Aug 18, 2017 10:12:15 GMT
Can anyone tell me how to remove the headlight switch with headlight angle adjuster (that's a mouthful) on my RHD W202 Elegance?
Headlight adjustment switch is hissing. I suspect it's leaking or the tubes into it is leaking/sucking in air. If I press the throttle thereby using up the vacuum so to speak, the hiss goes away.
How will I get this one passed the missus...
stwat
Aug 18, 2017 15:57:19 GMT
This may sound odd but, w hiss at the adjuster means it is most likely leaking at one of the headlights. Normally the connection at the drivers Sade headlight. I have had this happen a few times.
If you still need to remove the switch. Pull off the headlight switch using a pair of pliers, with a rag in the jaws to protect the switch. Undo the nut underneath and pull the housing and adjuster out.
1992 190E 1.8 manual
1989 300SE Low mileage LuxoBarge
1988 190e 2.6. 1988 190 2.3-16 Cosworth
Aug 19, 2017 20:35:53 GMT
Cheers mate. I will try that. If it's at the headlight unit, what am I looking for?
My old W123 series was a similar set up but it looks like there is a junction next to the fuse box. I presume (it's early days and i'm not familiar with 'Lucy' yet) that there is a one way valve system which the W123 series didn't have. The headlights don't move a lot when I use the adjustment switch but that could mean it's the switch or the headlight.
Any experience of removing the door handle on the drivers side front door [insert smiley icon]? Panel removal is a cinch.
Aug 20, 2017 16:58:54 GMT
Found the source of the problem. T piece undone on the N/S headlight. Someone had used a cable tie to tidy up the adjacent loom and thereby pulling the purple tube off the headlight.
Now to get hold of my mate (£22 k he spent on a Mini!!!, the tw@t) and sit him in the car, drive around a bit and find the source of some rattles/squeaks*...
*I'm not in Essex or near Dagenham, so don't go there.
