jonomisfit
Club RR Member Number: 49
I sealed up the important bits of the rack with rags and duct tape, then gave the steel part of the rack a clean in the blast cabinet P1070356 by jono_misfit, on Flickr P1070357 by jono_misfit, on Flickr i then gave the whole rack a good clean down P1070358 by jono_misfit, on Flickr then cleaned up and resealed the valve block and rack P1070359 by jono_misfit, on Flickr P1070360 by jono_misfit, on Flickr I painted the rack body (zinc primed, then a couple of coats of black) then did a fill in job. aluminium mounts to the lathe I didnt have the 30mm ali bar I needed... only 40mm.... cue a lot of material removal P1070361 by jono_misfit, on Flickr marked up and started trimming to size P1070362 by jono_misfit, on Flickr turned round, sized the bar and started cutting out the steps (pic shows 2 back to back, and two nose to nose) P1070363 by jono_misfit, on Flickr P1070364 by jono_misfit, on Flickr end up with these P1070365 by jono_misfit, on Flickr fitted them to the now dry rack body, a light press in with the vice P1070366 by jono_misfit, on Flickr P1070368 by jono_misfit, on Flickr I test fitted it to the cross member, which was perfect one side and had a gap the other... A measure of the bushes I pushed out show them to both be the same size... a measure of the cross memeber shows one gap to be 5mm bigger than the other. I shall need to look at this.... Started putting the rack back together. replaced seals and greased the bits as I put it together. Finger crossed i've not pinched any seals as getting the pinion back in was a right pain. P1070369 by jono_misfit, on Flickr The screw in cap to set the pinion rack preload had been cross threaded previously (i think this rack has been rebuilt before) and I couldnt get it to hold the spring down. Back to the lathe and made this. Luckily I had the right set of change gears to get the 1.25mm pitch metric thread. P1070370 by jono_misfit, on Flickr the two holes are for what I'd call a pin drive, which allows you to get a decent shear to turn it in. I used some drill bits and a length of box section with holes in it P1070371 by jono_misfit, on Flickr and screwed in P1070372 by jono_misfit, on Flickr I set it so the rack doesnt move back and forth off the pinion, but still moves freely side to side P1070372 by jono_misfit, on Flickr More rack rebuilding next time.
Enbloc
Nice work.
I've been asked to rebuild a rack, which I've never done before, so this is a good eyes on.
jonomisfit
We'll find out how well i've done it when i've put oil through it It it comes back out again the answer will be not very well
jonomisfit
Feb 10, 2023 21:39:18 GMT
My dad had a rummage round in his sheds and found 6 different starter motors of 4 different types... After a bit of an internet search I think i found the right part number which one of the starters had on it... He posted it down A comparison P1070373 by jono_misfit, on Flickr The perspective in the image is misleading as its only 5mm shorter than the one I have. P1070373 by jono_misfit, on Flickr I stripped it down and cleaned up the internals P1070374 by jono_misfit, on Flickr rebuilding P1070375 by jono_misfit, on Flickr and built back up P1070376 by jono_misfit, on Flickr I connected it up to the little tester battery (and then recharged the battery as it was flat....) and checked the solenoid throws and the motor spins ok. Which it did. So sanded it and painted it P1070379 by jono_misfit, on Flickr P1070380 by jono_misfit, on Flickr and ready to fit P1070381 by jono_misfit, on Flickr and fitted P1070382 by jono_misfit, on Flickr 5mm length difference on the starter doesnt sound like much, but you can see how tight it all is round here. The starter is 5mm shorter, and the tube that carries the nearside drive cross sump shaft has a clearance notch in it, and it only just get in there P1070383 by jono_misfit, on Flickr I had a spare 10 mins, so took a look at the heat shielding again. The exhaust pipes are going to run very close to the chassis legs so have extended the shielding P1070384 by jono_misfit, on Flickr P1070385 by jono_misfit, on Flickr
jonomisfit
Feb 12, 2023 20:55:27 GMT
I saw my backside with the state of the workshop, so spent some time tidying, sweaping up, and a tip trip to get rid of some junk. Not perfect, but better than it was P1070386 by jono_misfit, on Flickr P1070387 by jono_misfit, on Flickr P1070388 by jono_misfit, on Flickr and was embarrased by the state of the lathe, so gave that a clean up as well. P1070389 by jono_misfit, on Flickr I'm still waiting for some flare fittings and tube to arrive so I can finish off the steering rack, so made a quick list of some of the major jobs to do on the escort.... there are quite a few. P1070390 by jono_misfit, on Flickr first one picked from the list.... rear suspension P1070391 by jono_misfit, on Flickr damper out P1070392 by jono_misfit, on Flickr beam dropped P1070393 by jono_misfit, on Flickr there isnt much in the back end... P1070394 by jono_misfit, on Flickr start stripping down the arms (my camera is on its way out as its constanly out of focus in half the pictures....) P1070395 by jono_misfit, on Flickr I could get the nut off one of the hubs, but despite full pelt with the imapct driver, and a good yank with the extension bar (plus extender tube) i couldnt get it to budge. I've put it asside to take to local garage tomorrow to see if they can get it! stripped the one I could get the nut off and put in the blast cabinet for a light tickle. The ends are duct taped up as they are spherical bearings in the end of cosworth arms, not bushes, and as they are in OK condition I don't want to junk them. I want to change to a 6degree rear beam in the future which uses rod ends not these bushes. As the bearings are £95 each I'd like to can avoid buy new ones if I can as it'll be wasted money. P1070396 by jono_misfit, on Flickr cleaned up a few other bits P1070397 by jono_misfit, on Flickr The hub carrier bearings are toasted... but as there's loads of grease in there I taped over them so prevent the blast media getting contaminated. the arms need a few mods. First one is this relief cut. I'm running group A rear dampers which are intended for use in the mag rear arms. The damper mount for which are much shallower P1070398 by jono_misfit, on Flickr but using them on standard beams causes this issue on droop P1070399 by jono_misfit, on Flickr the damper body wedges on the arm, so I've trimmed clearance. P1070400 by jono_misfit, on Flickr Tigged on a new flange P1070401 by jono_misfit, on Flickr P1070402 by jono_misfit, on Flickr Just... and I mean just.... enough space to get a socket on The bracket with the bolt is bent, so I need to straighten it to finish the flange..... and work out what its for.... The roll bar mount is further forward on the arm. I think it might be for the group A anti roll bar. But its not clear. P1070403 by jono_misfit, on Flickr P1070404 by jono_misfit, on Flickr The problem with coil over dampers on the rear is it shifts load to a relatively week point on the arm. Looking at some pics online the 6 degree beam rear arms get a reinforcing plate under the existing bracket, same with the strngthened arms for rallying. go here P1070405 by jono_misfit, on Flickr some box P1070406 by jono_misfit, on Flickr a bit of trimming P1070407 by jono_misfit, on Flickr P1070408 by jono_misfit, on Flickr ready for a clean up and weld on P1070409 by jono_misfit, on Flickr
Last Edit: Feb 12, 2023 21:09:04 GMT by jonomisfit
jonomisfit
Feb 14, 2023 21:26:20 GMT
I fettled the brackets a bit more then welded them in P1070410 by jono_misfit, on Flickr P1070411 by jono_misfit, on Flickr P1070412 by jono_misfit, on Flickr Should add a fair bit of strength to rear damper mount P1070413 by jono_misfit, on Flickr I knocked out the bearing on the rear bearing carrier P1070414 by jono_misfit, on Flickr P1070415 by jono_misfit, on Flickr Its in OK condition. A few marks where it bearings havent been knocked out well in the past, but should be useable bearings feel ok and look in not bad condition P1070416 by jono_misfit, on Flickr the shells look fairly clean too P1070417 by jono_misfit, on Flickr appart from that.... that doesnt look good.... P1070419 by jono_misfit, on Flickr I have new bearings though. The other arm is with the local garage to try and get the nut undone.
mk2cossie
Club RR Member Number: 77
Feb 14, 2023 22:19:54 GMT
Always good to see a nicely welded gusset...bracket Certainly looks strong enough to last a forest stage 👍
jonomisfit
Feb 14, 2023 22:30:02 GMT
And will also hopefully survive the terrible country roads round where i live. I think most forrestry roads are smoother and have less pot holes.
jonomisfit
Feb 17, 2023 20:26:34 GMT
The local garage got the nut off for me in about 5 seconds. a little light pull got the hub out P1070420 by jono_misfit, on Flickr but this pulled out with it P1070421 by jono_misfit, on Flickr P1070422 by jono_misfit, on Flickr Which may explain why this bearing was rumbling.... knocked the bearing shells out and put the housing through the blast cabinet P1070423 by jono_misfit, on Flickr P1070425 by jono_misfit, on Flickr got the arm ready for a tickle P1070424 by jono_misfit, on Flickr worst bits cleaned off P1070426 by jono_misfit, on Flickr marked out to trim the relief round the damper mount P1070427 by jono_misfit, on Flickr trimmed P1070428 by jono_misfit, on Flickr stiffening strip tigged on P1070429 by jono_misfit, on Flickr P1070430 by jono_misfit, on Flickr P1070432 by jono_misfit, on Flickr added the coil over gusset and welded in P1070433 by jono_misfit, on Flickr cleaned up the bearing housing and etch primed P1070434 by jono_misfit, on Flickr P1070435 by jono_misfit, on Flickr
teaboy
Make tea, not war.
Feb 17, 2023 20:50:20 GMT
I think that is ready for a new bearing.
jonomisfit
Feb 18, 2023 20:56:40 GMT
jonomisfit
Feb 18, 2023 21:10:26 GMT
Better start dealing with this as well P1070445 by jono_misfit, on Flickr the bushes are toast and being replaced with aluminium mounts. Best get them out and check the beam isnt rotted out under them as often happens. P1070446 by jono_misfit, on Flickr the state of the bush.... P1070447 by jono_misfit, on Flickr and the other side. P1070448 by jono_misfit, on Flickr I cut the top off the rubber and tapped them out A little bit of rust in the cups, but not toooooo bad P1070449 by jono_misfit, on Flickr Doesnt quite fit in the cabinet.... P1070450 by jono_misfit, on Flickr but a combination of blast, twist knot in the grinder, and scotch bride discs in the die grinder got most of the paint off. P1070451 by jono_misfit, on Flickr a few bits are just tough to get to P1070452 by jono_misfit, on Flickr bit more effort on it got off what I can get to P1070453 by jono_misfit, on Flickr then cleaned it down and on with some etch prime P1070454 by jono_misfit, on Flickr P1070455 by jono_misfit, on Flickr and leaving to cure P1070458 by jono_misfit, on Flickr Then sorted through some driveshafts to find the right ones I need for the rear, and find the right sized drive flanges. I have 2 different sizes, the 2wd cosworth ones which are 108mm and the 4wd cosworth ones at 100mm. My rear diff is the 7" one which has the 100mm joints. they are in there somewhere P1070456 by jono_misfit, on Flickr and eventually found the right output flanges P1070457 by jono_misfit, on Flickr which needed a really good clean down and a zinc prime to protect them P1070459 by jono_misfit, on Flickr Will see what I get on with next time.
teaboy
Make tea, not war.
Feb 18, 2023 21:24:21 GMT
Looking good dude.
mk2cossie
Feb 18, 2023 22:13:14 GMT
Are the 108mm shafts and hub drive stubs surplus to requirements jonomisfit? As I know someone that is after some of each
jonomisfit
Feb 18, 2023 22:41:26 GMT
Are the 108mm shafts and hub drive stubs surplus to requirements jonomisfit? As I know someone that is after some of each At this point, no. I may end up changing things up later down the line and I've got a 7.5" Diff and beam that I may swap to, which run the 108's. Sierra's R Us may have some for sale though.
jonomisfit
Feb 24, 2023 20:44:09 GMT
I pressed in the new bearing shells, the orange colour is the protective oil P1070460 by jono_misfit, on Flickr the stub axles cleaned up and a light coat of paint on non mating faces P1070461 by jono_misfit, on Flickr I need to clean these up before I reassemble anything P1070462 by jono_misfit, on Flickr studs pressed out using the press, some of which went with a bang and a half! P1070463 by jono_misfit, on Flickr faces all buffed up P1070464 by jono_misfit, on Flickr I could do with re-plating these, but I don't have a plating kit so ive painted the faces with zinc primer P1070466 by jono_misfit, on Flickr then paint polished back from mounting / clamping faces to prevent slackening new longer studs to go in P1070468 by jono_misfit, on Flickr fitted P1070469 by jono_misfit, on Flickr P1070470 by jono_misfit, on Flickr then on with rebuilding the rear bearing carriers. Taper bearings greased and fitted P1070472 by jono_misfit, on Flickr The cosworth manual call out some specific ford stanard the grease has to be compliant to, and this FUSCH one matched it P1070473 by jono_misfit, on Flickr wiper seal fitted P1070474 by jono_misfit, on Flickr And re-assembled P1070476 by jono_misfit, on Flickr Nuts not done up as I need to split them to fit to the beam Beam given a once over with some black P1070465 by jono_misfit, on Flickr Paint left to harden P1070475 by jono_misfit, on Flickr I was looking for the parts to rebuild the driveshafts.... and it was as cheap to just buy new ones. So I have. If they turn out to be rubbish i'll rebuild the original ones P1070477 by jono_misfit, on Flickr boot pushed on P1070478 by jono_misfit, on Flickr lobro joint fitted P1070479 by jono_misfit, on Flickr got coated in grease so no pics mid assembly P1070480 by jono_misfit, on Flickr I ran out of time to do the other one, so will do it next session. But quickly put some etch prime on the rear arms P1070481 by jono_misfit, on Flickr P1070482 by jono_misfit, on Flickr P1070483 by jono_misfit, on Flickr These will get a quick flat and paint next time.
jonomisfit
Feb 26, 2023 20:59:48 GMT
jonomisfit
Feb 26, 2023 21:38:37 GMT
then onto the rear diff, which looks fine P1070486 by jono_misfit, on Flickr except..... oil has started leaking from here...... P1070487 by jono_misfit, on Flickr Which means the output shaft seal has let go. Which has happened in the time its been here I was apprehensive about undoing the torx head bolts on the diff cover, but they all cracked nicley and undid easily. P1070488 by jono_misfit, on Flickr there is no diff drain.... so positioned over the edge of the bench, put under the seat with the oil catch can P1070489 by jono_misfit, on Flickr and unleashed the stench P1070490 by jono_misfit, on Flickr Oil was faily clean, although old. And on to why I was taking the cover off..... These C clips hold in the output shafts P1070491 by jono_misfit, on Flickr and the second one P1070492 by jono_misfit, on Flickr output shafts P1070493 by jono_misfit, on Flickr lovelly... P1070494 by jono_misfit, on Flickr that looks eaqually lovelly.... explains why its leaking P1070495 by jono_misfit, on Flickr bunged up the bearings up to prevent anything going into them, then cleaned up as best I could P1070496 by jono_misfit, on Flickr other side was much better P1070497 by jono_misfit, on Flickr the front flange is also a mess. I looked in the manual and then selected ford tool A123-456 P1070498 by jono_misfit, on Flickr yes..... yes that will also need replaced P1070499 by jono_misfit, on Flickr I cleaned up the flange in the blast cabinet P1070503 by jono_misfit, on Flickr P1070504 by jono_misfit, on Flickr Still not pretty Zinc primed all over P1070505 by jono_misfit, on Flickr I sprayed it all black, then cured it, then flatted the mating flange using my steel plate, some wet and dry, and WD40 P1070517 by jono_misfit, on Flickr hmmmmm. I don't like that for mating to the prop. I clocked it up in the lathe, which wasnt easy and took a couple of thou off the front face Looks a lot better, not perfect, but better P1070518 by jono_misfit, on Flickr P1070519 by jono_misfit, on Flickr That should work, but if it doesnt then I'll need to releave one of the other diffs of its prop flange. output shaft seals pulled out P1070500 by jono_misfit, on Flickr they resisted.... P1070501 by jono_misfit, on Flickr Cleaned up further and new seals fitted P1070507 by jono_misfit, on Flickr P1070508 by jono_misfit, on Flickr Then the output flanged got protected where they needed it and took a trip through the blast cabinet. P1070506 by jono_misfit, on Flickr gave them a clean, a zinc prime, and then a coat of satin black P1070509 by jono_misfit, on Flickr and fitted P1070510 by jono_misfit, on Flickr P1070511 by jono_misfit, on Flickr Cleaned up the diff mounting face P1070513 by jono_misfit, on Flickr Cleaned up the back plate P1070502 by jono_misfit, on Flickr then applied the sealing paste to the diff cover P1070512 by jono_misfit, on Flickr bolted on and torqued up P1070515 by jono_misfit, on Flickr P1070516 by jono_misfit, on Flickr Once the pinion seal turns up I'll fit that and that'll be the diff done... after a bit of a clean.
mk2cossie
What is it with Ford not putting a drain on their differentials? Mk1 and 2 Granada is the same. Although I did repurpose one of the lower diff cover bolt holes in to a drain, with a small amount of drill action
jonomisfit
Saving those vital pence from a machining op and a bung...
I was contemplating putting a drain point in, and may well do that on the 7.5" diff.
