actuating the MC. Bought a pedalbox from an EG civic for super cheapz on trademe and the separate clutch pedal actually looks like a promising alternative. The other route seemed to be to fit a Wilwood pedalbox or similar, like Snoozin' is doing for his. Pimp, but didn't want to rush down that route just yet. I'm 6'2" and was worried that a floor mount pedalbox would sit closer to the drivers seat than the factory one, and I already struggle to get my gangly legs wedged in. Hmm.
At this point, Nats '16 happened, shotgunned my way around for a stress-free time this year.
Found a clone in Horopito, poor thing.
Was having a chat with Beaver, Manu, Goat, Ned and Cam, and one of them suggested a cable fork conversion kit from a company in Ireland. Ideal! Some googling revealed that FLOS.IE was the company that did them. GCs to deal with and did me a discount for sending a k50 donor fork for them to molest into one of these:
Got myself a Christmas present, an N2 style aluminium rear wing. Nicely modelled here by a goat majestically sunning itself in it's natural habitat:
Flippity flip I hate wiring.
Spent ages trying to work out why engine was turning over but not firing. Had spark but no injector pulse. Finally found this absolute treasure trove of 4age wiring goodness. Had to re-wire my fuel cutoff relay circuits to incorporate the ECU starter trigger like so:
et voila!
Much relief.
A bit of rust to sort in the heater channel, so loom came back out for now (also to solder and wrap properly, rather than the twist-and-tapes that you can see in the video...)
Gave the exhaust bits and bobs a tidy up. It's a 20v manifold (not sure what make, but the bolt spacing is 20v specific), and my original 2" system.
What now?
Oh yeah, lows.
Got some other bling from T3, these are just lovely.
Fitted up well (though they sent the wrong bolts with the RCAs). Gave the dust shields and calipers a bit of a spruce before shifting them onto the shiny legs.
Have since swapped the brake lines out for some pimp gold (don't judge me) Hel stainless steel braided ones. Don't trust 32 year old brake lines too much, and while it was all apart... No pics unfortunately.
As for the rear, figured a good low spring/short travel adjustable damper combo would be the way to go. Integrated shock/coilover units are available, but didn't want to go to the lengths of reinforcing turrets/axle spindle etc, at least not yet. If I eventually go T-series rear end that'll be the time for those fun and games.
Seems some people use mk2 escort rear dampers as their short travel shock of choice. With the amount of competition options available for them I thought that'd be a sound choice, so got some GAZ (English company, played with some of their stuff before I came over here) 38-way adjustable shocks for the rear. Should be enough adjustability to get it riding well I hope! Expecting to have to modify the Cobra springs to get them low enough. We'll see.
Current ultimate racecar spec as stands:
Chassis:
Stock kp61 Sprint body
T3 adjustable front coilovers
Cobra superlow rear springs
GAZ adjustable dampers (mk2 escort)
Hel braided SS brake lines
13x7 Work Equip 01s
A-series to K-series engine mounts
Battery relocated to boot.
Engine:
Stock 4AGE 20v blacktop from a Levin
SQ engineering waterline kit
SQ engineering Dizzy kit
T3 100mm velocity stacks
4-1 20v manifold (unknown brand) with 2" custom exhaust.
1G-GE high torque starter with Niteparts spacer kit
Simplified loom
Carter Lift pump/engine bay surge tank/Bosch 044 EFI pump setup
AE86 radiator
Transmission:
T50 20-spline
FLOS.IE T50 clutch cable conversion kit
Exedy 220mm clutch
Shortened corolla driveshaft
Stock U-code rear end
Plans:
Sort small rust patches in rain channel
Make up gearbox mount
Make up driveshaft loop
Fit O2 sensor and flanges to exhaust manifold
Fit rad and pipes
Cert
Doorts
Other stuff I can't think of right now.
