Apr 23, 2017 21:37:40 GMT
I get that they can produce silly numbers, but you can't escape that youre putting near half a ton of iron in the nose instead of 200 kilos of 2j!
if it had to be diesel I'd be going Om6**, but its not my project so crack on!
whitz
West Midlands
Apr 23, 2017 21:44:45 GMT
I get that they can produce silly numbers, but you can't escape that youre putting near half a ton of iron in the nose instead of 200 kilos of 2j! if it had to be diesel I'd be going Om6**, but its not my project so crack on! its around 600kg more but my reasoning why not put something in that will barely fit rather then have a massive hole in the engine bay? Ash
heathrobinson
Broken everything
Club RR Member Number: 111
Apr 23, 2017 21:47:37 GMT
OM606's can sound good, but a well tuned Cummins makes my spine tingle. Go the whole hog and put a jake-brake* on it for the full auditory experience!
*Disclaimer - I get the feeling that an exhaust brake would be bad news for drifting, especially in something so light. Eating your steering wheel every time you lift off probably won't help smooth drifts. It'd sound pretty special though
whitz it is all about having the motor wedged in the bay! Even better if it hangs out the sides and sticks out the top!
Colonelk
Club RR Member Number: 83
OM606's can sound good, but a well tuned Cummins makes my spine tingle. Go the whole hog and put a jake-brake* on it for the full auditory experience! *Disclaimer - I get the feeling that an exhaust brake would be bad news for drifting, especially in something so light. Eating your steering wheel every time you lift off probably won't help smooth drifts. It'd sound pretty special though Haha, I reckon that could work well actually, especially when shift-locking. Would need it on a lever or something so it only engages when you want it to.
Last Edit: Apr 24, 2017 8:29:10 GMT by Colonelk
whitz
West Midlands
Progress has been a smidge slow around work car shows and my knee really causing me issues (excuses i know) As usual pictures decided to rearrange them self during upload, this is the lastest pic of how it sits both rear toe arm inner camber bolts seized so i couldnt leave them in the end cut and burnt them out and put on a set of driftwork adjustable arms measuring up for sleeved shaft length more temp wheels bough the fit over the brakes so i can get them built interior painted in hammershite black smooth, as you can see i ran out but has been done now Fuel tank dropped for inspection, clean and undersealing, you an see under arches parts not done as it will be chopped and tubbed (saves effort) along with new poly bush diff mount chopped sleeved shaft welded up reassembed and put in place after several thousand F's under the sun due to there joint design Currently unable to find a Right rear handbrake cable for a half decent price that is actually in stock and not on back order which is holding me up Il be going to get an engine next week at some point too Ash
whitz
West Midlands
May 17, 2017 20:18:58 GMT
after alot of hassle with handbrake cables manage to get one off a st205 which is identical after alot of searching All new cables fitted along with shoes, springs, retainers etc and a good scrub up recon'd calipers fitted red paint stripped and gone to VHT black, new pads and fitting kit for good measure, ground the celica off the caliper now worth £100 more per caliper, I'm not even joking the scene tax is a joke slapped the bonnet on just to get it out of the way, will end up with a few holes in it Ash
Last Edit: May 11, 2020 0:44:20 GMT by whitz
May 17, 2017 21:51:14 GMT
whitz
West Midlands
May 21, 2017 15:44:19 GMT
Not much of an update due t oa few car shows, but pulled the gel stickered toyota off the roof along with the really curse word paint job, so guess what loverly job I'm about half way through Ash
whitz
West Midlands
May 29, 2017 21:13:04 GMT
all front suspension including subframe removed cleaned prepped wishbones painted all graesed and back together, including shultz under both sides 4pot calipers fitted on the front, paint can blocked solid so will paitn another day also put the discs on the wrong way so gotta come off again toight Ash
tristanh
Routinely bewildered
May 29, 2017 22:51:52 GMT
Discs on the wrong way, as in the grooves facing wrong? Would it really make a difference though?
whitz
West Midlands
Got abit busy over the weekend, front brakes built up and painted (no pics) Also collected a gearbox, flywheel and bellhousing all matching with a old clutch that i know will fit for mockup Also went and paid for this, a 250hp 820nm from factory FV432 APC engine will do nicely 250hp of glorious american pig iron Only 597 run hours on the engine so only just bed in really for one of these engines Ash
jelmerc31
Ja mar ik bin net benaud!
Does it have a industrial fuel pump or a regular pump?
1983 Datsun Laurel C31 3.0 V6 24v turbo--> 4.5 V8 32v 1986 Nissan Laurel C32 2.8 diesel 1984 Nissan Patrol 160 2.8i L6
1984 BMW E28 3.8 M5 sold 1987 Alfa Romeo 75 T.S sold 1985 Alfa Romeo 90 3.0 V6 sold 1996 Dodge Ram 3500 Cummins turbo diesel sold 1978 Dodge D300 Cummins turbo diesel sold 1985 Nissan Patrol 3.3 TD sold 1988 Alfa Romeo 75 2.5 V6 sold 1993 Alfa Romeo 75 1.8i.e sold 1986 Alfa Romeo 75 1.8 turbo sold 1984 Nissan Patrol 3.3 D sold
Jun 11, 2017 18:54:10 GMT
daft question, but what would the diesel engine had been standard in?
@ CRX_IN_SCOTLAND
nel5on
West Midlands
Jun 11, 2017 19:46:28 GMT
great looking project.
Covin 996.2 Tucson
Jun 11, 2017 20:39:26 GMT
daft question, but what would the diesel engine had been standard in? lots of stuff, typically Commercial, 7.5 ton Dafs I think would be the most common use in the uk, Dodge full size pickups, buses, agricultural equipment, en.wikipedia.org/wiki/Cummins_B_Series_engine
mattiwagon
Just got a work truck
Jun 11, 2017 20:40:43 GMT
daft question, but what would the diesel engine had been standard in? A fecking British Army armoured personnel carrier!🤘😆
Last Edit: Jun 11, 2017 20:41:27 GMT by mattiwagon
If they cant be nice f**k em!
84 low t25 panel 1.9td beige and rust combo 97 Goped Bigfoot G260RC with clutch conversion 97 Impreza turbo 2000 builders wagon 76k sold 04 Fabia vRs 50mpg pocket rocket 04 battered T5 pickup in blue! Chainsaws lotsa Chainsaws
whitz
West Midlands
Not much progress has been made as show season is in full swing, having a fair few issues, brake servo not fitting needing to be "frabricobbled" to fit, engine is yet to be delivered as theres a slight issue with it where the head has got to be whipped off After 4 months the custom extreme offset wheels turned up, shame they turned up damaged as they came though the box's and knackered the powdercoat still yet t obe fixed as there basically slow rolling me as i want them re powdercoat (seems fair right?) having lots of issues with paint, roof all flaked off and parts all over reacting, i suspect it might of has paint stripped over it at one point with issues with paint and wheels i hit the "curse word it" stage and made a roof rack up and bolted it straight into the rood and ordered 285 60 18 rear tyres, so its now getting lifted suspension and a madmax stlying so watch this space Ash
with issues with paint and wheels i hit the "curse word it" stage and made a roof rack up and bolted it straight into the rood and ordered 285 60 18 rear tyres, so its now getting lifted suspension and a madmax stlying so watch this space Well that took a sharp left turn! I'm still looking forward to seeing it come to life either way!
Look up these boys. They have a Cummins diesel in an rx8 in Ireland . Seen it in the flesh and the engine looks huge
