Il update this thread now ive got a little bit of time
started plugging things in and going around the car doing everything to get it running to see what path to go down, i was the first person to have a battery on in 5 years as the sunroof automatically shut (scared the curse word out of me as i was under the bonnet as it pulled up the plastic covers sounding like arcing cables) speedo reset from 20mph, lovely white dials in a MK1 ZT over the blue in Mk2s
i had got her up and running on 4 then 5 cylinders, injectors clogged solid
Dale at bailey performance cleaned them out 3 times (look how nasty the fluid went) and flow tested them all nice and even flows
changed the fluid again for the last clean
the joys of finishing a job someone else started, let my mate pull it into the workshop and wouldnt start (after i swapped all the dash over) starter nut had fell off or wasnt installed
Whole airbag system had to be changed, ecu, driver and passenger airbag, curtains squib and stalks along with the whole dash as it was bent from going off, cleaned all whle i was in there, front seats removed too and pre tensionsers and seatbelts changed along with crash sensors under carpet (nightmare job)
windscreen replaced off the donor car (on left) that the airbag system came out of
uooer dash is all the same color just looks off, lower section is a gloss not satin but a deatail for later
decided to whip the engine out as it needed some rework and rear of engine bay panels beating and patnting
oil was a big convern as it came out like it had water in there, id put fresh oil in and no water system fitted with around 6 mins it total run times in short stints moving the car
i replaced followingwith new , sump gasket, ac pump, pas pump, water pump, alternator, all aux pulleys and belt, manifold gaskets, spark plugs, oil filter, wishbone bushes to poly + arb along with a full clean down and paint of block etc
inside of sump was nasty and baffle plate had corrosion so stripped it all down cleaned and refitted
block all cleaned and painted
after engien refitted
whipped all suspenion off, ground off any corrosion, fertan converted twice and left over night followed by cold gav and then tinted raptor liner in silver metallic bodycolor under arches lower bay and tunnel
raptor linered, painted all brackets i had taken off and strainted and cleaned up all heat shields
raptor came out quite alot thinner then i expected, used 2x1L bottles for this, also sprayed in holes and down chassis legs
painted all the one chassis leg in 2K MBB silver not the poundland paint it had on there
partially re-assembled with heat shields etc, also modded and fitted a diesel sound proofing blanket across the rear bolt on bulkhead, missing piece was ordered from rimmers for near on £100 to be told (2 weeks later) its NLA
so i will have to get a normal one ( i few 3 away) and modify it
made a new bracket to hold the pas pump, rather then to chassis make it onto the stock engine bracket using a chopped up diesel bracket and a V6 pot
i want v8 noises
safe to say v8 noises achived
remembering where half of this went
did alot of little nigglly bits here, changing damaged plugs to nice new ones taping and coving etc along with a few broken wire repairs
unfortunately is back in bits there as the alternator charging system has an issue, on the igniter system
new Genuine radiator, AC condensor, pas cooler
Couldnt with the old cooling fan assembly so ordered another Genune item (my poor wallet) but looks the bits and no cracks, put all airbox assemly back in place, also ordered new bonent cables (x3) aftermarket clips afor them and 2 new bonnet latches to be future proof on issues
Been doing odds and sods minor items prople wont see link swapping out bent pas rack lines to a good set i have and heater valve block repair kit, new bolts for wings etc
Rear discs where too good to justify spending £300 on a pair for now all cleaned up inside/out and internal face with with paint, waiting on black paint for calipers the rear AP racing calipers weigh just nothing
i bought this paint pod that said its good for "4 caliper" so far done around 12 calipers and 6 discs with about half left
price gouging on v8 parts are silly £60 for handbrake shoe? no thanks il part search it for £12.50 delivered for TRW shoes for a pugeot 607
same issue with brembo pads £120 all around some searching got them for £65, lotus for the rear and bmw for the front
numberplate + some TFR to get the green off looks half respectable, bumper needs realighing with exhausts but thats on the list
Basically where i am upto now
Ash
