moglite
Club RR Member Number: 144
Oct 24, 2019 13:40:03 GMT
This particular piece isn't finished yet, but I'm quite chuffed with it, so was eager to share Taking inspiration from no less than E-types and proper Hot-Rods...... I wanted a louvred bonnet. So taking the marking out/design phase very slowly and methodically. I came up with this I planned to use a die in my bead roller to make the louvres, and whilst these dies will cut. It is a lot easier if you pre-cut the slits. I had to cut out a section of bonnet bracing, so the panel would fit in the bead roller. It was rusty - what a surprise !! Basic bracing to keep some shape in the panel. Here it is all in situ. I used a tripod to support the weight of the panel, as I was working alone Here is a close up of the die ready to be tightened down. Because of the pre-cut slits, the die followed the lines very accurately. It was also easy to feel where to stop and start the rolling. That was quite hard work, heaving heavy panels around, and concentrating. Also knowing I had precisely one shot at getting it right. But it turned out pretty well. A quick blast of primer so it photographs better, and we have this. The money shot Yep very happy with that for few hours work and the cost of a pair of dies (£50) When the bracing is back in place it should a bit better, as there is some oil-canning at the moment. Getting everything 100% even and ready for paint will be a straightforward but time consuming task - but that can wait for another day. Thanks for looking
Oct 24, 2019 17:16:11 GMT
WOW! They look sweet! Never thought about doing them in a bead roller.
Great work.
Oct 24, 2019 18:43:23 GMT
That looks very nice! Well done
Oct 25, 2019 20:46:13 GMT
Brave man doing that to the bonnet! Turned out well though
moglite
Oct 27, 2019 17:58:31 GMT
So I set myself the target of doing as much as I can by the end of October, and then turn the car around and finish the other side. Whoo-hoo 27th October, and deadline beat But I'm getting ahead of myself again. I'd previously spent about 6 hours fitting the rubber door seals - horrible job, there is probably a knack or a special tool, but I had neither. Soapy water, a plastic tool, and a few mm at a time I still haven't got the feeling back in the end of my thumb after a week or so !! Also did some final fettling on door adjustment, with everything set level on the ground. Then some rudimentary masking before spraying a can of Dinitrol ML into the doors/A-pillar/B-pillar/rear wing and valence. Time to start putting things back together - rear boot panels. Speakers were black, but have been primered, and sprayed silver to tone them down a bit. With the Dinitrol in place, that allowed me to do the final fitting of the rear door trim. The front door too. strikey wasn't keen on the ashtrays. Bit late now, but I think I spray them silver or chrome them to blend them in a bit better. Job for another day though. That was my to-do list done, so now it was time to turn the car around, so I could finish the other side. I live on a bit of a hill, and the engine and brakes are all a work in progress, so rather that watch the car career down the hill out of control. I purchased some dollies so I could swing it around it the drive. Paintwork still needs a final detail/cut/polish but yeah liking that a lot. The air suspension is on the bumpstops here. The other side is half done. Sills and rear wheel arch and wing are done, along with the floor, chassis and outriggers. But the front wing repair sections were out of stock at the time, which I why I stopped on this side. The door shuts are very tight on this side, so there will be lots of work on getting all the gaps set. Replacing the front wing with a better example and fixing the extensive rot I've found in the A-pillar will be the big jobs. Oh and the engine bay and front need more than a little TLC Thank for looking
Last Edit: Oct 27, 2019 18:01:02 GMT by moglite
Pid363!
Madness is all in the mind!
Oct 27, 2019 18:40:59 GMT
Still love it!
Stupid is as stupid does!
Oct 27, 2019 18:50:10 GMT
This is giving me a really bad case of the wants. Those bonnet vents couldn't look better. Great stuff.
eternaloptimist
Oct 27, 2019 19:01:54 GMT
Great work. Love these.
Oct 27, 2019 19:29:36 GMT
strikey wasn't keen on the ashtrays. Bit late now, but I think I spray them silver or chrome them to blend them in a bit better. Job for another day though. more a case of would have looked sleeker without.... a bit like a boil on kylie minogues rsesome serious progress there though.
Last Edit: Oct 27, 2019 19:30:17 GMT by strikey
Oct 27, 2019 21:17:13 GMT
I like the ashtrays, they just look a bit odd in black now. What would be really trick would be to have them remade in alloy, if that's possible.
C-rock
Didn't know it was you 😮 been following this since the beginning
moglite
I had the please of meeting @westy67 the other day. I got some bit off of him that will help my project along greatly. All will be revealed soon
Last Edit: Nov 1, 2019 22:36:35 GMT by moglite
moglite
It is time for more rust Some of the interior is actually quite nice now, so protect it with old curtains (they don't burn easily) and then hack the old front wing off - like you do !! The A-pillar and scuttle needs work - but I knew that. A very unpleasant hour or two with the twisted knot brush, and the inner wing is largely back to bare metal. The curly panel around the side-lamp doesn't want to fit just yet. But I've cut enough crud out of the way to do a first fitting of the replacement wing. A bracing bar has been fitted to ensure levels, and center lines all match up reasonably well. That curly panel hasn't succumbed yet - but it will. Being able to fit the wing will allow me to fix the rust repairs, and build up the flanges needed to make it bolt on. But I got distracted, so that is as far as I got.
Last Edit: Nov 6, 2019 19:15:31 GMT by moglite
moglite
The holy grail, or at least one of them in Farina land is a front bench seat. So, when by chance I got offered one, it was time to raid the autobank and head north after work. In the cold light of day, I can see straps and foam will need work, but I was told to expect that. Oh and it is beige - but that will change. What I wasn't expecting was the non-automotive stuffing used for a previous repair LOL. The seat uses a single central runner/adjuster and an ickle wheel at each end !! That big runner bolts in place of the drivers side inner seat runner. It needs a couple of extra bolts and and underfloor captive plate. But that will be easy when I'm in the mood. It is just a proof of concept now. Teasing my hernia and back back I heaved the seat into position. I love the way the front and back seats now how matching cutouts The rear of the seat is very plain, but in good condition, and just a single ashtray to annoy the ashtray police But a front armrest for the win. I was never 100% happy with the colour of the repaired front seats, they came out a bit "raspberry" for my liking. But they are too nice to tear into and redo. But this bench seat needs replacement leather on the squab at least. Then everything needs to be this rich maroon'y colour I've used for the sunroof panel. Very happy with the way the interior is going, albeit very slowly
C-rock
I love it 😁
C-rock
Downside is you need one of them rare fintail hockey stick gearstick 🙄
fogey
For those of us that don't have a bead roller to form louvres - just visit your local tip / recycling centre and buy a couple of scrap Microwave ovens - they often have louvred vents on the side or back - just cut out thee whole section and weld it to your car - assuming you have a welder of course
moglite
Just a small but essential update. Learning from my mistakes - strip the paint off of the doors outside. The new purple strip discs are great and don't wear much. The worn one was all I used to strip this door. That door needs a few spot repairs to be welded in but nothing out of the ordinary, just as well as estate doors are very rate. So the same process with the front door. I'm still on the first striping disc, the 2nd one I bought might be an heirloom. There isn't any rust to speak of on the front door. But it was absolutely slathered in filler. The worlds worst panel beater has been let loose on the bottom of the door for some reason. Tricky to see because of the shadow, but the ruler takes no prisoners As I am the worlds 2nd worst panel beater I'm sure I can make that a little better and save the world's stocks of body filler. Thanks for looking
moglite
I was bored of tripping over the spare A-pillar section on the garage floor. So before something nasty happened, I carefully cut off the first repair panel I needed from it, to get it out of the way. Knowing how big the repair panel could be, allowed me to cut away some more of the scuttle, so I could see the rust in the A-pillar. Far from pretty, but I can now see that shouldn't be too hard to cut out and weld in a few repair sections - pheww. So on a roll, I resumed work on the front wing. That curly panel put up a good fight, but I managed to get a 1/2 decent fit. Temporarily held in with pop-rivets, so I could do a trial fit of the grille. The sharpie line is the outside of the grill, so I've just got to make sure there are no gaps. Some localised tin-worm has been revealed after dipping. So the old rinse-lather-repeat of. Make a repair panel. Mark around it, and cut out the rot. Minor trimming for best fit, and clamp it into place for welding. Weld that into place, and grind it all back, and be ready for the next section. That wing is better than the original, but still needs a few spot repairs, which should be straightforward. Even if I spent a grand on a new steel wing, I'd be welding it, so I could modify it to bolt on rather than be spot welded, so I might as well do it this way. Thanks for looking.
I said it when you were doing the other side; that rot would have frightened the life out of me. Fair play to you for keeping on with it. 👍😃
