Jul 11, 2019 20:03:52 GMT
Pid363!
Madness is all in the mind!
Jul 11, 2019 21:51:49 GMT
Not wishing to copy you but I want to do ally panels for the 2 door. I’n exchange for rental of your knowledge and new toy I may have a spare pair of hands and arms! What thickness ally are you using? Copy away - it is hardly an original idea, and it'll be perfect for your 2-door - we can sort something out. I think I'm going to go for a full sheet of 1mm 1050 ali. It is about £80 from Metal Supermarkets, and if everything goes to plan I can get all my panels from that single sheet. Thanks Andy I will have to sort out a trip down. Have you tried Longbridge motor spares for the estate rubbers?
Stupid is as stupid does!
moglite
Club RR Member Number: 144
I've put the bead roller and door panels to one-side, as I've been concentrating on the bodywork. The current goal is to get the rear door hung, with the hinge areas/shuts painted, so I can mask, and continue working on the outside of the panels. This slightly strange way of working is due to - The two-tone makes the shuts quite complicated
- I've got limited room in my garage to work on panels off the car
See I'm using the bonnet as a work-bench !! But that door is two-toned now, and ready to bolt on. I've got a bit of overspray to cleanup at the end of the job, and I'm going use some pinstripe tape to cover the join. Difficult to see, but the finish from my new spray gun is pretty good straight from the gun IMHO. So there is no need for any flat/polish on the internal surfaces for now at least. My rear wing has led a 1,000 lives, and needed quite a bit of metal work. The first coat of primer filler reveal high-spots and low-spots. But I did a bit of remedial work with the DA and some glaze, and shot the 2nd coat. Along with some grey top-coat so I can get the striker into place The A and B pillars have also been receiving some bodywork and paint. The new sill plates have been adjusted to fit, and are just resting in place in this shot. Getting close to bolting that back door on which would be a good milestone. Then I can mask the bits I've done, and lay down more primer filler on the exterior panels. Thanks for looking
moglite
Jul 28, 2019 17:36:02 GMT
This weekends update.... I got the 1/2 painted rear door back on the car i'd previously painted the top of the rear wing, and I was happy with it, but now I'm using a long sanding block, it makes the panels a lot flatter than previously. Masked up ready to throw on some primer filler There is about 2L of cellulose primer filler on this side, and I've blocked it black, putting most of it on the floor, which I then walked everywhere. That allowed me to see areas that needed a little more work. I'm happy with the sill now, so I shot another 1.5L over the wings and doors, and put on a guide coat ready for final flatting back, at least I hope that is the last round of primer/filler Whilst the car is in this position, I think I need to put the top-coat on the sills/wheelarches at least, as I need it jacked up to get the spray gun into position. But got a busy week at work now, so progress will slow a little, whilst the primer/filler hardens off. As always thanks for looking.
Jul 28, 2019 18:10:08 GMT
GSP (Great Solid Progress)
Last Edit: Jul 28, 2019 18:10:27 GMT by Deleted
Jul 29, 2019 17:39:14 GMT
Indeed solid progress there! One warning: you should be carefull with hanging the doors when the car is on axle stands. I thought this was only valid for convertabels but i had my Rover P5B on axle stands and hung the doors but could not get all the gaps 100% right so had to remove a shim behind a door hinge to get it right. Then put the car on its wheels and the doors did not open really nice so i had to fit the shim again. Normally i would think that the car has structual problems but the inner and outer sills were all replaced by myself. Could not believe it was oke but then lifted my daily Rover P5B with a jack on the proper position and yes also on that car the door did not open well either. I did all the welding on the project Rover with engine and gearbox, subframe and axles on the car and with the axle stands where the wheels are so in the end, i did not have problems.
Keep up the good work as you are almost done Peter
Jul 30, 2019 11:21:32 GMT
What he said. If you must hand panels with the car supported, put the stands under the rear axle and front suspension points so as to mimic the car being on the ground. This especially goes for welding on structural panels.
moglite
Absolutely with the car being on the ground for final fitting. I did all the metalwork on the door gaps with the car on the ground. The doors are "hung" but will need final tweaking as I don't have the rubbers in place yet.
Jul 31, 2019 11:55:15 GMT
Will it be the lighter colour first or does it not matter?
moglite
Jul 31, 2019 12:12:06 GMT
Will it be the lighter colour first or does it not matter? I'm going to do the maroon first, then I can get it off the axle stands. I'll mask off the areas that I'll spray grey. 95% of the join is hidden behind a stainless waistline strip, so any small overlaps will be hidden. Where it joins in the door shuts, I'm going to try some 10mm wide chrome pinstripe tape I've got to mimic the waistline strip. As the maroon is on vertical sections I'm hoping I don't have to clean the garage 100% to get a good finish, a wet floor and extractor fan helps a lot.
moglite
Aug 19, 2019 20:19:28 GMT
Had a few days off work, so I pushed on. The primer filler in the previous posts was blocked, but I wasn't quite happy enough, so I laid down some more and blocked that off. If you like masking, then paint a two-tone car in a small space - then will keep you happy. Now the car can do its hovercraft impersonation The original plan was to get some body colour on the sills and edges, so I can get the car back on the ground. But I got carried away, and started laying down some colour on the main panels. I believe the sill looking darker is just the light in the garage. But the reflections of the tool chests bodes well for the final finish. Being impetuous - after a short while I whipped off the masking paper and tape, and dropped the car back on its wheels. The rear valance is done too There is dust in the colour coat, but I couldn't clean the garage until the car was back on the wheels, hopefully it will polish out, if not it won't be too much work to lay down a clean coat when the garage is cleaner. Next step is to get the rear tailgate into colour. Thanks for looking
Aug 19, 2019 20:24:39 GMT
Christ their expensive! I don't know what their other prices are like but we use 2mx1m sheets of 2mm mild at work (therefore thats the only item i can compare) and they are about £25 from local stockholders, £65 from there! We use maybe 10 sheets a year so its not like were even getting discount.
Last Edit: Aug 19, 2019 20:30:15 GMT by VW
Aug 19, 2019 20:29:28 GMT
If you like masking, then paint a two-tone car in a small space - then will keep you happy. I know what you mean! I painted the inside of my van white, then masked the inside off, leaving the returns of the door skins etc for outer colour, then two toned the outside of my van along with a pinstripe. I put the top colour on the sills too. Took me about 7 hours to mask it up! And i had the luxury of space. Worst part of the whole job imo. Still, your cars looking great!
Aug 24, 2019 17:00:50 GMT
Ive just been directed to this thread by @grumpynorthener when I was asking about chrome paint.
Ive only quickly scanned through so far but I will go back and read properly - looks a really good project.
Car's looking great, I'm really impressed with what you've been able to do in such a small space.
moglite
Aug 27, 2019 15:17:12 GMT
Car's looking great, I'm really impressed with what you've been able to do in such a small space. Thanks - but it doesn't seem like such a small space when the time comes to clean up the dust, and line one side of the garage with plastic ready for spraying But cleaning up the garage was how I spent my Bank Holiday Monday, getting ahead of myself a bit. Before that is was time to get the tailgate into paint. It was a bit rougher than I thought and took quite a bit of prep to get it this good (but still not perfect) With the garage a mess and full of a dusty Morris Oxford - I did my painting on the lawn. First the grey Then the maroon . The external tailgate hinges got in on the action too The tailgate has been baking in the sun for the last three days, so the paint should have hardened off nicely. But I'm not looking forward to refitting it with all that shiny paint around. There is no gasket between the hinge and the body/tailgate, so scratches are easy. I'm pondering making some gaskets out of some thin clear/black plastic which might help, without throwing the fit off
Pid363!
Aug 27, 2019 16:23:36 GMT
Mega! Love seeing an update! Keep up the good work sir
Aug 28, 2019 11:14:19 GMT
Goop, so you can keep the water out?
moglite
Aug 28, 2019 21:27:58 GMT
So I had a hunt around, and found some plastic just 0.2mm thick, so made up some shims/gaskets which would allow me to adjust the hinges without scratching the paint. That worked well, and I was able to get the tailgate bolted on without scratches. As a bit of a boost I put various fittings loosely in place, yes I've got new number plates on order, as this one is past its best. Oh yes - liking this a lot Fitting the tailgate has allowed me to set the masking for the two-tone break accurately. Yet more masking before spraying some grey is in my future. Thanks for looking.
You're doing a great job and the Oxford is coming together nicely! The number plate you have there looks perfect to me! I love those plastic digit plates - and they are so easy to restore if you want them "as new". Although I prefer them slightly aged just like yours. My pet dislike is seeing cheap black and silver aluminium plates on '60s cars - especially when they have the wrong modern font!
